HOW TO: Replace Timing Belt/Water Pump 6G75/Eclipse GT - Club4G Forum : Mitsubishi Eclipse 4G Forums - 2006-2012 Eclipse Authority
Old October 21st, 2016, 08:42 PM   #1 (permalink)
Wwwyzzrdd's Avatar
Vehicle: 2009 Eclipse GT
Wwwyzzrdd is on a distinguished road
I'm surprised a how to for this hasn't been posted for this yet, so I thought I'd compile all the info out there together into one place for anyone who's wanting to give this a shot themselves. It's not hard, just takes some attention to detail and if you don't understand what this guide talks about, don't bother because you don't want your engine to get off on timing - $700 for a timing belt and water pump at a shop beats $3k+ for a new engine or rebuild if you mess this up.
I replaced my drive belts, water pump, timing belt, auto-tensioner, tensioner pulley, and idler pulley all at once. You had might as well since you're in the area anyways, especially since they're not expensive.
I didn't take any pictures myself, but I've included pictures of the diagrams, which are more helpful anyways (in my opinion) because they have the torque values included. I also left a link to the video I found for this at the bottom of the guide as well. It's where most of this procedure comes from, just altered slightly to make things easier since we don't have all the space an Endeavor has.
Removal:
1. Set vehicle on jack stands, disconnect battery
2. Support the engine on a jack (use a block of wood to protect the engine from damage)
3. Remove passenger side wheel and wheel well splash guard
4. Remove nuts/washers securing the power steering fluid reservoir to the frame (this just makes things easier to work around, not totally necessary)
5. Remove engine mounting stay
Engine Mounting Stay
6. Remove both upper timing belt covers
Upper Timing Belt Covers
7. Turn crankshaft clockwise until timing marks align on both camshaft sprockets and the crankshaft pulley at TDC
* The notch on the crankshaft pulley is on the inner edge, you have to look down from the top to see it *
Engine Timing Marks
8. Loosen the crankshaft pulley bolt
* You'll need something to hold the pulley in place here if you're not using an impact wrench - there's a special Mitsubishi tool for it, or you can make your own like some threads on here*
9. Loosen the generator/AC belt tensioner pulley adjusting bolt, then the locking nut (the adjusting bolt is underneath the pulley, just in front of the oil filter)
Generator/AC Belt Tensioner
10. Remove the generator/AC belt
11. Loosen the power steering belt tensioner locking nut, then the adjusting bolt
Power Steering Belt Tensioner
12. Remove power steering drive belt
13. Remove crankshaft pulley
14. Remove passenger engine mount
Engine Mount
15. Remove generator/AC belt tensioner pulley
16. Remove engine support bracket
* This bracket just barely squeezes in, you'll have to loosen all the bolts and pull the bracket out with the bolts still in it in order to get it out *
Engine Support Bracket
17. Remove power steering drive belt tensioner pulley and bracket
Power Steering Belt Tensioner Pulley and Bracket
18. Remove the lower timing belt cover
* Be careful with the crankshaft position sensor coming from the cover *
19. Immobilize both camshaft sprockets somehow (I just used some paracord tie through the sprockets and timing belt cover bolt holes)
20. Mark the current timing belt at the TDC markings on the sprockets and the direction of rotation
21. Remove the crankshaft position sensor (I just laid the sensor and wire over the engine, you don't have to remove it completely, just be careful with it)
Crankshaft Position Sensor
22. Lock the hydraulic auto tensioner in place. Sticking a small Alan wrench into the pin hole works.
Auto Tensioner Setting Pin
23. Loosen the timing belt tensioner pulley bolt
24. Remove timing belt
25. Remove tensioner pulley
26. Remove timing belt auto tensioner
27. Remove timing belt idler pulley
28. Ensure that the coolant is drained as much as possible from the engine and radiator - you won't get it all, but it's better than a complete waterfall
29. Remove water pump assembly from engine
* Don't dispose of this assembly, it's two pieces and you need to install the housing that sits in between the engine and pump on the new pump, there's 4 smaller bolts holding the two together *
Water Pump
30. Disassemble water pump assembly
Installation:
1. Assemble the water pump assembly (new pump + housing removed from old pump), ensure there is a gasket between the pump and housing
2. Install the water pump assembly onto the engine, ensuring there is a gasket between the engine and assembly
* Note: The torque values are different for the M10 and M8 bolts, see the diagram *
Water Pump
3. Install new idler pulley
4. Install new timing belt auto tensioner
* Leave the setting pin in the tensioner for now *
Timing Belt Auto Tensioner
5. Install new timing belt tensioner pulley, with the two smaller holes towards the ground, contrary to the diagram. Don't torque the bolt yet.
