Go Back   Club4G Forum : Mitsubishi Eclipse 4G Forums - 2006-2012 Eclipse Authority > Marketplace > Parts Directory > Drivetrain Parts
Drivetrain Parts Flywheels, clutches, torque converters, differentials and other drive train components.
Old February 17th, 2007, 09:45 PM   #1 (permalink)
Three Diamonds
Russ's Avatar
Tournaments Won: 4
Name: Russ Sanderlin
Quaife ATB Differential
The Quaife Differential powers both drive wheels under nearly all conditions, instead of just one. With an ordinary open differential, standard on most cars, a lot of precious power is wasted during wheelspin under acceleration. This happens because the open differential shifts power to the wheel with less grip (along the path of least resistance). The Quaife, however, does just the opposite. It senses which wheel has the better grip, and biases the power to that wheel. It does this smoothly and constantly, and without ever completely removing power from the other wheel
In drag-race style, straight-line acceleration runs, this results in a close to ideal 50/50 power split to both drive wheels, resulting in essentially twice the grip of an ordinary differential (they don't call open diffs "peglegs" for nothing).
In cornering, while accelerating out of a turn, the Quaife biases power to the outside wheel, reducing inside-wheel spin. This allows the driver to begin accelerating earlier, exiting the corner at a higher speed.
The Quaife also controls loss of traction when the front wheels are on slippery surfaces such as ice and snow or mud, providing the appropriate biased traction needed to overcome these adverse conditions. The Quaife Differential provides constant and infinitely variable drive. Power is transferred automatically without the use of normal friction pads or plates seen in other limited-slip designs.
The Quaife's unique design offers maximum traction, improves handling and steering, and puts the power where it is needed most. A definite advantage whether on the track or on the street.
The Quaife is extremely strong and durable and since the Quaife is gear operated, it has no plates or clutches that can wear out and need costly replacement.
The Quaife is great for street driving or racing. Racers don't have to put up with locking mechanisms or spools that created unwanted understeer under power, or in the case of front-drive cars, even tear the steering wheel out of their hands when cornering. Because it behaves like an open differential during ordinary driving, street drivers will have trouble telling it's there until pushing the car's limits.
The Quaife has been proven in everything from SCCA Rally to Formula 1. It provides autocrossers with such an advantage, it has become "required" equipment for a winning effort.
More and more auto manufacturers are specifying the Quaife ATB Differential as original equipment in their high performance models - for good reason - it works!
The Quaife ATB Differential comes with something else other's don't have:
a Limited Lifetime Warranty. This warranty applies even when raced!
Available through the following vendors
V6 6G75 3.8L:
Tearstone Performance
I4 4G69 2.4L:
Russ is online now   Reply With Quote
Old February 18th, 2007, 11:45 AM   #2 (permalink)
What Drives You?
Slippercream's Avatar
I'll have to vouch for this being perhaps the best kind of transmission upgrade you can get. Especially if you're planning for massive HP upgrades (FI, N/A engine build), a Quaife diff does more than just provide a more beefed up differential. I have this upgrade on the 3G, and am lined up to get this on the 4G soon.
If you put the car up on a lift, an attempt to turn one tire will cause the other to turn as well. That's how you know the axles are "locked", as opposed to the open diff setup provided by the OE differential. When you take the corners, however, power is distributed proportinally among both wheels, depending on how much traction each wheel is getting. Every bit of HP is utilized as efficiently, while reducing unnecessary spin on either wheel (commonly referred to as wheel slip / loss of traction on turns).
That, paired with Quaife's lifetime warranty, makes this perhaps the best bang-for-the-buck upgrade you can ever get for your transmission. ...Not that I've had the Quaife fail on me yet
Slippercream is offline   Reply With Quote
Old February 22nd, 2007, 11:09 PM   #3 (permalink)
What Drives You?
Niiice That'll definitely be a good (partial) solution to your tq steer
Old March 10th, 2007, 10:01 AM   #4 (permalink)
Three Diamonds
Russ's Avatar
Tournaments Won: 4
According to Quaife, we sold the first customer Quaife this past week to Manny with the GT here in Orlando. Very exciting!
