4G Reverse/Backup LED Bulbs! Several Model Options, Ships Same-Day! Plug & Play - Club4G Forum : Mitsubishi Eclipse 4G Forums - 2006-2012 Eclipse Authority
Go Back   Club4G Forum : Mitsubishi Eclipse 4G Forums - 2006-2012 Eclipse Authority > Marketplace > Vendor Forums > Diode Dynamics
Old September 1st, 2015, 03:43 PM   #1 (permalink)
Eclipse Lighting Vendors
Diode Dynamics's Avatar
Vehicle: Any
Arrow 4G Reverse/Backup LED Bulbs! Several Model Options, Ships Same-Day! Plug & Play
Mitsubishi Eclipse 4G Reverse Light LED
At Diode Dynamics, we carry a full line of LED bulbs, including three different model options for your reverse light or backup light bulb (3156 size). We carry the brightest, highest-quality bulbs on the market, which we have designed in St. Louis, Missouri. Your order will ship same day, and we're here if you need us for support and service. Every bulb carries with it a three-year limited warranty.
Your purchase includes two 3156-sized LED bulb, for perfect fitment in all 4G Eclipse Models.
Bulb Design
HP11: Four side-firing 1.5W-rated Osram LED chips, and one 5W-rated LED chip on top, which is projected by a lens for maximum effective brightness. The bulb is housed in a machined aluminum casing, which provides superior heat diffusion for long life.
XP80: Each of the four sides of this bulb contains three 5W-rated chips, and the top is fitted with four more under a projector lens. This is the brightest self-contained automotive LED bulb on the market, and is housed in an aluminum casing with a textured finish for maximum heatsinking properties.
Fitment. All three bulbs use a quality inject-molded 3156 terminal, with a locking base connector and proper pin alignment, designed for exact replacement of your factory 3156 bulb.
Included in your order is TWO BULBS.
COLOR
These LEDs illuminate in a crisp, cool, bright, white hue for maximum light output.
BRIGHTNESS
Diode Dynamics offers several brightness options so you can choose what fits you best. These options are listed by the design and the lumen output of each bulb:
HP11: Slightly higher brightness than OEM bulbs. (310 lumens)
XP80: Much brighter than OEM bulbs. These are bright! (510 lumens)
Lumens. BUYER BEWARE! Most sellers just provide "calculated" lumen numbers, based on the maximum potential brightness of the LED chips on the bulb. For example, if a bulb has five 10-lumen chips, they will rate it at 50 lumens. However, this is not accurate, as the design of an LED bulb does not get rid of heat fast enough to run the LEDs at maximum.
These "calculated" lumen ratings are much, much higher than the true, measured light output, so it will look like competitors' bulbs are brighter than ours. This is because Diode Dynamics does not provide inflated "calculated" numbers; we believe it is misleading. We test the actual brightness of the bulbs in our lab, to provide real lumen output measurements. Our measurements are accurate, but they are usually much lower than the misleading "calculated" figures. Please click here to learn more about LED brightness measurement.
QUALITY
LED Components. Diode Dynamics uses only the highest quality LED chips in the production of its bulbs. This means only brand-name suppliers such as Epistar, Cree, Osram, and Samsung.
While Diode Dynamics bulbs may look the same as others on the market, most copycat bulbs use economy-grade LED chips in order to reduce costs. This greatly reduces the reliability and overall brightness of the bulb when you compare it to Diode Dynamics.
Construction. Although LED technology allows for extremely long bulb life, the market is flooded with cheap LED bulbs that fail prematurely due to inferior construction. The worst enemy of LEDs is excessive heat, and when bulbs are not designed properly, they do not disperse heat as well, leading to premature failure.
Off-brand, cheap bulbs exhibit poor solder uniformity, high levels of flux in the solder, uneven chip placement, low-gauge terminal wires, poor assembly, and bulbs held together with inferior adhesives. At best, solder joints will crack and fail on low-quality LEDs after a few weeks of use. In the worst case, these bulbs can damage housings as the extra flux and adhesive evaporates and creates a residue on the lens of the housing.
