How To Guide How To Remove And Open Stock Gauge Display - Club4G Forum : Mitsubishi Eclipse 4G Forums - 2006-2012 Eclipse Authority
Old August 22nd, 2013, 12:01 PM   #1 (permalink)
Gamer
cmturner's Avatar
this is a How to, for removing and opening your stock gauge display
I rate this a 3 or 4 out of 10, 10 is hardest
I opened mine to add a LED in the gauge pod.
this is the finished product!!
Removing the Gauge Display
First start by lowering the steering column as low as it will go, then lock it into place.
you will see this rubber piece right below the gauges,
Lift it up on each corner and there is a Philips head screw on each corner, and remove them!!!
now pull on the gauge display till it pops out, and there is a connector on the back, disconnect it, then bring it inside to open up.
Opening the Gauge Display
Once you have it inside, make sure your counter/workspace is clean since you will have a open circuit board laying out!!!
Too start out, first behind the rubber piece that's on the bottom of the gauges, there are 3 little circle things.
holding the rubber piece on, remove these with a mini flat head screw driver (be careful because they will fly off.)
then set them too the side
next flip the gauge pod over, and there are 3 screws, one top, and one on each side.
remove the 3 screws, and then set to the side.
Now that the 3 screws are removed, there are little bitty white clips on the back, and on the side.
push these in, and pull the cluster out of the case.
now you will remove the face plate, from the cluster.
now to remove the clear plastic piece and black piece from the circuit board, you will press these in same as the last step,
but be very careful when separating these, with the mileage reset button.
now to remove the clear plastic piece from the black piece, press these in and then separate.
and now you should be here for what ever projects you want to do!!!
for me I installed a LED, where the shift Icon is for automatics, for us manuals, its just blank.
Installing LED
first mark the whole where you want it
then drill and place the LED in the spot, I used a dab of super glue on the back to make sure it stays in place
and now you are ready to place it all back together,
this is where I ran the wire threw this little cubby hole
and then ran the wire threw this hole out the back
my LED is used for when my addition fan kicks on, it will light up that LED,
the fan is on a adjustable thermostat, set to 210+F so basicly as a fell safe for overheating.
comments appreciated!!!
and mods can you move to right section please
http://club4g.org/board/members-ride...ners-ride.html
Old August 22nd, 2013, 12:04 PM   #2 (permalink)
Silver Behemoth
Vehicle: 2007 Eclipse GT Spyder
Masyn is on a distinguished road
Good read man. I may try something like that soon.
Masyn is offline   Reply With Quote Quick reply to this message
Old August 22nd, 2013, 12:07 PM   #3 (permalink)
Gamer
cmturner's Avatar
thank ya, and it was real easy to do
Old August 22nd, 2013, 02:25 PM   #4 (permalink)
ryguy's Avatar
Vehicle: 06Eclipse Gs
ryguy is a name known to allryguy is a name known to allryguy is a name known to allryguy is a name known to allryguy is a name known to allryguy is a name known to all
nice one cmtuner!
Good work!
( do you have digital temp readout?)
ryguy is offline   Reply With Quote Quick reply to this message
Old August 22nd, 2013, 02:30 PM   #5 (permalink)
Gamer
cmturner's Avatar
Originally Posted by ryguy View Post
nice one cmtuner!
Good work!
If you mean the temp gauge on the radio display pod, then yes I do
Old August 22nd, 2013, 02:43 PM   #6 (permalink)
ryguy's Avatar
sorry, no, I thought you were talking about something else overheating.
Now I see you mean the car overheating....
(dont we have a temp light? that does the same thing?)
I ment a digital temp readout on whatever your trying to cool.
I thought you had this hooked to your amplifiers, so when they got hot, and their fans kicked on, the light would come on, telling you their cooling.
my bad.
thanks for the idea though.
Old August 22nd, 2013, 02:50 PM   #7 (permalink)
Gamer
cmturner's Avatar
No there are no stock lights for if the car over heats :-\
That's why I installed the fan, and the LED,
Don't want a repeat of April lol
Old August 22nd, 2013, 03:01 PM   #8 (permalink)
ryguy's Avatar
o, I did not know that.
great job then! Smart thinking!
Old August 22nd, 2013, 03:04 PM   #9 (permalink)
Gamer
cmturner's Avatar
Thank ya, I found out the hard way there wasn't a light lol
art, back, black, board, button, clips, display, flat, gauge, head, how to, led, light, lock, lowering, plate, red, remove, rubber, screw, stock, super, top, white, wire
Remove stock sub in 07 Spyder GT DeToni12 Audio & Lighting 14 July 21st, 2012 10:55 PM
Wtb gauge holder as seen on the ralliart eclipse concept for clock display area mpguy24 Automotive For Sale/Wanted 25 February 18th, 2012 07:03 PM
Aftermarket heads and stock clock/display? Chronos Audio & Lighting 5 March 4th, 2011 01:32 AM
Stock Center Display/Serius Radio TelecasterBlues Audio & Lighting 1 September 25th, 2009 06:00 PM
how hard is it to open the stock air box? tjf 2006-2012 Eclipse (General 4G) 12 February 19th, 2008 01:53 AM
