How Too MIVEC Indicator Light - Club4G Forum : Mitsubishi Eclipse 4G Forums - 2006-2012 Eclipse Authority
Old July 18th, 2013, 08:22 AM   #1 (permalink)
Gamer
cmturner's Avatar
How To MIVEC Indicator Light
So this is the How To to make this happen when MIVEC hits
https://www.youtube.com/watch?v=DWIj...e_gdata_player
To start out the how tools are different for the GS and GT
GS
For the GS you have to tap into the "Oil Pressure Switch Circuit "
It is pin 110 on the ECU or the switch itself is on the driver side of the engine, (Which I tapped into)
It is a yellow wire with a black strip
And the switch is only one wire, because it grounds out threw the engine, but once you tap into this wire, you run the wire to inside the car and hook it to the positive (+) side of the LED, and then ground the other side of the LED.
Now I put a volt meters on it all threw out the rpm Range and once mivec hits the voltage jumps up to battery voltage 13 V +.
GT
Special thanks go to DustinPeters for the GT wiring, he was the first one to figure it out, then I had to go from there and figure out the GS since it's different wiring harnesses
the wire color is yellow/black for the gt for sure, On the gt the wire is located on the bottom Harness of the ECU
on the second harness that's not visible with the cover on(wire is still accessible) there are only two yellow/black wires. If your unsure use a digital multi meter, the wire should hit 12v at mivec.
Instead of using a relay I used an in4001 diode to isolate the wire from the led.
Now if yall have any questions just ask
http://club4g.org/board/members-ride...ners-ride.html
Old July 18th, 2013, 08:23 AM   #2 (permalink)
Gamer
cmturner's Avatar
Also if a mod can move this to the HOW TO section, thanks
Old July 18th, 2013, 08:43 AM   #3 (permalink)
angel4g
Guest
Tournaments Won: 4
Posts: n/a
Great write up colt. +Erep
Old July 18th, 2013, 08:45 AM   #4 (permalink)
Gamer
cmturner's Avatar
Thank ya :-)
Old July 18th, 2013, 10:14 AM   #5 (permalink)
eosrebel's Avatar
Vehicle: 2009 Eclipse GS
eosrebel has a spectacular aura about
Great, now I need to mock up a MIVEC lens for the LED and integrate this into my dash. Awesome.
eosrebel is offline   Reply With Quote Quick reply to this message
Old July 18th, 2013, 10:23 AM   #6 (permalink)
Gamer
cmturner's Avatar
That would be awesome, I'm going to mount the LED eather on the radio cover, the top Radio mount(where airbag lights are), or somewhere on the gauge pod
Old July 18th, 2013, 10:34 AM   #7 (permalink)
eosrebel's Avatar
That's the hard part that I'm trying to figure out, where to put the damn thing? I'm with you in leaning towards the radio cover as there is a ton of empty space to work with. Maybe even something down by the shifter, perhaps opposite the power outlet? What I have in mind won't be super huge, maybe 2"x2" at the very most and probably even smaller than that.
Here's something that I just threw together to get an idea on the board.
Last edited by eosrebel; July 18th, 2013 at 10:35 AM. Reason: Change the image link
Old July 18th, 2013, 10:35 AM   #8 (permalink)
Interior Neon Fabrication
nickracer1108's Avatar
Vehicle: 2007 Eclipse GS
nickracer1108 is a jewel in the roughnickracer1108 is a jewel in the rough
i love everything on this thread right now ha
Sent from my house.
nickracer1108 is offline   Reply With Quote Quick reply to this message
Old July 18th, 2013, 10:37 AM   #9 (permalink)
Gamer
cmturner's Avatar
That would be cool, but I think next to the shifter won't work well.... Because your going to be looking down every time it lights up, I'm leaning towards the radio, but I'm going to play around with it this afternoon
Old July 18th, 2013, 10:39 AM   #10 (permalink)
eosrebel's Avatar
What I would really love to do is move the button for the hazard lights down next to the shifter and use that space for the LED. Hmmm.... I may have to look into that further.
Old July 18th, 2013, 10:40 AM   #11 (permalink)
Gamer
cmturner's Avatar
Now that would be freaking awesome lol
Old July 18th, 2013, 10:42 AM   #12 (permalink)
eosrebel's Avatar
It really shouldn't be too difficult to do, plus the dash would hide all the wiring...alright I'm sold.
Now that I've got my game plan, I'll go measure the button to see how much room I have to play with.
Old July 18th, 2013, 10:44 AM   #13 (permalink)
Gamer
cmturner's Avatar
Haha awesome
Old July 18th, 2013, 10:44 AM   #14 (permalink)
angel4g
Guest
Tournaments Won: 4
Posts: n/a
Hm..... Let us experiment (:<
Old July 18th, 2013, 10:47 AM   #15 (permalink)
angel4g
Guest
Tournaments Won: 4
Posts: n/a
Erep for a brilliant idea. I will experiment tonight when I get outta work. I'll keep u guys updated
Old July 18th, 2013, 11:08 AM   #16 (permalink)
Gamer
cmturner's Avatar
Think I'm going to take a long lunch and play with it
Old July 18th, 2013, 11:44 AM   #17 (permalink)
Gamer
cmturner's Avatar
Ok installed it on the radio display
Old July 18th, 2013, 02:54 PM   #18 (permalink)
eosrebel's Avatar
That's exactly where I'm going to put mine as it's the only spot large enough to accommodate a CNC'd piece of acrylic that I want. Unless I can move the hazard light into the center console, it's the only viable piece of real estate.
