How to: B&M Trans Filter ATX - Club4G Forum : Mitsubishi Eclipse 4G Forums - 2006-2012 Eclipse Authority
Old May 26th, 2014, 11:07 PM   #1 (permalink)
Not Quite OG
fellowsdrake's Avatar
Vehicle: 07 Eclipse GT
fellowsdrake is a jewel in the roughfellowsdrake is a jewel in the rough
Post How to: B&M Trans Filter ATX
mitsubishi thought that a LIFETIME Filter was a good idea. Oh and if you ever WANTED to change it, you'd have to rip apart the entire transaxle
So here we go with the parts list.
P/N Nomenclature Price link for reference
MMOC-F Mishimoto Trans Cooler $146 http://www.summitracing.com/parts/mio-mmoc-f/overview/
80277 B&M Transmission Filter $35 http://www.summitracing.com/parts/bmm-80277
01320 Royal Purple MAX ATF $12 Max ATF | Synthetic Automatic Transmission Fluid | Royal Purple
ROY30-8A Royal Purple Filter $12 http://www.summitracing.com/parts/chc-30-8a
15721 Derale Thermo Switch $25 http://www.summitracing.com/parts/der-15721
(the links are for quick reference, pricing is based off of amazon) Total investment required for an actual lifetime fluid filtering system? About 300 Bones. But if you dont intend to autocross or hotlap the tranny at a road course or dragstrip, its only 150. Go with a cheaper fluid other than Royal Purple, could probably do it for $75 bucks. But this is top of the line materials.
[size=18pt]PHASE 1: ROYAL PURPLE W/ B&M FILTER[/size]
Principle of Operation.
Install filter kit intercepting the cooler to trans line. If you understand this concept, the following pictures should tell the rest of the story. Super easy install for me. I hope to see other ATX guys rocking my same setup.
For this task you need the kit and oil listed above.. And in addition:
(1) 10 x 1.5 bolt.
(1) Washer
(1) 3/8" Barbed Coupler
(3) Worm Gear Clamps
(2) 3' lengths of 5/16" fuel hose
PHOTO TIME!!!
AEM CAI, Tanabe G Medallion Muffler, OBX LTH's, Solid Mounts, AIT Carbon Spoiler, Tien H Techs, Tanabe Underbrace, Projectors w/ eyelids, AEM FICDetailingBliss
Originally Posted by Phantom_4G View Post
Cheap, fast, reliable. You only get to choose 2..
fellowsdrake is offline   Reply With Quote Quick reply to this message
Old May 27th, 2014, 09:28 AM   #2 (permalink)
No Worries
tcsoccer09's Avatar
Vehicle: 2009 Eclipse GS Auto
Great write up man! +rep
Old May 28th, 2014, 06:23 AM   #3 (permalink)
Spyder4g's Avatar
Vehicle: 2009 eclipse gs spyder
Spyder4g will become famous soon enough
In theory couldn't you just run the hose from the radiator trans cooler to the filter, instead of buying a completely separate one? Then go back to the trans.
Spyder4g is offline   Reply With Quote Quick reply to this message
Old June 5th, 2014, 07:29 AM   #4 (permalink)
Not Quite OG
Yes, except that this mishimoto one is bigger (more cooling) and I just like throwing parts at my car.
When I was on buttonwillow, as I ran my laps, the shifting got more and more LAZY and sloppy due to heat. for around town and drag racing, I'm sure the factory cooler is fine, but for roadracing or autocross, hells no.
Old June 5th, 2014, 04:37 PM   #5 (permalink)
Vehicle: 2008 Spyder GT
RaucousSounds is on a distinguished road
Hey man,
I agree the transmission gets super sloppy and laggy when it heats up. I can tell after a half hour of highway driving. In addition to that, when you let the transmission cool for some time, it becomes quick and responsive again.
My question is, is the ATF fluid under pressure or anything? And how much stays in the stock cooler when you remove it? Looking to add my own cooler in the next month or so.
RaucousSounds is offline   Reply With Quote Quick reply to this message
Old June 16th, 2014, 05:16 PM   #6 (permalink)
Not Quite OG
Outside of the transmission itself no it is not PRESSURIZED, it has FLOW yes, but no pressure. What do you mean remove the stock cooler? I'm still rocking the factory cooler ATM. If you drop the factory cooler and add in the mishimoto one, you would just guesstimate, drive around, recheck, and add / remove as necessary.
Old June 16th, 2014, 05:19 PM   #7 (permalink)
Not Quite OG
I just reread this and it doesnt make any sense to me. There are a total of 4 lines for the transmission. 2 are for trans fluid to and from cooler. And 2 are coolant lines to and from radiator.
Old June 16th, 2014, 06:48 PM   #8 (permalink)
Vehicle: 09 4G69
FeaRlezZ is a name known to allFeaRlezZ is a name known to allFeaRlezZ is a name known to allFeaRlezZ is a name known to allFeaRlezZ is a name known to all
they also sell inline trans filters which is 10x quicker and easier and they are recommended to be changed every 30k miles. plus they are like $20. they are just as efficient and come in multiple sizes to accommodate multiple applications. just split the return line and clamp each end onto the ends of the filter. positive flow is labeled on the filter. do not put it backwards
Magnefine Inline Transmission Power Steering Filters
Eagle + Manly fully built 4G69 8.5:1 87.5 106mm stroker _ RPW stage 1 camshaft _ Full custom Borla Exhaust _ Tuned _ AEM gauge pod
FeaRlezZ is offline   Reply With Quote Quick reply to this message
Old June 16th, 2014, 08:53 PM   #9 (permalink)
Spyder4g's Avatar
Yes. The two that are for the trans make the trans cooler. That's how the radiator works. So I was just wondering couldn't you splice one of the lines and run it that way. I think it would do the same but I could be wrong.
Old June 20th, 2014, 04:48 PM   #10 (permalink)
Not Quite OG
Dog I am sorry I am soo lost... If you could draw me a picture er something maybe I'd get it.
As for you fearlezz... woulda been nice to know on the nation about this. I wouldn't have spent the $40 I did for my setup. I had this up on the nation long before I actually did the install.
automatic, how to, kit, setup, synthetic, tranny, trans, transmission
Project: universal trans filter fellowsdrake 2006-2012 Eclipse (General 4G) 0 June 6th, 2013 06:13 AM
Difference between regular K&N oil filter and 'Racing' filter? HomesickAlien Eclipse Performance 2 June 30th, 2011 04:01 PM
k&n filter eclipse628 Eclipse Performance 1 May 25th, 2010 12:45 AM
Engine Coolant & Trans Fluid Flush EclipseReloaded 4G Eclipse GT/SE Specific 14 June 26th, 2009 12:05 AM
Texas Galant/Eclipse Tri-city Cruise & Meet ATX 4/11-12/09 g-spot Texas 28 March 16th, 2009 01:35 PM
