Old October 11th, 2010, 06:24 PM   #1 (permalink)
b1gkishan's Avatar
1 Highscore
Vehicle: 06 Gt 6spd
b1gkishan is a glorious beacon of lightb1gkishan is a glorious beacon of lightb1gkishan is a glorious beacon of lightb1gkishan is a glorious beacon of light
swapping clutch
So my release bearing went out so im putting a spec 2+ clutch and fidanza flywheel and oem slave cylinder........3 1/2 hours later the tranny has been dropped working calmly making sure i keep up with all my bolts ..........but its dark so i might save the rest for tomorrow!
Originally Posted by joeyb
- it may ruin me financially, get me divorced, and who knows what else, but I WILL get this build done some day
Est.430+whp Nitrous-150shot. Aiming for 350+WHP N/A
b1gkishan is offline   Reply With Quote
Old October 11th, 2010, 08:19 PM   #2 (permalink)
fastest 4g in colorado
roy_robinsonV's Avatar
Vehicle: 08 gt
roy_robinsonV has much to be proud ofroy_robinsonV has much to be proud ofroy_robinsonV has much to be proud ofroy_robinsonV has much to be proud ofroy_robinsonV has much to be proud ofroy_robinsonV has much to be proud ofroy_robinsonV has much to be proud ofroy_robinsonV has much to be proud ofroy_robinsonV has much to be proud of
how is dropping it was it hard wat did u have to take out to drop it u should do a write up i dont think there is one on cluch swap
roy_robinsonV is offline   Reply With Quote
Old October 12th, 2010, 12:32 AM   #3 (permalink)
b1gkishan's Avatar
1 Highscore
Vehicle: 06 Gt 6spd
bleh its time consuming! but i wasnt rushing just taking my time making sure i dont lose any bolts! i also had a friend helping me! but its easy untill you get to taking off the tranny cause the rear mount is in the way! i guess i should have removed it, i thought i did but there is a bolt behinde the bracket! ill take pictures so its not confusing! and ill try my best to do a write up with pics! i think bolting up the bell housing to the block is going to be the hardest part! but we will see tomorrow when i continute!
bearing, bolts, clutch, fidanza flywheel, flywheel, oem, release, tranny
