Ticking noise around intake manifold - Club4G Forum : Mitsubishi Eclipse 4G Forums - 2006-2012 Eclipse Authority
Old September 24th, 2015, 01:13 AM   #1 (permalink)
KIKO
kikohg15 is on a distinguished road
My '06 GT started this weird ticking noise right around the intake manifold area. I noticed the oil level was extremely low a couple days ago and I've always used Valvoline Synthetic or Mobil 1 Synthetic. It's at 146,000 miles right now. I used to drive it all the time but lately I use it about twice a week. Anyone know what it could be?
kikohg15 is offline   Reply With Quote Quick reply to this message
Old September 24th, 2015, 02:08 PM   #2 (permalink)
eosrebel's Avatar
Vehicle: 2009 Eclipse GS
eosrebel has a spectacular aura about
How low was your oil level?
eosrebel is offline   Reply With Quote Quick reply to this message
Old September 24th, 2015, 03:11 PM   #3 (permalink)
KIKO
It was 2-3 quarts lower than it should
Old September 25th, 2015, 08:01 AM   #4 (permalink)
Was it 2 quarts, or 3 quarts low, this engine only only holds 4.5 quarts including the oil filter. Driving with 2.5 quarts of oil is one thing, driving with 1.5 quarts of oil is another!! Either way around... Do a complete oil change, driving that low on oil will consume the properties of the oil, so basically even if you did add oil, you are still driving with burnt-out oil in the engine. Burnt oil can/will damage you engine quickly!!
When the engine is running the crank splashes oil to lubricate the lower part of the engine, this includes the cylinder walls, without oil on the cylinder wall you can score the walls of the cylinders and piston rings. Bad Ju-Ju!! You never got an oil light?? On your dip stick you have two lines, top line indicates you engine oil is full, the second lower line indicates you are one quart low, if no oil is on your dip stick you are 1 1/2 quarts of oil low, or more. Your engine oil light should come on before you are lower than 1 1/2 quarts low.
Are you burning oil from your exhaust, or do you have an oil leak? Check your spark plug holes for oil, or do you have other visible oil leaks on the engine or the ground?
Old September 25th, 2015, 10:48 AM   #5 (permalink)
eosrebel's Avatar
One or more of the lifters may be stuck as well as they are run off oil pressure on our cars as well.
Old September 25th, 2015, 10:42 PM   #6 (permalink)
KIKO
So yeah I think it was running it with burning oil. I notice it's not burning it anymore but yeah I will do an oil change hopefully tomorrow. I check for leaks but I didn't find any. I also noticed that when I'm easy on the throttle the car seems to be running like a brand new car. But the moment I go above 4500 rpms the car has trouble breathing in air. Hopefully it all goes away with the oil change. I'll keep you guys posted. Thanks so much for your help
Old September 29th, 2015, 09:12 AM   #7 (permalink)
I don't know if you did your oil change yet... Marval Mystery Oil works wonders for stuck valves and rings, just add it before your oil change, it will also clean out any sludge build-up. You can also add it to your fuel tank to clean the fuel system, lubricate your fuel pump, clean fuel lines and injectors, will also lubricate your top end, clean valves, and piston heads. You can buy it at any auto parts store.
Marvel Mystery Oil:
::Marvel Mystery Oil::
Old September 29th, 2015, 10:49 AM   #8 (permalink)
Super Moderator
A little bit of sea foam in the oil before an oil change helps too
06 gt, drive, intake, intake manifold, level, low, manifold, miles, noise, oil, synthetic
Intake manifold spacer in throttle body spacer Mindy07 4G Eclipse GS/SE Specific 6 August 6th, 2015 11:50 AM
WTB: Intake Manifold jelloshotz101 Automotive For Sale/Wanted 5 April 30th, 2015 09:03 PM
FS: FS NY: 2007 GT Upper and Lower Intake Manifold trevroar Automotive For Sale/Wanted 2 April 15th, 2015 10:09 AM
FS/WTT: Fully ported and polished heads, upper intake manifold msoto Automotive For Sale/Wanted 21 January 26th, 2015 08:11 PM
FS: 4G69 Jet Coated Intake Manifold FeaRlezZ Automotive For Sale/Wanted 33 November 11th, 2014 06:48 PM