6. Install new timing belt according to the markings in this order:
1) Crankshaft Sprocket
2) Idler Pulley
3) Front Camshaft Sprocket
4) Water Pump
5) Rear Camshaft Sprocket
6) Tensioner Pulley
Timing Belt Routing
* The next steps are critical, if you don't have proper tension on the timing belt, it will likely slip or break prematurely, causing severe damage to the engine *
7. Set the correct tension on the belt by pushing the tensioner pulley against it. This can be done using the special tool designed to fit into the two small holes, as shown in the diagram. You can also wedge something between the pulley and the tensioner arm to set the tension on the belt (ensure it will not mar the pulley, which could damage the belt later). I used the small pry bar from the OEM spare tire equipment with a cloth between it and the pulley. If using the special tool, ensure the torque shown is 39 in-lbs. If not, ensure that the setting pin can be spun around freely in the pin hole.
* Do not half ass this end result of the pin spinning freely/39 in-lbs *
Setting Timing Belt Tension
8. While holding the tensioner pulley in place, apply the proper torque to the tensioner pulley bolt
9. Once proper torque is applied to the pulley bolt, ensure that the pin still spins freely in the auto tensioner. If it doesn't, the tension on the belt is incorrect and you must redo the previous two steps.
10. Remove you used to immobilize the camshaft sprockets
11. Rotate the crankshaft to ensure that the timing marks match up still (the belt marks may not match up to the sprockets after several turns, this is okay, as long as the marks on the sprockets all come to the marks on the engine at the same time)
12. After rotating the crankshaft, ensure the auto tensioner pin still spins freely
13. Remove the auto tensioner setting pin
14. Reinstall the crankshaft position sensor
15. Reinstall the lower timing belt cover, ensure that the crankshaft position sensor wire comes out of the cover at the correct location
Lower Timing Belt Cover
16. Reinstall power steering tensioner pulley and bracket
* Do not torque the pulley locking nut or adjusting bolt yet *
17. Reinstall engine support bracket
18. Reinstall generator/AC tensioner pulley
* Do not torque the adjusting bolt or locking nut yet *
19. Reinstall crankshaft pulley. Ensure the bolt receives a light coating of engine oil before installation. You'll need something to hold the pulley in place again as well. The torque on this bolt is 136 ft-lbs.
20. Reinstall upper timing belt covers
21. Reinstall engine mount
Engine Mount
22. Install power steering drive belt, tighten tensioner pulley locking nut (do not torque yet)
23. Apply proper tension to the belt using the procedure in the factory service manual, then torque the tensioner pulley locking nut to 36 +/- 7 ft-lbs.
24. Install generator/AC drive belt, tighten tensioner pulley locking nut (do not torque yet)
25. Apply proper tension to the belt using the procedure in the factory service manual, then torque the tensioner pulley locking nut to 36 +/- 7 ft-lbs.
26. Reinstall engine mounting stay
27. Re-secure the power steering fluid reservoir to the mounting bracket
Power Steering Fluid Reservoir
28. Reinstall splash guards and passenger wheel
29. Remove vehicle from jacks, reconnect battery
30. Refill coolant and burp it
31. Perform the ECU reset procedures
If you set the tension on the belt right, applied the proper torque to all the fasteners, and made sure the timing marks lined up at all times during this procedure, you should be fine. If not, I'm not a professional automobile mechanic, so I'm not liable for any damages. This is merely what I did. Here's the link to the video I got the general idea of how to do this from:
https://www.youtube.com/watch?v=V7vK7engRCc
Good luck, hopefully this saves you a few hundred dollars!
2009 Solar Yellow GT | Injen Cold Air Intake | BC BR Coilovers | Hackish Reflash
Ralliart Eyelids | StopTech X-Drilled Rotors
Wwwyzzrdd is offline   Reply With Quote Quick reply to this message
Old October 22nd, 2016, 12:13 PM   #2 (permalink)
Super Moderator
Very useful guide, nice to see one for the GT owners now
I think this warrants a sticky
March COTM VOTING form
Old October 24th, 2016, 10:59 AM   #3 (permalink)
Wwwyzzrdd's Avatar
Thanks! Figured it was about time since alot of people are going to be due for it soon, or are already overdue
eclipse, eclipse gt, engine, install, installation, mitsubishi, video
Question: Timing Belt Replacement GT chiron02 4G Eclipse GT/SE Specific 4 November 10th, 2016 12:40 AM
Gt timing belt sos Austin269 2006-2012 Eclipse (General 4G) 6 April 22nd, 2016 03:57 PM
[Request] Replace Stock Sub 06 Eclipse GT Dingo 2006-2012 Eclipse (General 4G) 4 August 19th, 2015 10:14 PM
My timing belt/water pump change Experience Porcupinepuffer 4G Eclipse GT/SE Specific 5 July 20th, 2015 03:15 PM
Question: 06 Eclipse GT timing belt kit Andy4G 4G Eclipse GT/SE Specific 24 January 2nd, 2015 11:00 AM
