Go Back   Club4G Forum : Mitsubishi Eclipse 4G Forums - 2006-2012 Eclipse Authority > Marketplace > Parts Directory > Brake Parts
Brake Parts Calipers, rotors, lines and brake kits
Old February 17th, 2007, 10:52 PM   #1 (permalink)
Three Diamonds
Russ's Avatar
Tournaments Won: 4
Name: Russ Sanderlin
Techna-Fit Stainless Steel Brake Lines
When depressing the brake pedal on your vehicle, there is a high amount of fluid pressure that travels from your master cylinder out to your calipers to close the pads onto the rotor creating enough friction for you to stop. Through most of it's travels it goes through rigid steel tubing until except from the chasis out to the caliper. From the chasis to the caliper is usually rubber or nylon hose which can stretch or give under pressure especially as age occurs.
With stainless steel brake lines, there is substantially less flex and give to provide more response and consistent braking.
This kit is for all 4 corners.
This product is available through the following vendors
Russ is online now   Reply With Quote
Old February 20th, 2007, 03:52 AM   #2 (permalink)
NotUrAvg4G's Avatar
NotUrAvg4G has a reputation beyond reputeNotUrAvg4G has a reputation beyond reputeNotUrAvg4G has a reputation beyond reputeNotUrAvg4G has a reputation beyond reputeNotUrAvg4G has a reputation beyond reputeNotUrAvg4G has a reputation beyond reputeNotUrAvg4G has a reputation beyond reputeNotUrAvg4G has a reputation beyond reputeNotUrAvg4G has a reputation beyond reputeNotUrAvg4G has a reputation beyond reputeNotUrAvg4G has a reputation beyond repute
just received the vr4 brakes, im sure i need these too
NotUrAvg4G is offline   Reply With Quote
Old May 4th, 2011, 08:12 PM   #3 (permalink)
G-TuneD...
PearlGreenNMean's Avatar
Vehicle: 2009/Eclipse/GS
PearlGreenNMean is just really nicePearlGreenNMean is just really nicePearlGreenNMean is just really nice
Where can I get these?
The vendors dont show up, and i looked around for them, can't find them lol.
HAVE: OBX Exhaust Header+ Mid pipe, TB bypass, Custom CAI, HID Halo Sonar Projectors, Aero 2540i, Dash kit, AEM FIC!!!
SOON: D2 Coilovers...Mmmmmm MM!
WANT: Custom painted Rims, RRE underdrive pulley, High flow cat, The 3 Bars of SWAY!
Old May 4th, 2011, 08:21 PM   #4 (permalink)
Daxenth's Avatar
Vehicle: 2008 Eclipse GS-N
Daxenth is a splendid one to beholdDaxenth is a splendid one to beholdDaxenth is a splendid one to beholdDaxenth is a splendid one to beholdDaxenth is a splendid one to beholdDaxenth is a splendid one to beholdDaxenth is a splendid one to behold
RRE offers them bro. kinda pricy but you get nothing but quality from them
Mods=Daxenth's Satin Girl
Buy My Stock Shit!
