Rotora Big Brake Kits (Rear) - Club4G Forum : Mitsubishi Eclipse 4G Forums - 2006-2012 Eclipse Authority
Go Back   Club4G Forum : Mitsubishi Eclipse 4G Forums - 2006-2012 Eclipse Authority > Marketplace > Parts Directory > Brake Parts
Brake Parts Calipers, rotors, lines and brake kits
Old November 11th, 2007, 11:32 AM   #1 (permalink)
What Drives You?
Slippercream's Avatar
Part Description (from Rotora)
Made of billet aluminum alloy and CNC machined to ensure the highest quality; Rotora's high performance brake system enables superior brake modulation while improving overall pedal feel to ensure equal distribution of weight transfer when braking. To achieve this proportional front-to-rear brake bias, Rotora’s opposing piston calipers are fine tuned by increasing the clamp load to the optimal level while utilizing the stock master cylinder to retain overall front-to-rear brake bias. Rotora’s full big brake system design delivers excellent initial bite, exceptional modulation, and consistent pedal feel for street and track use applications. All systems are ABS compatible and direct bolt on replacement with minimal modifications required.
COMPONENTS/FEATURES:
  • -Rotora billet aluminum alloy 2, 4, 6, 8, or 12-piston racing calipers with sequentially sized piston bore sizes engineered to each specific vehicle.
  • Rotora billet aluminum hat with “floating” disc assembly to reduce heat related stress and unsprung weight.
  • Rotora one piece vented, or two piece heat treated directional vane disc system to improve airflow/cooling under severe braking.
  • lotted or drilled & slotted oversize discs up to 16” (405mm) to ensure equal heat dissipation and increase thermal capacity while relieving the disc and brake pad surface free of excess debris.
  • Rotora ceramic formulated pads designed for extreme street and track application with high co-efficient of friction and high temperature fade resistance.
  • Rotora DOT compliant stainless steel braided brake lines to improve stiffer pedal feel and prevent brake hose expansion.
  • Rotora carbon steel (SC45) mounting brackets (depending on application) and hardware.
Tech Specs / SKUs
  • 2-piston 2-piece caliper / 330 x 30mm 2-pc rotors (RBK129.01)
  • 4-piston 2-piece caliper / 330 x 30mm 2-pc rotor (RBK129.02)
  • Custom config of calipers, rotors, and hats (1-pc /2-pc) available by special order
4-piston / 2-pc caliper shown, with 2-piece lightened rotors (aluminum hat), mounting bracket, pads, and stainless steel brake lines.
Old February 13th, 2008, 06:47 AM   #2 (permalink)
What Drives You?
Finally found pictures of the 2-piston rears:
Old February 13th, 2008, 10:16 AM   #3 (permalink)
tjf
Its MIVEC not MYVEC silly
tjf's Avatar
tjf has a reputation beyond reputetjf has a reputation beyond reputetjf has a reputation beyond reputetjf has a reputation beyond reputetjf has a reputation beyond reputetjf has a reputation beyond reputetjf has a reputation beyond reputetjf has a reputation beyond reputetjf has a reputation beyond reputetjf has a reputation beyond reputetjf has a reputation beyond repute
i want the whole kit its a shame its so expensive though
tjf is offline   Reply With Quote Quick reply to this message
Old February 14th, 2008, 01:03 AM   #4 (permalink)
What Drives You?
Yeah There is a cheaper option though, for the rears. You keep your stock rotors (or stock size at least) and get the Rotora MINI kit, which is also a 2-piston setup for the rear. A little smaller pad area than the BBK but definitely better clamping force than stock.
Or... you could always just go with used Evo Brembos
Old February 14th, 2008, 06:01 PM   #5 (permalink)
"Yayo"
Kilzod's Avatar
Vehicle: 2003 Eclipse GTS
Kilzod has a reputation beyond reputeKilzod has a reputation beyond reputeKilzod has a reputation beyond reputeKilzod has a reputation beyond reputeKilzod has a reputation beyond reputeKilzod has a reputation beyond reputeKilzod has a reputation beyond reputeKilzod has a reputation beyond reputeKilzod has a reputation beyond reputeKilzod has a reputation beyond reputeKilzod has a reputation beyond repute
Fawking sexy.... I hate our stock braking system, it is the suck for sure.
I'm pretty sure these won't fit with stock wheels, you need aftermarket with more(?? - whichever moves the wheels further out... I always get them confused) offset
Edit: Just read this was the rear set ( ) and am not sure if this applies to the rears too.
Kilzod is offline   Reply With Quote Quick reply to this message
Old February 14th, 2008, 06:28 PM   #6 (permalink)
NotUrAvg4G's Avatar
NotUrAvg4G has a reputation beyond reputeNotUrAvg4G has a reputation beyond reputeNotUrAvg4G has a reputation beyond reputeNotUrAvg4G has a reputation beyond reputeNotUrAvg4G has a reputation beyond reputeNotUrAvg4G has a reputation beyond reputeNotUrAvg4G has a reputation beyond reputeNotUrAvg4G has a reputation beyond reputeNotUrAvg4G has a reputation beyond reputeNotUrAvg4G has a reputation beyond reputeNotUrAvg4G has a reputation beyond repute
save the money and get the evo brembos. direct bolt on...just need the correct offset on the fronts to fit..(35mm)
OMG...NO...not a....CIVIC
http://i4.photobucket.com/albums/y13...b663cdwp51.gif
NotUrAvg4G is offline   Reply With Quote Quick reply to this message
Old February 14th, 2008, 08:55 PM   #7 (permalink)
What Drives You?
Only thing you gotta remember is OEM Brembos come with standard 1-piece plain rotors, and smaller pistons. Aftermarket ones have larger pistons and , lighter slotted/cross-drilled rotors. I don't even know if OEMs come with rubber brake hoses or braided SS.
Old February 22nd, 2008, 01:50 AM   #8 (permalink)
MIA4gEclipse is on a distinguished road
i love the Rotora front 4 piston bbk.. now i just need SS lines in the back and the 2 piston brembos lol
*Clutchmasters Stage 3 clutch/Aluminum Flywheel
*Eibach pro kit
*Progress rear sway bar
*Black Housing projector headlights/eyelids
*Aero kit Fangs
*TWM SSK,bushings and weighted knob
*Rotora 4 Piston BBK with 14in Rotors and SS lines
*Two 10in MTX Thunder 4500 subs in jackhammer box
*Kenwood Excelon KDC-X591 HU with IPOD hook up
*Beltronics STI DRIVER radar detector
*AEM FI/C
MIA4gEclipse is offline   Reply With Quote Quick reply to this message
abs, brake, calipers, carbon, custom, dent, ding, heat, kits, list, modifications, mounting, pedal, performance, racing, rear, show, stock, street, system, temperature, weight