Old July 18th, 2013, 02:57 PM   #19 (permalink)
Gamer
cmturner's Avatar
Only problem with moving the hazard button, is you would have to extend the wire harness on it
Old July 18th, 2013, 02:59 PM   #20 (permalink)
Gamer
cmturner's Avatar
Oh and make sure you check the inside of the radio housing and see if it'll fit, there's not much room inbetween the AC vents and radio....
Old July 18th, 2013, 09:17 PM   #21 (permalink)
Gamer
cmturner's Avatar
Here is the final product of the MIVEC Indicator LED,
http://youtu.be/0ED0fktoO0A
Old July 18th, 2013, 09:56 PM   #22 (permalink)
Hoser is on a distinguished road
I know exactly where I'm putting mine. I'm just going to make a small lens with the Mitsubishi logo where the gear indicator is for the auto. Probably going to make it blue.
Hoser is offline   Reply With Quote Quick reply to this message
Old July 18th, 2013, 10:25 PM   #23 (permalink)
Gamer
cmturner's Avatar
awesome!!! when you do, take a pic of it!!!!
Old July 18th, 2013, 10:39 PM   #24 (permalink)
1st Turbo 4g In Colorado
DeAtHsWhIpLaSh's Avatar
Vehicle: 2009/Eclipse/GST
DeAtHsWhIpLaSh will become famous soon enough
Im still doing mine ill get a pic in the afternoon tomorrow, but omg this is awesome!
DeAtHsWhIpLaSh is offline   Reply With Quote Quick reply to this message
Old July 18th, 2013, 10:40 PM   #25 (permalink)
Gamer
cmturner's Avatar
im glad you like it
Old July 19th, 2013, 08:57 AM   #26 (permalink)
Gamer
cmturner's Avatar
I just realized in the video. You can hear the ice cream Man in the beginning lol
Old July 19th, 2013, 06:15 PM   #27 (permalink)
Miembro
TyEclipse's Avatar
Vehicle: 06 Eclipse GS
TyEclipse has a spectacular aura about
Great work!
One question: Do you have any idea of what output current/power that yellow wire has, as to know how many LEDs or what capacity could be wired?
http://i595.photobucket.com/albums/tt38/tyeclipse/DSC00151Signature.jpg
TyEclipse is offline   Reply With Quote Quick reply to this message
Old July 19th, 2013, 07:28 PM   #28 (permalink)
Gamer
cmturner's Avatar
Originally Posted by TyEclipse View Post
Great work!
On the gs, it has full power(13-14V) not sure about current
Old August 17th, 2013, 08:45 AM   #29 (permalink)
Vehicle: .
zschneiderj is on a distinguished road
zschneiderj is offline   Reply With Quote Quick reply to this message
Old August 17th, 2013, 08:51 AM   #30 (permalink)
Gamer
cmturner's Avatar
It's been done on the GT and worked, but the location you are thinking of putting the LED is a pain in the a**
Old August 17th, 2013, 08:53 AM   #31 (permalink)
Vehicle: .
Old August 17th, 2013, 08:56 AM   #32 (permalink)
Gamer
cmturner's Avatar
I understand what you mean, and it can be done, just going to take some work, but I have a GS and I didn't use a resistor or anything, just taped into the sensor,
Now the GT I'm not sure
Old August 17th, 2013, 09:01 AM   #33 (permalink)
Vehicle: .
Old August 17th, 2013, 09:25 AM   #34 (permalink)
Gamer
cmturner's Avatar
I have how to do it on the GT also towards the top
Old August 17th, 2013, 10:52 AM   #35 (permalink)
DustinPeters's Avatar
Vehicle: 08/eclipse/gt
DustinPeters is a jewel in the roughDustinPeters is a jewel in the rough
For the gt I used a 3v led, resistor was built in. I put a diode on it right at the connection to the car just to be safe.
DustinPeters is offline   Reply With Quote Quick reply to this message
Old August 17th, 2013, 08:15 PM   #36 (permalink)
Vehicle: .
Old August 17th, 2013, 10:10 PM   #37 (permalink)
Gamer
cmturner's Avatar
Awesome can't wait to see it
Old August 18th, 2013, 08:36 PM   #38 (permalink)
Vehicle: .
Old August 18th, 2013, 08:55 PM   #39 (permalink)
Gamer
cmturner's Avatar
Originally Posted by zschneiderj View Post
Ok so I have everything wired up and all set to go, and the light doesn't work... used a test light on the wire indicated above and cannot get it to light up when mivec is suppose to kick in. Am I doing something wrong here?
I have the light grounded out under the dash, and an IN4001 diode in line to a 12V blue led connected to the wire. But even with a test light and someone revving the engine I cannot get the test light to kick on.
ANY help is greatly appreciated
-the engine has to run for about 30 secs before you can rev it high enough for mivic to kick in
-make sure your hitting atleast 4000 rpm
-swap the diode around and see if works that way
-are you sure you tapped into the right wire???
Old August 18th, 2013, 09:01 PM   #40 (permalink)
Vehicle: .
600, art, battery, black, car, circuit, color, cover, driver, ecu, engine, i i, indicator, led, light, mivec, mounting, oil, questions, relay, start, switch, video, wire, wiring
How To: Mivec Indicator Light jhun35 Electronics 30 July 12th, 2013 02:24 PM
Fog Indicator Light OrangeCrush Audio & Lighting 4 March 3rd, 2013 07:40 PM
Question: Bright Light indicator - to bright?? dshaff3 2006-2012 Eclipse (General 4G) 30 December 8th, 2012 01:51 PM
MIVEC light ALBOE Tuning and Electronics 9 November 9th, 2009 04:39 PM
MIVEC Light DarkSidEclipse Audio & Lighting 5 September 15th, 2008 01:33 PM
