Adjusting projector headlights? - Club4G Forum : Mitsubishi Eclipse 4G Forums - 2006-2012 Eclipse Authority
Old January 19th, 2013, 07:53 PM   #1 (permalink)
Use it or loose it
Itsa mitsa 08 gt's Avatar
Vehicle: 08 gt p
Itsa mitsa 08 gt is a jewel in the roughItsa mitsa 08 gt is a jewel in the rough
Hey guys,so I've hooked up my projector headlights and everything works great! Except for one thing,I can't adjust the pricks!
I'm (ass-u-me-ing) the adjusters are the Phillips (for low beams)and the flathead(high beam).
I didn't realize how tight it was in there! Now I'm hoping that a few of you fine gentlemen have some tips,because the only thing I can think of is to drop my bumper and keep taking out the headlights,then clipping them back on until there corrected!
I've looked for a how to,but came up short handed.
Thanks guys (and gals)
Itsa mitsa 08 gt is offline   Reply With Quote Quick reply to this message
Old January 19th, 2013, 07:55 PM   #2 (permalink)
Vehicle: 09 4G69
FeaRlezZ is a name known to allFeaRlezZ is a name known to allFeaRlezZ is a name known to allFeaRlezZ is a name known to allFeaRlezZ is a name known to all
u can manage going through the splashguard in the wheel well with a small screwdriver
Eagle + Manly fully built 4G69 8.5:1 87.5 106mm stroker _ RPW stage 1 camshaft _ Full custom Borla Exhaust _ Tuned _ AEM gauge pod
FeaRlezZ is offline   Reply With Quote Quick reply to this message
Old January 19th, 2013, 11:09 PM   #3 (permalink)
ClipsGT's Avatar
Vehicle: 07/Eclipse/GT
ClipsGT is a jewel in the roughClipsGT is a jewel in the rough
I used a 1/4in. drive ratchet wrench with like a 10" or 12" extension and a swivel on the end. I think it was a 10mm socket that fit it. it also had the Phillips and flathead that your talking about but I could also use a socket on mine.
ClipsGT is offline   Reply With Quote Quick reply to this message
Old January 19th, 2013, 11:17 PM   #4 (permalink)
Use it or loose it
Vehicle: 08 gt p
Thanks clipsgt,I was thinkin that not 10 minutes after I posted! Lol
Definitely by far the best way going about it. ��
Old January 19th, 2013, 11:27 PM   #5 (permalink)
Autocityimports Rep
OrangeDemon's Avatar
Vehicle: 2006/Eclipse/GT
OrangeDemon is a glorious beacon of lightOrangeDemon is a glorious beacon of lightOrangeDemon is a glorious beacon of lightOrangeDemon is a glorious beacon of light
Definitely by far the best way going about it. 😃
Best way to do it! You get your complete order yet!?
OrangeDemon is offline   Reply With Quote Quick reply to this message
Old January 20th, 2013, 10:56 AM   #6 (permalink)
ClipsGT's Avatar
No problem. Love to help when I can.
Old January 20th, 2013, 11:14 AM   #7 (permalink)
Use it or loose it
Vehicle: 08 gt p
almost. just waiting on the stiffy! i installed the tower bar as well. im heading to the shop where i work today so i can install the under brace,rear traiarm bushings and front bushings. i might send the car in to the mechanics to do the motor mounts,as im lacking on some tools for that job i think. as well,its my dd so if something goes south,i,ll be down a ride to work!
thanks for helpin a brotha out jason. joe has been pretty good as well. ill definately be getting more goodies through ACI!
Old August 12th, 2013, 05:00 PM   #8 (permalink)
Mvader's Avatar
Vehicle: 2007 / GS
Mvader is on a distinguished road
i'm having same issue,, i've installed the spec D tunning halo projector lights.. i'm assumine the same thing on the screws.. but i only see two screws for the projector bulb does this sound right. and which way does what adjust what? i've called spec D but they are not much help because no one has called me back. and i've emailed them. thanks in advance people.
Mods : Power sport Drilled / Slotted Rotors, Ceramic Pads all 4 corners. InSys Cold air Intake. FlowMaster Cat Back, Led Tail Lights, Projector Head Lights, blue led fog lights.
Mvader is offline   Reply With Quote Quick reply to this message
Old August 12th, 2013, 07:51 PM   #9 (permalink)
Use it or loose it
Vehicle: 08 gt p
Yes I believe there are two screws for each light(2 for low,2 for high beam) as for which one adjusts left to right,side to side,I can't remember. Mine still have to be adjusted. There a little hard to adjust. When I get time,I might just drop my bumper and adjust them that way(take it out,adjust it,then clip it back in and check it) I actually think I have to pop my lenses off and adjust or set them properly. Hope you don't have to do that! Good luck.
Old February 25th, 2014, 10:47 AM   #10 (permalink)
Vehicle: 07 Eclipse GS
CuTi08 is on a distinguished road
I have the same problem .. I try to adjust it but for some reason my passenger side it not doing so well the driver side show bright but I have hard time on adjusting the passenger side .. I hope after pop in the 1200K it make it better.. r else I have to take it apart and reagliment the lenses ...
CuTi08 is offline   Reply With Quote Quick reply to this message
back, bumper, cool, drop, headlights, how to, projector, short, works
FS: Projector Headlights, Projector Eyelids, Passenger Rear Assembly, and more! OrangeDemon Automotive For Sale/Wanted 109 January 23rd, 2013 05:13 PM
FS: Projector headlights FeaRlezZ Automotive For Sale/Wanted 6 October 28th, 2012 07:21 AM
WTB OEM projector headlights Rustyneedle Automotive For Sale/Wanted 0 July 22nd, 2010 12:22 PM
projector headlights need help. BARNEY1985 Problem Reports 0 July 11th, 2008 10:15 PM
Chrome Halo Projector Headlights or Black headlights Grant Audio & Lighting 6 June 18th, 2008 08:58 AM