Old June 29th, 2007, 04:30 AM   #5 (permalink)
4G NOVICE
mbunds's Avatar
Vehicle: 2006 GT
mbunds has a spectacular aura about
Could an advanced do-it-yourselfer install this, or is a transmission shop recommended?
mbunds is offline   Reply With Quote
Old June 29th, 2007, 06:54 AM   #6 (permalink)
Three Diamonds
Russ's Avatar
Tournaments Won: 4
Well, here is the install on a 3G, and you can get an idea what is involved: HOW TO: Quaife LSD install instructions (pics included)
Russ Sanderlin
Questions? Please email me at rsanderlin@tearstone.com
2006+ Factory Service Manual
Old December 30th, 2007, 10:14 PM   #7 (permalink)
superspider's Avatar
Vehicle: 2007/spyder/GT
superspider is on a distinguished road
i heard the quaife differential is not made for Auto transmission. My question is will it ever be made for the Auto?
superspider is offline   Reply With Quote
Old December 30th, 2007, 10:20 PM   #8 (permalink)
"Yayo"
Kilzod's Avatar
Vehicle: 2003 Eclipse GTS
Kilzod has a reputation beyond reputeKilzod has a reputation beyond reputeKilzod has a reputation beyond reputeKilzod has a reputation beyond reputeKilzod has a reputation beyond reputeKilzod has a reputation beyond reputeKilzod has a reputation beyond reputeKilzod has a reputation beyond reputeKilzod has a reputation beyond reputeKilzod has a reputation beyond reputeKilzod has a reputation beyond repute
IIRC they are developing one, but unless there is demand for them, I doubt they'll produce them soon.
Kilzod is offline   Reply With Quote
Old December 30th, 2007, 10:29 PM   #9 (permalink)
Vehicle: 1989 2.0 Mirage Turbo
Mike W is a jewel in the roughMike W is a jewel in the rough
There is no devolopment yet and no future plans for the GT Auto tranny Quaife. Sales of the GT 6 speed are pretty dismal compared to other diffs that they make and potentially can make.
Mike W
Mike W is offline   Reply With Quote
Old December 30th, 2007, 10:46 PM   #10 (permalink)
"Yayo"
Kilzod's Avatar
Thanks for the clarification Mike!
Old December 30th, 2007, 10:58 PM   #11 (permalink)
Sully's Detailing
sullysdetailing's Avatar
Vehicle: 2008 Raider
sullysdetailing is a splendid one to beholdsullysdetailing is a splendid one to beholdsullysdetailing is a splendid one to beholdsullysdetailing is a splendid one to beholdsullysdetailing is a splendid one to beholdsullysdetailing is a splendid one to behold
does that work on the autos?
sullysdetailing is offline   Reply With Quote
Old December 31st, 2007, 12:10 AM   #12 (permalink)
99 problems...
XFactor's Avatar
XFactor has a reputation beyond reputeXFactor has a reputation beyond reputeXFactor has a reputation beyond reputeXFactor has a reputation beyond reputeXFactor has a reputation beyond reputeXFactor has a reputation beyond reputeXFactor has a reputation beyond reputeXFactor has a reputation beyond reputeXFactor has a reputation beyond reputeXFactor has a reputation beyond reputeXFactor has a reputation beyond repute
No, thus the discussion above.
Huge deal breaker for me on ever getting to FI my car, probably wont happen without a diff.
2006 UV Blue Mitsubishi Eclipse GT 3.8L MIVEC v6 ~ I/H/E -- 236.4whp/210wtq on the DD
Originally Posted by horse-eater View Post
welcome to the Dark Side. now go and feast my son... feast on smoked honda until you cannot feast anymore.
Cardomain Rate my ride and i'll rate yours! C4G needs to represent!
Ride Thread
XFactor is offline   Reply With Quote
Old December 31st, 2007, 12:11 AM   #13 (permalink)
Sully's Detailing
Russ does the 3gen gt stall converter work on the 4gen gt ?
Old December 31st, 2007, 12:18 AM   #14 (permalink)
99 problems...
XFactor's Avatar
I'd like to know the answer to that as well... something I need to start looking into.
