How To Guide Order Pistons - What you need to know - Club4G Forum : Mitsubishi Eclipse 4G Forums - 2006-2012 Eclipse Authority
Old February 28th, 2014, 12:32 PM   #1 (permalink)
Contributing Member!
trevroar's Avatar
Vehicle: 07 Spyder GS6; AP1 s2000
trevroar is a splendid one to beholdtrevroar is a splendid one to beholdtrevroar is a splendid one to beholdtrevroar is a splendid one to beholdtrevroar is a splendid one to beholdtrevroar is a splendid one to behold
For anyone else ordering pistons, here's the data I provided Ross Pistons on my order. I also put an order in for a head gasket set from Cometic.
Cometic Head Gasket Specs
Phone # (800)752-9850
Their Engine Code on file: 4G6G75
Part# H34551040S (can adjust for any overbore size)
Head Gasket Bore: 96mm (OEM stock)
Thickness: .040" (Can do any thickness upon request)
Cost: $98.24 each
Ross Pistons
Phone# 310-536-0100
Job Card #: 127619
Cylinder bore: 95mm (OEM stock)
Piston Stroke: 90mm
Oil Ring Support (ORS):ORS-378
Combustion Volume: Pentroof
Head CC's: 65cc
Piston Pin Diameter: 22mm
Block Height: 228mm
Cylinder Head Height:120mm
Rod Lengths: 6.040"
Cost Break Down
Pistons 83-20: $112.96 each
Pins 866-02-250: $11.95 each
ORS: $7.68 each
Rings Custom-CS-06: $179.60 Set
Slipper Skirt forgings and forged side reliefs at no additional cost (upon request only)
Total Price w/o Shipping $975.12
FSM Info for 6G75
Valve Info
Intake:
Over all length -4.304"
Head diameter -1.437"
6mm valve stem
Exhaust:
Over all length -4.470"
Head diameter -1.260"
6mm valve stem
First Ever Documented GS V6 Swap Completed: <-- Click me!
Who's selling their 4G next
Boosted V6 Swap, Ross Pistons 9:1 compression, H-beam Forged Rods, Comp Cams Valve Springs, Ripp Mods SDS Vortech V5G Stage II @ 8psi.
trevroar is offline   Reply With Quote Quick reply to this message
Old February 28th, 2014, 12:35 PM   #2 (permalink)
Mr. Offensive
Phantom_4G's Avatar
1 Highscore
Vehicle: 2006/Eclipse/GT
Phantom_4G has a brilliant futurePhantom_4G has a brilliant futurePhantom_4G has a brilliant futurePhantom_4G has a brilliant futurePhantom_4G has a brilliant futurePhantom_4G has a brilliant futurePhantom_4G has a brilliant futurePhantom_4G has a brilliant futurePhantom_4G has a brilliant futurePhantom_4G has a brilliant futurePhantom_4G has a brilliant future
Awesome idea. repped!
Follow the official Club4G Instagram at @club4g
Phantom_4G is offline   Reply With Quote Quick reply to this message
Old February 28th, 2014, 12:41 PM   #3 (permalink)
resident crossplatformer
fox_brand's Avatar
Vehicle: 1999 Galant
fox_brand is a jewel in the roughfox_brand is a jewel in the rough
stock head CC is 65 cc's
from the valve face surface to the deck surface, the angle is 25 degrees for both the intake and exhaust, the angle from the valve stem to the deck surface is 65 degrees, in other words, from the valve stem to the cylinder head's centerline (veiwing from the top of the cylinder head) is 25 degrees, just specify that your heads use pent house roof combustion chambers
fox_brand is offline   Reply With Quote Quick reply to this message
Old February 28th, 2014, 01:55 PM   #4 (permalink)
trevroar's Avatar
Thanks fellas! Much appreciated. I'll make sure I put something comprehensive up in the first post once all is said and done.
Old February 28th, 2014, 04:00 PM   #5 (permalink)
trevroar's Avatar
Just got off the phone with Mike again... we filled in a few more blanks on ordering the pistons. I still need to provide him with head gasket information. Does anyone know the specs off hand for an OEM gasket from the dealer. Need to know the thickness, and diameter for cylinders.
Old February 28th, 2014, 09:54 PM   #6 (permalink)
fox_brand's Avatar
the stock head gasket bore diameter is ~96.32 mm (measurements are done with digital calipers, not a bore gauge), thickness is roughly 0.38 mm (also done by digital calipers)
Old February 28th, 2014, 10:04 PM   #7 (permalink)
fox_brand's Avatar
pin diameter is 0.866 inches/22 mm, go by the dimension given by whoever makes your connecting rods, you also don't need to use oil ring support rail if you are going naturally aspirated/low levels of nitrous (thinner crown), my CP's are like this
anybody know the exact diameters of the intake and exhaust valves?
also worth noting, you can get these pistons with slipper skirt forgings and forged side reliefs at no additional cost
Old March 3rd, 2014, 09:53 AM   #8 (permalink)
trevroar's Avatar
Thanks for the info Fox! I'll be boosting between 8-12lbs... so do you feel that the ORS are necessary?
Old March 3rd, 2014, 12:48 PM   #9 (permalink)
trevroar's Avatar
Fox, when I told Mike the thickness of the headgasket, he was concerned that it was very thin.... Not to doubt you, but only to double check.... are we sure about the .38mm thickness?
This pic is promising... but still want to make sure
Old March 3rd, 2014, 02:14 PM   #10 (permalink)
trevroar's Avatar
Nevermind... just went with Cometic Headgasket
Old March 4th, 2014, 01:40 AM   #11 (permalink)
fox_brand's Avatar
you should talk to Ross about this, it might be over kill, then again, over kill implies that it is working, the general theory of forced induction (and nitrous oxide) versus naturally aspirated, through my reading, N/A, you want to top ring land as close to the crown without compromising strength as possible to increase sealing, efficiency, and cutting down on dead space between the crown and the top ring land. With forced induction (and nitrous oxide), it is more of increasing strength of the crown
Old March 4th, 2014, 01:41 AM   #12 (permalink)
fox_brand's Avatar
yeah, that picture is more or less what I'm going off of
Old March 4th, 2014, 09:06 AM   #13 (permalink)
trevroar's Avatar
Mike at Ross Pistons says use them for FI, so they're included in the order... they aren't overly expensive anyways.
back, custom, gasket, i need help, life, lowering, need help, oil, phone, pistons, ross, stock, stock bore, support
best part order? ginajean Member's Rides 1 October 16th, 2013 08:24 AM
About to order this Kidtkd73 4G Eclipse GS/SE Specific 4 July 26th, 2011 03:46 PM
Placed the order doctorres112 Wheels, Tires, Brakes and Suspension 4 May 30th, 2009 02:18 AM
How to money order (??) AceIsFromJapan The Lounge 5 March 3rd, 2009 11:28 AM
About to order my SE Wing.. LPfenix182 2006-2012 Eclipse (General 4G) 8 August 21st, 2008 11:26 PM
