| View Poll Results: Better headers for GT? | |||
| OBX |
7 | 33.33% |
| RRE |
14 | 66.67% |
| Voters: 21. You may not vote on this poll | |||
2007/Eclipse/GT
headers
here are a few headers i found on ebay.. are the RRE's really worth it or OBX is iigh? any opinions?
06-09 ECLIPSE GT V6 OBX SS304 HEADER EXHAUST LONG TUBE - eBay (item 390277291232 end time Jan-13-11 08:59:14 PST) OBX Header 06-09 Eclipse GS V6 Exhaust Manifold - eBay (item 180516189065 end time Jan-29-11 14:19:03 PST) Road Race Engineering's 4G Eclipse Parts and Performance |
Jeff
2008 Eclipse GS-N
header gains are minimal between the two.. any header is a good header though. just RREs are simple bolt on, where as OBX long tubes your gonna have to weld a bit
Jeff
2008 Eclipse GS-N
haha im just on at the right times
and no problem man
#5 (permalink) | |
![]() Join Date: Jul 2008
06 Gt 6spd
I'd go with obx! with RRE you will still have the stock y-pipe which is terrible for scavenging as it creates a reverse flow.
**speaking for a gt idk about a gs
Est.430+whp Nitrous-150shot. Aiming for 350+WHP N/A |
Jeff
2008 Eclipse GS-N
i always forget your in a GT man. but yeah id go OBX for GT at least. OBX for GS suckkkkkkkk.... RRE is our godsend though
07 Eclipse GT 6speed
On at the right times? Dax you never get off this site. Haha you must sit there like this
waiting for thread updates. But its okay, we like you.
Injen intake, RRE short tube headers, Injen exhaust, Outlaw Engineering spacers, VFiber CF OEM hood, Nexxo wheels, Eagle GT 245/45/18 tires, Progress sway bar, Energy Suspension motor mounts and suspension bushings, Ingall's torque damper, Tanabe strut brace, MR coilovers, AEM FIC(tuneless for winter), more to come in time. |
Jeff
2008 Eclipse GS-N
lmao. well i wake up to this site. and i go to bed to this site. and usually during the day im at the girls house. so. gotta make up for lost time
#9 (permalink) | |
Will
2007 Eclipse Spyder GT-PN
Personally I'd go with the RRE headers due to less modification to make them fit right. I'm not comfortable with extending wires on O2 sensors, welding, and whatever else you need to do for the OBX. I've seen the RRE ones in action and I'll stick with the guys that have been doing Eclipse/Evo parts and performance since the beginning of time. ^^ Of course when it comes down to it, it's all about your budget and how much work you wanna do.
Don Glisson
2008 Eclipse GT
I have the OBX long tubes and love them and I guarantee my Y-pipe works better than anything stock
08 Eclipse GT - SC
long tubes are a little better in my opinion, and required if you ever want to go forced induction. long tubes to a large pipe sounds the best for the v6 in my opinion.
#12 (permalink) | |
2007/Eclipse/GT
08 Eclipse GT - SC
^man I say if you read up, study and understand each step, have tools, then you can do the install yourself. it will be at least a few hundred dollars more to have someone install them for you unless you know a mechanic who'll be very nice to you.
there are several how-to's on this site that go over the installation of the long-tubes and what is involved. yes, if you buy the OBX kit then you'll need to extend your o2 sensor wires in some way. that is just about the only other thing you'll need, except maybe getting it welded into the cat-back at the muffler shop. $50, 1 hour worth of work. easy.
08 Eclipse GT - SC
check out this thread - 2nd page, about half-way down. you can see some of what is involved in the install.
