Go Back   Club4G Forum : Mitsubishi Eclipse 4G Forums - 2006-2012 Eclipse Authority > Marketplace > Parts Directory > Drivetrain Parts
Drivetrain Parts Flywheels, clutches, torque converters, differentials and other drive train components.
Old February 17th, 2007, 09:43 PM   #1 (permalink)
Three Diamonds
Russ's Avatar
Tournaments Won: 4
Name: Russ Sanderlin
Clutchmasters Clutch (Stage 1,2,3,4) 6G75 3.8L 6spd
All Clutch Masters systems come complete with:
Pressure Plate
Clutch Disc
Throw-out Bearing (when applicable)
Pilot Bearing or Bushing (when applicable)
Alignment Tool
FX100 Stage 1:
High performance street system
Holding capacity 70% over stock
Heavy-Duty reinforced pressure plate
Hi-Leverage pressure ring design
Sprung hub/cushioned disc
Steel backed organic friction material
FX200 Stage 2:
Extra long life street system
Steel backed Carbon Kevlar friction material
FX300 Stage 3:
Heavy-duty street & racing system
Holding capacity 110% over stock
Hi-Leverage™ pressure ring design
Steel backed Segmented Carbon/Kevlar
FX400 Stage 4:
Ultra heavy-duty street &racing system
Holding capacity 170% over stock
Sprung hub/4-button Ceramic friction material
SFI approved on most race applications
Russ is offline   Reply With Quote
Old February 18th, 2007, 11:48 AM   #2 (permalink)
What Drives You?
Slippercream's Avatar
Hey Russ... care to explain the differences between the "trims"? I've had the SPEC Stage III (6-puck) on the 3G and really have not had any issues with it (as opposed to some who say it's too much for the 3G tranny).
For people building up for FI, why should one choose to go with, say, the CM-FX300 vs. the FX400-6 puck?
I'm guessing the 4-puck will be way too harsh for my taste. The 4G is, after all, my daily driver.
Slippercream is offline   Reply With Quote
Old February 18th, 2007, 01:17 PM   #3 (permalink)
Three Diamonds
Russ's Avatar
Tournaments Won: 4
It's pretty self explanatory the differences above.
I've always recommended that you stick with a disc clutch as much as you can until you absolutely have to upgrade to a 6 puck clutch which has a much harsher engagement.
Old February 18th, 2007, 01:42 PM   #4 (permalink)
What Drives You?
Well, I've grown accustomed to the 6-puck. I really never considered it much different from stock. A lot of people like to finick about how harsh this one thing is, or how noisy the car becomes, but I never really found anything wrong with the 6-puck setup. In fact, I've grown to like how you need very little clutch pedal engagement to get some grip (a major problem for those without a short shifter )
Then again, I really do drive like a grandpa until I get pissed at someone on the road.
Old February 20th, 2007, 02:54 AM   #5 (permalink)
NotUrAvg4G's Avatar
NotUrAvg4G has a reputation beyond reputeNotUrAvg4G has a reputation beyond reputeNotUrAvg4G has a reputation beyond reputeNotUrAvg4G has a reputation beyond reputeNotUrAvg4G has a reputation beyond reputeNotUrAvg4G has a reputation beyond reputeNotUrAvg4G has a reputation beyond reputeNotUrAvg4G has a reputation beyond reputeNotUrAvg4G has a reputation beyond reputeNotUrAvg4G has a reputation beyond reputeNotUrAvg4G has a reputation beyond repute
i need to switch the clutch so i guess i should change the flywheel at the same time huh?
NotUrAvg4G is offline   Reply With Quote
Old February 20th, 2007, 06:43 AM   #6 (permalink)
Three Diamonds
Russ's Avatar
Tournaments Won: 4
While you are in there, it is a good idea to free up some of that rotational mass on the rotating assembly of the engine
Old February 20th, 2007, 11:01 AM   #7 (permalink)
NotUrAvg4G's Avatar
then i guess i know where someof my tax return dollars are going
Old March 2nd, 2007, 01:44 PM   #8 (permalink)
EuroClipse
Vehicle: 2006 GT/6spd. Titanium
doctorres112 is a jewel in the roughdoctorres112 is a jewel in the rough
so if i am only going to go as far as headers for my car, should i stay with the stock clutch until it starts to go out or should i look into purchasing a stage 1? i already have a CAI and cat back on board
doctorres112 is offline   Reply With Quote
Old March 2nd, 2007, 02:18 PM   #9 (permalink)
"Yayo"
Kilzod's Avatar
Vehicle: 2003 Eclipse GTS
Kilzod has a reputation beyond reputeKilzod has a reputation beyond reputeKilzod has a reputation beyond reputeKilzod has a reputation beyond reputeKilzod has a reputation beyond reputeKilzod has a reputation beyond reputeKilzod has a reputation beyond reputeKilzod has a reputation beyond reputeKilzod has a reputation beyond reputeKilzod has a reputation beyond reputeKilzod has a reputation beyond repute
You could probably wait until the stock one starts going. You're not adding a crazy amount of HP that you would need anything higher than stage 1 or 2.
Kilzod is offline   Reply With Quote
Old March 2nd, 2007, 07:50 PM   #10 (permalink)
What Drives You?
Like Russ said, it's probably a good idea to do all at once. You don't want to pay the killer labor costs associated with shop transmission work thrice anyway, and generally speaking, unless you really rag on your car, you'll only have to have transmission work done on your car once. If I may say so, I've never had to replace a clutch twice (first being the upgrade), on any car I've ever owned.
