Rotora Big Brake Kits (Front) - Club4G Forum : Mitsubishi Eclipse 4G Forums - 2006-2012 Eclipse Authority
Go Back   Club4G Forum : Mitsubishi Eclipse 4G Forums - 2006-2012 Eclipse Authority > Marketplace > Parts Directory > Brake Parts
Brake Parts Calipers, rotors, lines and brake kits
Old November 11th, 2007, 11:26 AM   #1 (permalink)
What Drives You?
Slippercream's Avatar
Part Description (from Rotora)
Made of billet aluminum alloy and CNC machined to ensure the highest quality; Rotora's high performance brake system enables superior brake modulation while improving overall pedal feel to ensure equal distribution of weight transfer when braking. To achieve this proportional front-to-rear brake bias, Rotora’s opposing piston calipers are fine tuned by increasing the clamp load to the optimal level while utilizing the stock master cylinder to retain overall front-to-rear brake bias. Rotora’s full big brake system design delivers excellent initial bite, exceptional modulation, and consistent pedal feel for street and track use applications. All systems are ABS compatible and direct bolt on replacement with minimal modifications required.
COMPONENTS/FEATURES:
  • Rotora billet aluminum alloy 2, 4, 6, 8, or 12-piston racing calipers with sequentially sized piston bore sizes engineered to each specific vehicle.
  • Rotora billet aluminum hat with “floating” disc assembly to reduce heat related stress and unsprung weight.
  • Rotora one piece vented, or two piece heat treated directional vane disc system to improve airflow/cooling under severe braking.
  • Slotted or drilled & slotted oversize discs up to 16” (405mm) to ensure equal heat dissipation and increase thermal capacity while relieving the disc and brake pad surface free of excess debris.
  • Rotora ceramic formulated pads designed for extreme street and track application with high co-efficient of friction and high temperature fade resistance.
  • Rotora DOT compliant stainless steel braided brake lines to improve stiffer pedal feel and prevent brake hose expansion.
  • Rotora carbon steel (SC45) mounting brackets (depending on application) and hardware
Tech Specs / SKUs
  • 4-piston 1-piece caliper / 330 x 24mm rotors (RBK018.04)
  • 4-piston 2-piece caliper / 330 x 30mm rotors (RBK018.05)
  • 4-piston 2-piece caliper / 355 x 32mm rotors (RBK018.06)
  • 6-piston 2-piece caliper / 355 x 32mm rotors (RBK030.01)
  • Custom config of calipers, rotors, and hats (1-pc /2-pc) available by special order
4-piston / 2-pc caliper shown, with 2-piece lightened rotors (aluminum hat), mounting bracket, pads, and stainless steel brake lines.
Old November 11th, 2007, 11:31 AM   #2 (permalink)
MIA4gEclipse is on a distinguished road
Ive got them
*Clutchmasters Stage 3 clutch/Aluminum Flywheel
*Eibach pro kit
*Progress rear sway bar
*Black Housing projector headlights/eyelids
*Aero kit Fangs
*TWM SSK,bushings and weighted knob
*Rotora 4 Piston BBK with 14in Rotors and SS lines
*Two 10in MTX Thunder 4500 subs in jackhammer box
*Kenwood Excelon KDC-X591 HU with IPOD hook up
*Beltronics STI DRIVER radar detector
*AEM FI/C
MIA4gEclipse is offline   Reply With Quote Quick reply to this message
Old November 11th, 2007, 11:54 AM   #3 (permalink)
What Drives You?
Pardon the graphic rape photos, but I thought to add a little bling to 'em
I do need to get the 2-piece rotor.
I do actually want the 6-pots. When the budget permits I should be able to slap these back into the 3G (as these were originally on the old beast of laden):
Old November 11th, 2007, 01:34 PM   #4 (permalink)
here is the bbk on my eclipse
*Eibach pro kit
*Aero kit Fangs
*AEM FI/C
Old November 11th, 2007, 01:38 PM   #5 (permalink)
What Drives You?
Damn, dude! That is one pretty bitch-ride
Old November 11th, 2007, 01:39 PM   #6 (permalink)
thank you 2 of the rims came in the wrong color so im waiting on them to be painted then on the car they go and i can get some real pics taken
*Eibach pro kit
*Aero kit Fangs
*AEM FI/C
abs, brake, calipers, carbon, custom, dent, ding, heat, kits, list, modifications, mounting, pedal, performance, racing, rear, show, stock, street, system, temperature, weight