Freekers' LongTubes' Thread
blue lightning
aj
2006 mazdaspeed6,2005 rx8
I have the obx headers. Basically all u need is a jack, socket set, wrench set and some wire to extend the o2 sensors. Also heat shrink wrap. After all is done u just take it to a weld shop to weld the test pipe. I believe freeker has a how too thread
Pushing 19psi Mods: greddy type s bov, greddy turbo timer, boost gauge, sure race pipe, sure sri, magnaflow exhaust, aem wide band, cobb ap, su rear engine mount, h&r springs, whiteline adj. rear sway bar, cxracing fmic, dreadnaught front differential brace, dreadnaught rear differential brace, kmd fuel pump internals |
#16 (permalink) | |
Don Glisson
2008 Eclipse GT
Sleeper
2006/Eclipse/GT Plus
The OBX headers are simply a less expensive (knock off) of the RIPP longtubes and the comparison between RIPP and RRE headers has been ongoing for a while (litterally years) on this sight. what everyone's pretty much discovered is the longtubes are better for heat scavenging which is great if you're autocrossing or doing laps at the track, but not really needed for DD or occasional racing. As far as the power goes, the longtubes pump out around 5whp more peak power than RRE with a stock y-pipe but the RRE headers put out more midrange power. RRE headers with a custom y-pipe put out the same peak power as the long tubes with no loss to the midrange which has it's benefits.
The important thing is that you modify your car according to your own personal driving style and budget
Injen CAI|Headers|EGR bypass|Proflow TB|TB bypass|Phenolic spacers|De-burred upper & lower intake plenums|APXEi hyper-ground system|Hi-flow Cat|WORKS Exhale 3" cat back|Ingalls ETD|Poly motor mounts|Quaife LSD|Short shifter|Aluminum Flywheel|CM FX400 Clutch|Poly suspension bushings|Eibach springs|Cusco strut tower bar|Tanabe under body brace|19 x 7.5 ADR Spades|245/35 Goodyear GT2's|Aero kit|Eyelids|Debadged|5% tint|
#18 (permalink) | |
08 Eclipse GT - SC
I HIGHLY recommend you do the motor mount upgrade at the same time.
#19 (permalink) | |
Step Up or Step Aside
Patrick
'09 Rave Red GT
This may seem like a stupid question, but my exhaust is far from stock. Only the stock y-pipe remains. However, it still follows the fitment pattern of the stock exhaust. So if a quality after market y-pipe exists that simply replaces the stock one, then by all means please share the info. |
#20 (permalink) | |
Pat
08 GT Spyder 6MT
#21 (permalink) |
06 Eclipse GT
I think the stock y-pipe is fine the way it is...just because it has one bend in it doesn't mean it won't flow...
#22 (permalink) |
Sleeper
Not saying that the stock y-pipe is a seriously weak link, its definitely not, thats why RRE didnt see the need to change it after they made and tested theirs. Just saying that once the stock y-pipe is replaced, any difference in power between the shorties and the long tubes is completely gone. Keep in mind i'm talkin about less than 5whp so most wont notice any difference at all. If you are simply chasing after those higher dyno numbers then every little improvement can, however, make a difference.
There currently is no template for a y-pipe replacement so if you want it you will have to get one made and honestly, the performance difference isn't really worth the price ($100-$300 for less than 5 whp, depending on the shop) but if you're just chasing numbers and money isnt an issue, then you may want to do it. I'm lookin at getting a custom y-pipe made for my setup simply because i need every single little (or big) increase i can get with my NA setup in order to keep Carl's (horse eater) taillights in view when his twin turbo boost kicks in, and i've been blessed with the fact that money isn't too big of an issue for me. My best advice, do what you can do and make your car the way YOU want to make it
#23 (permalink) | |
1989 2.0 Mirage Turbo
Stock Y pipe: ![]() Mike W |
#24 (permalink) |
Will
I don't get it....but OK.
Are we describing back pressure here? EDIT: I'm a stupid. I was looking at it thinking I was all bass ackwards.... Yeah, Mike is right, it flows just fine. I know MitEclipse07 got the custom Y pipe done for like 180 bucks and says he feels a difference in it. Who knows though. I'm sticking with RRE. They seem to know what's up.