Ride Thread
Old January 1st, 2008, 06:05 PM   #15 (permalink)
only with quaife differential would my auto Spider have a chance with the 08 Vette, 6.0L, stock 423hp on 1st roll-on
450hp supercharged spider
http://i243.photobucket.com/albums/f.../album2016.jpg
Old January 1st, 2008, 06:31 PM   #16 (permalink)
Sully's Detailing
he got stage 2 4525-450 bhp not WHP
Old October 26th, 2008, 09:04 PM   #17 (permalink)
a=dv/dt
Mattman's Avatar
Vehicle: 2008 ECLIPSE GS
Mattman has a reputation beyond reputeMattman has a reputation beyond reputeMattman has a reputation beyond reputeMattman has a reputation beyond reputeMattman has a reputation beyond reputeMattman has a reputation beyond reputeMattman has a reputation beyond reputeMattman has a reputation beyond reputeMattman has a reputation beyond reputeMattman has a reputation beyond reputeMattman has a reputation beyond repute
what is the speedo gear and bearing add on? what will do this do and should i get it when i make this purchase?
Selling E4E rear and sides, will need to be refinished and repainted. Pm me
Mattman is offline   Reply With Quote
Old October 27th, 2008, 01:06 AM   #18 (permalink)
If you are talking about a GS:
You need bearings for it to turn and mount in place. You need the speedo drive gear if you want the speedometer to work.
The bearings are needed if you dont trust your mechanic to sucessfully take the factory bearings off the original diff and transfer them over to the new diff all in one piece. I can do it but I have done a zillion of them. Safest is to just buy new ones.
The speedo drive gear is cut into the stock diff. If you dont buy it and install it you will not have a working speedometer.
If GT
Your mechanic walks on water he _might_ be able to get the factory bearings off the stock diff. I did one sucessfully once and it took like 2 hours and was not pretty. Buy new ones. He will spend so much time chasing little ball bearings from the shift hubs all over the shop dont make him suffer with those bearings too.
GT does not need a speedo drive gear. The stock speedo drive gear easily transfers over from the stock diff.
Mike W
Old November 7th, 2008, 02:07 PM   #19 (permalink)
infuriated's Avatar
Vehicle: '07 M175U815H1 3CL1P53 GS
infuriated is on a distinguished road
does the 4cyl version (GS) one work on an auto, on their site it does not say it is limited to manuals like it does for the GT one, however it doesn't say that it does work for auto. I am planning a turbo project and and something like this would be essential really.
infuriated is offline   Reply With Quote
Old November 8th, 2008, 06:39 AM   #20 (permalink)
infuriated's Avatar
and incase it is not out, I would definitely recommend releasing one for the GS Auto, as for the increasing amount of turbo projects, this is quite important.. specially as the GS has no traction control.. I know it isn't the same, but the LSD won't only make up for the lack of traction control but it reduces Torque Steer. If I have understood it correctly.
Soon to be installed: T3/T4 50 Trim Hybrid Turbo, Full Tubular Manifold, Forge Blow-Off Valve, 38mm Tial Wastegate with 10psi spring, 1,100 cfm Intercooler, 440cc Subaru WRX Injectors, Greddy Profec B II Boost Controller, Intake/Intercooler/Exhaust Piping, AEM FIC, GT Throttle Body, Outlaw Engineering Throttle Body Spacer, Oil Catch Can, PLX M-300 Tuner Edition Wideband, RRE Underdrive Pulley, RRE Magnaflow Exhaust.
Old June 7th, 2009, 09:52 PM   #21 (permalink)
Dynocologist
Shikaroka is on a distinguished road
Bringing this back from the dead, as I'm in the middle of an install.
The 3G looks (according to that DIY link) to be about 100 times EASIER then a 4G 6-speed.
Shikaroka is offline   Reply With Quote
Old October 27th, 2009, 06:48 PM   #22 (permalink)
Vehicle: 07 Eclipse GT 6speed
skysky will become famous soon enough
how does this affect the traction control and abs systems? the brakes i dont think would be affected s they respond to locking themselves up nd release on their own but what about to traction control, which im prettu sure incorporates the brakes to distribute power? yeah yeah i know you can just push a button and turn it off but still
skysky is offline   Reply With Quote
Old April 8th, 2010, 09:51 AM   #23 (permalink)
Vehicle: 2011 Subaru STi
mistahcat is on a distinguished road
I got one of these. It cost as much as itself to install, but I did it at the mitsubishi dealer. My dealer is amazing with my aftermarket stuff. When I brought in my car for an oil change after installing KN short ram, they gave me new screws for my wiretied (those plastic screws suck.) intake lip.
