Stoptech Big Brake Kits - Club4G Forum : Mitsubishi Eclipse 4G Forums - 2006-2012 Eclipse Authority
Go Back   Club4G Forum : Mitsubishi Eclipse 4G Forums - 2006-2012 Eclipse Authority > Marketplace > Parts Directory > Brake Parts
Brake Parts Calipers, rotors, lines and brake kits
Old December 8th, 2007, 07:49 PM   #1 (permalink)
What Drives You?
Slippercream's Avatar
Part Description (from Stoptech)
Big Brake Kits give your vehicle that Supercar look and feel, and exceed stock performance in two areas. First, larger rotors increase heat capacity. Second, stiffer calipers and stainless steel lines reduce system compliance.
The key, however, is to increase heat capacity and reduce compliance without upsetting the stock front to rear brake torque ratio. If the brake upgrade you select adds too much front torque (as many do), you reduce your car's ability to utilize the tractive capacity of all of the tires to the maximum practical extent (even on ABS equipped cars) and you therefore create performance sacrifices. In addition, too many pistons or pistons that are too large will make the brake pedal much more difficult to modulate, which limits a driver's control of brake input on the race track.
Advantages of StopTech over other brake upgrades:
  • Shorter Stopping Distances
  • Better Brake Modulation
  • Firmer Brake Pedal
  • Less Brake Fade
Feature Benefit Summary:
  • Balanced Brake Upgrades™ with optimum brake bias offer the shortest stopping distance with the best pedal feel
  • Our patented AeroRotors® with the best airflow available result in better cooling, less fade and longer rotor and pad life
  • The stiffest aftermarket calipers with patented bridge result in better clamping under hard braking and less pad taper
  • Track testing of new applications ensures optimum performance
Tech Specs / SKUs
Four-wheel (complete) kit 1:
FRONT: 332 x 32 mm Rotor/ 4 Piston Caliper
REAR: 328 x 28 mm Rotor/ 2 Piston Caliper
  • Red slotted (83.624.4623.71)
  • Red drilled (83.624.4623.72)
  • Red slotted, zinc-plated (83.624.4623.73)
  • Red drilled, zinc-plated (83.624.4623.74)
  • Black slotted (83.624.4623.51)
  • Black drilled (83.624.4623.52)
  • Black slotted, zinc-plated (83.624.4623.53)
  • Black drilled, zinc-plated (83.624.4623.54)
Four-wheel (complete) kit 2:
FRONT: 355 x 32 mm Rotor/ 4 Piston Caliper
  • Red slotted (83.624.4723.71)
  • Red drilled (83.624.4723.72)
  • Red slotted, zinc-plated (83.624.4723.73)
  • Red drilled, zinc-plated (83.624.4723.74)
  • Black slotted (83.624.4723.51)
  • Black drilled (83.624.4723.52)
  • Black slotted, zinc-plated (83.624.4723.53)
  • Black drilled, zinc-plated (83.624.4723.54)
Front kit 1:
FRONT KIT: 332 x 32 mm Rotor/ 4 Piston Caliper
  • Red slotted (83.624.4600.71)
  • Red drilled (83.624.4600.72)
  • Red slotted, zinc-plated (83.624.4600.73)
  • Red drilled, zinc-plated (83.624.4600.74)
  • Black slotted (83.624.4600.51)
  • Black drilled (83.624.4600.52)
  • Black slotted, zinc-plated (83.624.4600.53)
  • Black drilled, zinc-plated (83.624.4600.54)
Front kit 2:
FRONT KIT: 355 x 32 mm Rotor/ 4 Piston Caliper
  • Red slotted (83.624.4700.71)
  • Red drilled (83.624.4700.72)
  • Red slotted, zinc-plated (83.624.4700.73)
  • Red drilled, zinc-plated (83.624.4700.74)
  • Black slotted (83.624.4700.51)
  • Black drilled (83.624.4700.52)
  • Black slotted, zinc-plated (83.624.4700.53)
  • Black drilled, zinc-plated (83.624.4700.54)
Rear kit:
REAR KIT: 328 x 28 mm Rotor/ 2 Piston Caliper
  • Red slotted (83.624.0023.71)
  • Red drilled (83.624.0023.72)
  • Red slotted, zinc-plated (83.624.0023.73)
  • Red drilled, zinc-plated (83.624.0023.74)
  • Black slotted (83.624.0023.51)
  • Black drilled (83.624.0023.52)
  • Black slotted, zinc-plated (83.624.0023.53)
  • Black drilled, zinc-plated (83.624.0023.54)
Complete Out of the Box 4-wheel Set:
Calipers:
Standard 2-pc uncoated steel rotors with aluminum hat:
Special zinc-coated steel rotors with aluminum hat:
600, abs, aftermarket, black, box, brake, calipers, cars, dent, driver, heat, kit, kits, life, list, offer, pedal, performance, race, rear, stock, system, tires, upgrades, wheel
