Old January 10th, 2011, 07:41 PM   #1 (permalink)
ferazjaved's Avatar
Vehicle: 2007/Eclipse/GT
ferazjaved is on a distinguished road
brake problem?
so basically when its cold in the morning, or if the car is sitting for 3-4 hours, when i start it and reverse it, and brake it, it makes a LOUD noise. it is not a minor squeal or i wouldn't be complaining. I showed this to like 4-5 places, but whenever im there it doesnt make the noise -___- and they check the brakes n say everythings fine.. remember that it only comes when i brake, and only when in reverse. when accelerating and backing out it is perfect. any ideas?
ferazjaved is offline   Reply With Quote
Old January 10th, 2011, 07:47 PM   #2 (permalink)
TemplarRadix08GT's Avatar
Vehicle: 2008 black eclipse MR
TemplarRadix08GT will become famous soon enough
What pads and rotors are you using because the more aggressive the rotor/pad the more shrilly it is.
It doesn't happen at all forward?
Audio: Eclipse 5030 deck, RE Audio xxx6.5c Speakers, Re Audio mono block and quad channel amps, Stinger wires and caps, Optima Redtop, second skin.
Performance:Stiffy, Injen CAI, HKS ABM, S-T rear sway bar, energy suspension bushings all around.
Brakes: StopTech pads, Powerslot Rotors, Goodridge lines
TemplarRadix08GT is offline   Reply With Quote
Old January 10th, 2011, 07:53 PM   #3 (permalink)
ferazjaved's Avatar
i got the rear rotors and brakes change a few months ago in an attempt to fix this noise but it didnt help.. idk the company name tho.. and it is perfectly normal when driving forward
Old January 10th, 2011, 08:04 PM   #4 (permalink)
Maybe a wheel bearing gummed up or ebrake jam..
Sounds odd..
Old January 10th, 2011, 08:17 PM   #5 (permalink)
Brakes Squeal in Reverse only - Nissanhelp.com Forums
Park your car in gear without the parking brake. Could be freezing up.
Old January 10th, 2011, 08:54 PM   #6 (permalink)
All Black Everything
JDub's Avatar
JDub is just really niceJDub is just really niceJDub is just really nice
Yea, I have this exact same issue. So confused, lol.
Motegi Racing MR118 Rims / Fujita CAI / 35% Tint / Halo Projector Headlights / Projector Eyelids / DRL Delete / Black LED Tail Lights / Interior LEDs / Sony Head Unit / 12" MTX Subs / MTX Terminator Amp / Debadged / Upper + Lower Grillcraft Grill / Progress Rear Sway Bar / RRE Magnaflow Axle-Back / Painted Calipers / Momo Shift Knob / Custom Seat Covers
JDub is offline   Reply With Quote
Old January 11th, 2011, 11:28 AM   #7 (permalink)
ferazjaved's Avatar
Sounds odd..
i had a mechanic friend that had a similar opinion.. he said it was some ebrake problem... he took my car for a day n did somethin to it lol and it went away for a week or two.. but then it came back.. and i cant really consult him anymore since he moved outta town =[
Old January 11th, 2011, 11:29 AM   #8 (permalink)
ferazjaved's Avatar
i'll try today and let you know!
Old January 11th, 2011, 11:30 AM   #9 (permalink)
ferazjaved's Avatar
its the most annoyin shit ever
Old January 11th, 2011, 11:31 AM   #10 (permalink)
Daxenth's Avatar
Vehicle: 2008 Eclipse GS-N
just a hunch but maybe its the early morning frost on the brakes. mine have a rust film and my stopping power is like BAM for the first stop of the day. but after the pads rub the rotor one full turn my braking is normal. not chirps. and no like tap on the brake and getting whiplash
Mods=Daxenth's Satin Girl
Buy My Stock Shit!
Old January 11th, 2011, 11:56 AM   #11 (permalink)
ferazjaved's Avatar
does it make a REALLL loud noise? and yeah its only in the cold.. but even if it sits outside for 3-4 hours it happens again.. any way to fix it? other than getting brembo brakes lol $$$ =\
Old January 11th, 2011, 12:06 PM   #12 (permalink)
Daxenth's Avatar
mine dont squeak obnoxiously loud but yeah there is some squeaking.
Buy My Stock Shit!
Old January 11th, 2011, 12:14 PM   #13 (permalink)
Is it like a loud groan when you first stop, kind of like our famous brake squeal just louder?
Do you use your parking brake most of the time? E-brake might not be releasing until you move.
Depending on what brake setup you have... some high performance brake pads have to heat-up before they become optimal.
Old January 11th, 2011, 12:52 PM   #14 (permalink)
ferazjaved's Avatar
a very loud groan yes. i have never used my e-brake till date lol. and im prtty sure my brake pads arent thatttt great. they must be decent.. but then again, no one finds any problems when they check my brakes n everything
Old January 12th, 2011, 03:27 PM   #15 (permalink)
If it is only happening when you first start your can and start rolling and then the problem goes away after the first mile or so, more then likely it's just your pads. Nothing you can do except change out to a higher quality pads and break them in properly. When I first installed my new brake system, when I backed up it made a really loud groan the first couple times; however after I broke the brakes in properly I haven't had a problem since.
Also when you installed your new rotors and pads, did you break them in correctly? This is normally done by driving your car at a low speed (<30 mph)and making several slow stops (5/6 stops), then stopping your car and letting your brakes cool for about an hour, then repeating the process. Then do the same at a higher speed (<50 mph) at least once. From there take it easy on the brakes for the first 500 miles, no hard braking. This conditions the rotors from hot-spots/warping and the brake pads so they will operate and last longer, and hopefully prevents your brakes from squealing.
Our OEM pads are notorious for squealing, that's why most of us at the very least upgrade to better, higher quality, pads. Some of us upgrade to high quality rotors and pads, 6/7 hundred, or better yet, go with a big brake system $$$$. When it comes to brakes... you get what you pay for.
Old January 12th, 2011, 03:42 PM   #16 (permalink)
Another thing you can try. Disassemble your brakes, use a very fine wet & dry sand paper and resurface the rotors by scuffing the surface, light sanding, this will get rid of any surface contaminants, then clean the rotors with some brake cleaner. Do the same with the pads, just enough to get rid of any surface contaminants. Re-assemble and break-in the rotors and pads properly.
Old January 12th, 2011, 04:43 PM   #17 (permalink)
NitroGlisson's Avatar
Getting Brembos won't fix it if it is your parking brake. The parking brake is actually a very small drum brake independent from the disc brakes.
art, brake, brakes, car, cold, noise, problem