My car: GT, 07, Fujita CAI, 20 inch wheel, sunny SN3800 tires, axelback
Labor time: 11 hours (charged me 1300, but was well worth doing at dealership; they also threw in my front and rear motor mounts for free while they were at it) They billed it as a complete transmission overhaul.
How it's working: Awesome. Cornering is more like a car, less like a slip'n'slide.
Also in regards to ABS and traction control logic (TCL), ABS works fine (snow and rain - ****ing nebraska...) and TCL still engages like it normally would once the tires start to slip a little but since I don't really need it I just turn it off and the diff does its job. So I'm guessing they work together, but it feels more like TCL is just a cockblock.
mistahcat is offline   Reply With Quote
Old April 8th, 2010, 09:58 AM   #24 (permalink)
I would say any FWD car serious about performance and high power MUST have this installed - as there is a point you will no longer be able to apply the power you are making
Old May 24th, 2010, 01:35 AM   #25 (permalink)
ALBOE's Avatar
Vehicle: 2012 Camaro
I'll be getting this whenever is time to do maintenance on my clutch.
Old May 24th, 2010, 09:25 PM   #26 (permalink)
4G69er
Lanzerralliart's Avatar
Vehicle: CS7A
Lanzerralliart is a glorious beacon of lightLanzerralliart is a glorious beacon of lightLanzerralliart is a glorious beacon of lightLanzerralliart is a glorious beacon of light
Yeah you guys are lucky yours is over 300 bucks cheaper?!!? I don't get it either..lol
RIP SILVERSIDE you'll be immortalized with your accomplishments...The all new 2009 2002 Eclipse - Equipped with 265-horsepower MIVEC V6 - First in the world!
Lanzerralliart is offline   Reply With Quote
Old December 3rd, 2010, 04:16 PM   #27 (permalink)
Lathe Master
Ricoswave's Avatar
Vehicle: 05 Lancer Evolution
Still no pics of a cracked six speed tranny case huh? Man I wish there was some more material out there or I might have the balls to try this on my own when its clutch time.
Mods:
Old December 3rd, 2010, 04:28 PM   #28 (permalink)
Pics of Stock Differential
^also a video of a celica doing burn-outs w/ the pozzy installed
Old December 3rd, 2010, 05:45 PM   #29 (permalink)
Lathe Master
Ricoswave's Avatar
Thanks for the link man, but I was thinking more along the lines of like seeing what I have to pull apart after the bell housing is cracked. I watched a vid on the getrag 5 speed in the mini cooper yesterday,and it looked like CAKE. I can't imagine it being that easy for us though, judging from what I've heard.
Mods:
Old December 3rd, 2010, 07:52 PM   #30 (permalink)
Pics here:
Index of /4g/tech/trans-clutch
The folders are named. The pics are just numbered by the camera. Mostly should be in order of what I took apart. The pics really hepled to put it all back together. Everything is super heavy. It would help to have an assistant.
The syncro hubs _WILL_ slip and ball bearings will fly out in 3 different directions. Have a clean work space since you will be chasing after ball bearings a lot. Tiny little suckers :-P
I had better luck reassembling it with the gear stacks horrizontal. With the bell housing on the table and the gear stacks verticle, the syncro hubs fall from their own weight too easily and the balls go shooting out. I'd charge about $500 to install a LSD into a tranny that was already out of the car and still hate every minute of it.
Mike W
Old December 3rd, 2010, 11:46 PM   #31 (permalink)
Lathe Master
Ricoswave's Avatar
Wow Mike thanks, sounds just as much of a pain in the ass as I thought.
Too many chances to screw something up, not sure if this is something for the less than professional to attempt.
Mods:
2.4l, 3.8l, 4g69, 6g75, acceleration, art, cars, drive, drivers, gear, good, handling, loss, original, performance, race, racing, rally, shop, speed, straight, street, unique, wheels, works