Diode Dynamics bulbs are produced with modern, computerized equipment, and only the best materials, to ensure complete uniformity, high quality, and long bulb life. All Diode Dynamics products come with a 30-day satisfaction guarantee and a 3-year limited replacement warranty.
Questions? Feel free to ask here, PM, email contact@diodedynamics.com or call us: (314) 205-3033
Thank you!
Nick C.
Diode Dynamics
Diode Dynamics is offline   Reply With Quote Quick reply to this message
Old October 16th, 2015, 05:46 PM   #2 (permalink)
Vehicle: Any
Meet our newest LED bulb replacement, the HP48:
Available in 1156/7 - 3156/7 - 7440/3 sizes
Old November 11th, 2016, 12:40 PM   #3 (permalink)
Vehicle: Any
http://www.youtube.com/watch?v=LxSFb9Z6Sjg
Diode Dynamics at SEMA 2016
Old November 15th, 2016, 03:42 PM   #4 (permalink)
Vehicle: Any
Diode Dynamics Store
Old November 16th, 2016, 05:40 PM   #5 (permalink)
Vehicle: Any
Dealer Locator Tool
Looking for installation? We've added several new authorized dealers to our locator tool!
Nick C.
Old November 18th, 2016, 10:02 AM   #6 (permalink)
Vehicle: Any
Questions about automotive lighting? Give our team a call!
(314) 205-3033
Old November 22nd, 2016, 07:52 PM   #7 (permalink)
Vehicle: Any
The 2016 Black Friday Sale Starts Now!
20% off orders $100 or more using code: BLACKFRIDAY
*Cannot be combined with other discounts
Old November 23rd, 2016, 01:59 PM   #8 (permalink)
Vehicle: Any
The 2016 Black Friday Sale continues!
Old November 24th, 2016, 11:29 AM   #9 (permalink)
Vehicle: Any
Happy Thanksgiving!
Don't miss out on this year's biggest savings
Old November 25th, 2016, 08:13 AM   #10 (permalink)
Vehicle: Any
Black Friday is here!
Don't miss out on this year's biggest savings storewide
20% off storewide using code: BLACKFRIDAY
Old November 26th, 2016, 11:08 PM   #11 (permalink)
Vehicle: Any
The sale continues!
Don't forget to use the code: "BLACKFRIDAY" for 20% off orders storewide
Old November 27th, 2016, 09:52 PM   #12 (permalink)
Vehicle: Any
Don't stay in the dark this winter! The 2016 Black Friday sale ends tonight!
Don't forget to use the code: "CYBERMONDAY" for 20% off orders storewide
Old November 28th, 2016, 05:47 PM   #13 (permalink)
Vehicle: Any
Take advantage of our Cyber Monday Sale! (Ends tonight at Midnight CST)
Sale ends tonight!
Old December 6th, 2016, 06:24 PM   #14 (permalink)
Vehicle: Any
Don't forget to send us a PM for the free-shipping code!
(U.S. members only)
Thank you,
Nick C.
Old December 20th, 2016, 05:50 PM   #15 (permalink)
Vehicle: Any
New authorized dealers have been added to our dealer locator tool, check it out to find a dealer near you:
Dealer Locator Tool
Thanks!
Nick C.
Old January 5th, 2017, 01:50 PM   #16 (permalink)
Vehicle: Any
Questions? Chat with an expert on our site!
Diode Dynamics
Old January 10th, 2017, 09:47 PM   #17 (permalink)
Vehicle: Any
Contact@diodedynamics.com
Old January 11th, 2017, 07:21 PM   #18 (permalink)
Vehicle: Any
Diode Dynamics is on SnapChat!
Nick C.
Old January 12th, 2017, 02:54 PM   #19 (permalink)
Vehicle: Any
PM Responses sent!
Thanks,
Nick C.
2006, 4g eclipse, automotive, body, chip, club, day, eclipse, fast, fitment, gauge, heat, king, led, light, lower, mitsubishi, oem, projector, questions, service, shipping, shop, top, white
Lumen replacement LED bulbs carid CariD.com 0 October 17th, 2014 05:42 AM