But for those who really want to see the most benefit off the transmission, stock or FI alike, I'd consider putting an LSD in - and THAT takes the most "work". This of course depends on the skill of your transmission guy. Why bother taking the transmission down 2 or 3 times when you can live off of the stock clutch for the meantime and save up for all 3 - LSD, clutch/pp, and flywheel - and install at once.
... That is, if you're really concerned about performance.
Old May 11th, 2007, 03:38 PM   #11 (permalink)
JSRIDE's Avatar
Vehicle: 2006 eclipse gt
JSRIDE is on a distinguished road
clutch and flywheel
I just had an fx400 clutch and fidanza flywheel put in my gt and what a differance it made in acceleration and performance. I can't wait to have it put back on the dyno and see what kinda numbers it will put out. I am very satisfied with it and would reccomend it to any one.
JSRIDE is offline   Reply With Quote
Old December 10th, 2007, 07:21 AM   #12 (permalink)
Diss-member
Leeclipse's Avatar
Leeclipse has a spectacular aura about
I would replace the fly/clutch as soon as your able to. Here's why, most people are only going to keep the car for about 3-4 years. Why wait until your current clutch goes bad before you start enjoying the benefits of a performance set up.
If it was just changing to a new clutch of the same type I would say wait but the difference in the clutch and lighter flywheel will be very noticable and need to be enjoyed for a longer period of time...
AEM CAI, Tanabe exhaust, Progress Swaybar, Works Shift knob, Toyo Proxes4, DEI Heat shield, Throttle body bypass, Mobile 1 oil, Redline MTL gear lube, Rippmod Brat, Apexi super ground system, custom Alpine/Crossfire sound system, Ingalls ETD, Tork Matrix 18" lightweight wheels and race lugs.
Leeclipse is offline   Reply With Quote
Old December 10th, 2007, 03:23 PM   #13 (permalink)
What Drives You?
sah true... sah true
Only thing I'll add to that is if you're doing anything transmission you might want to think about doing it ALL at once: clutch/flywheel/LSD. Especially in the case of the clutch and flywheel, anytime a new clutch is dropped and the old flywheel is retained, you will have to have the piece machined, which means more downtime and cost. And in the case of the differential, you have the bell housing off the car anyway, so why not do it all in one fell sweep?
While you're at it, get some good tranny oil, like Redline M/T or BG Synchroshift ... do people still use the Earl Grey.... err... Scott Grey mix?
Old December 10th, 2007, 04:02 PM   #14 (permalink)
Diss-member
Leeclipse's Avatar
I likey me some Redline MT
Old June 8th, 2008, 03:36 AM   #15 (permalink)
All Show and GO
HAHA NO's Avatar
Name: Matt Landrigan
Vehicle: 07 Eclipse MR
i just put in my stage 2 cause my realease bearing went again so while they had it off i bought the stage 2 so for so good. Just breaking it in right now.
Old June 26th, 2008, 09:52 PM   #16 (permalink)
Vehicle: 2006 Eclipse GS
jbv87 is on a distinguished road
i have a 06 gs what type of clutch can i put in my car...
jbv87 is offline   Reply With Quote
Old June 27th, 2008, 12:51 AM   #17 (permalink)
All Show and GO
HAHA NO's Avatar
well i know fidanza and cltch masters make them for our cars. I also heard that bully has a setup for it but ive yet to find it but here is cltch masters for your car.
Clutch Masters- Your High Performance Specialists
Old June 28th, 2008, 11:38 PM   #18 (permalink)
o ok thax
Old June 30th, 2008, 06:53 PM   #19 (permalink)
All Show and GO
HAHA NO's Avatar
o ok thax
no prob
Old October 26th, 2008, 09:00 PM   #20 (permalink)
a=dv/dt
Mattman's Avatar
Vehicle: 2008 ECLIPSE GS
Mattman has a reputation beyond reputeMattman has a reputation beyond reputeMattman has a reputation beyond reputeMattman has a reputation beyond reputeMattman has a reputation beyond reputeMattman has a reputation beyond reputeMattman has a reputation beyond reputeMattman has a reputation beyond reputeMattman has a reputation beyond reputeMattman has a reputation beyond reputeMattman has a reputation beyond repute
hey slip, i didnt really catch i concrete answer to the question you asked. I believe it was what to choose for those building up to FI. i dont see myself self spending the 1600 for stage 5 and above. but stage 4 is no problem, which one will be best for me? and this comes with the lightweight flywheel, from my understanding. so thats 2 birds. now what exactly is pp and LSD, in reference to cars . im not familiar with these terms.
I would like to buy everything needed in this category, building up to FI, and pay one labor fee.
sorry for my ignorance and not catching what was probably answered. thanks for the help.
Selling E4E rear and sides, will need to be refinished and repainted. Pm me
Mattman is offline   Reply With Quote
Old December 11th, 2010, 04:13 PM   #21 (permalink)
Vehicle: 2007/Eclipse/GT
Clessy has a spectacular aura about
LSD is amazing. Limited Slip Differiantial. Once you've had a car with it you'll hate every car without it.
My question I have is can I use a clutch master stage 1 clutch with the oem flywheel. Im really hurting for money and this seems like the only real choice I have.
test
Clessy is offline   Reply With Quote
3.8l, 6g75, bearing, bushing, button, carbon, clutch, life, long, performance, plate, race, racing, shop, stage 1, street
