Rotora MINI Caliper Kit (Rear) - Club4G Forum : Mitsubishi Eclipse 4G Forums - 2006-2012 Eclipse Authority
Go Back   Club4G Forum : Mitsubishi Eclipse 4G Forums - 2006-2012 Eclipse Authority > Marketplace > Parts Directory > Brake Parts
Brake Parts Calipers, rotors, lines and brake kits
Old November 11th, 2007, 10:43 AM   #1 (permalink)
What Drives You?
Slippercream's Avatar
Part Description (from Rotora)
Made of Billet Aluminum Alloy and CNC machined to ensure the highest quality; Rotora's new MINI Caliper Kits Enables superior brake modulation while improving overall pedal feel to ensure equal distribution of weight transfer when braking. To achieve this proportional front-to-rear brake bias, Rotora's opposing piston calipers are fine tuned by increasing the clamp load to the optimal level while utilizing the stock master cylinder to retain overall front-to-rear brake bias. Designed purely to utilize stock diameter OEM brake discs thereby allowing to clear stock size diameter wheels. Rotora's new MINI Caliper Kits deliver excellent intitial bite, exceptional modulation, and consistent pedal feel. All systems are direct bolt on replacement with minimal modifications required.
COMPONENTS/FEATURES:
  • Billet Aluminum High Performance MINI Calipers provide increased clamp load to ensure equal front-to rear brake bias.Each engineered to provide optimum caliper rigidity and minimum weight. Differential caliper piston bore sizes engineered to each specific vehicle with dust seals. All MINI calipers are factory pre-installed and ABS compatible.
  • Ceramic Friction material pads designed for extreme high performance street driving and hard braking applications with high co-efficient of friction and high temperature fade resistance.
  • DOT-compliant Steel Braided Brake Lines to improve stiffer pedal feel and prevent brake hose expansion.
  • 45C Carbon Steel Mounting Brackets with Steel Studs to provide added strength. Direct bolt on replacement to the vehicle's original suspension.
  • Does Not include Rotors. Kit fits to all Stock Rotors or After Market Rotors.
Tech Specs / SKUs
  • 2-piston 2-piece front caliper , 261x10mm to clear 17" wheel (RCK129.01)
4-piston / 2-pc caliper shown (actual hardware is 2-piston, but similar look), with mounting bracket, pads, and stainless steel brake lines. Utilizes stock rotors / rotor size.
abs, brake, calipers, carbon, dent, factory, kit, kits, list, modifications, mounting, oem, original, pedal, performance, rear, show, stock, street, suspension, temperature, weight, wheels