#25 (permalink) |
"Uncle" Clayton
Tournaments Won: 1 Name:
Clayton
2007 GT
Really flowing left,right,up,down dosnt matter so long as the pipe is proper sized and mandrel bent with no restrictions, its gonna flow fine. The force behind it its gonn push it the minor "bend" it has to go thru.
#26 (permalink) |
08 Eclipse GT - SC
REST DELETED b/c misleading.
............. like I said above, the difference will be minuscule for the majority of drivers. but boy I tell you, the long tubes sure SOUND mean as f*ck.
![]() "Has blower and many modifications." ~347 WHP / ~309 WTQ / ~6 lbs Boost Last edited by joeyb; January 20th, 2011 at 03:57 PM. |
#27 (permalink) |
06 Eclipse GT
^^^ That MAY be true to some extent, but honestly, I think as long as you are mandrel bent and not crushed that it isn't going to be worth the difference (if any). I mean, you're still going to have to bend the custom y-pipe too...so really, what's the difference?
Also, more flow doesn't always mean more power either...it might be best suited for redline performance...but how often are you at redline? Cut your pipes off a foot from the head, that'll give you little to no restriction...but you're low and mid range power will pay dearly for that... IDK, I don't think it's worth it...I really don't think you're going to see anything from it...the stock pipe is the proper size and it's mandrel bent...and it's 1 bend...not a whole bunch of twists and turns...and the front portion of the y-pipe you really can't improve upon other than maybe getting rid of the 45...but it's going to have to bend somewhere to clear everything... I'd like to see what a "custom" y-pipe looks like for this car...it can't look all that different from the stock one...
#28 (permalink) |
06 Eclipse GT
Joey...
What do you mean about "having one blowing back into the other"? It's just a standard "Y" merge...I don't see the difference in this or any other "custom" setup...even the longtubes have a "Y" section where both pipes come together into one...
#29 (permalink) |
08 Eclipse GT - SC
keeping this for the info and thread flow - BUT MISLEADING - BRIANJ IS CORRECT. I AM WRONG.
just seems like whatever gains in flow the shorties buy you are gone once they hit that stock y-pipe. here is the long tube design: ![]() probably not a ton of difference, I'm sure. but again, I sure like the way the long-tubes sound, and I know that I have maximized my exhaust from the head all the way to the muffler. I may be a little prejudice against stock parts and this stock y-pipe in general, tho.
![]() "Has blower and many modifications." ~347 WHP / ~309 WTQ / ~6 lbs Boost Last edited by joeyb; January 20th, 2011 at 03:58 PM. |
#30 (permalink) | |
Will
Got any pics bro? |
#31 (permalink) |
06 Eclipse GT
^^^ Now that right there drops off RIGHT INTO the other pipe...it doesn't even look like a good transition angle...it looks like it almost 90 degree's into the other pipe! That to me would be restrictive...but that's a bad angle...
And the big advantage to headers of either kind is that you get rid of the cat's in the manifolds...that's your restrictive part...not the "Y" pipe...
#32 (permalink) | |
Will
#33 (permalink) |
08 Eclipse GT - SC
if you want to sound beastly like an STi - then long tubes.
#34 (permalink) |
06 Eclipse GT
What are you talking about with "backward blowing"??? On the stock setup, both pipes flow exhaust in the same direction when they meet...never does one pipe blow gases into another pipe in the opposite direction of flow...
#35 (permalink) |
06 Eclipse GT
LOL...you must be...the "front bank" of headers is out of the picture at the TOP of the screen...look at the direction arrows...the front bank blows DOWNWARD in this picture (from top to bottom)...the rear bank is the one with the bend in it...it goes around and MEETS the front exhaust flow IN THE SAME DIRECTION the front exhaust is flowing...never does one send gases into another in different directions...they just meet up, same as your longtubes...
#36 (permalink) |
08 Eclipse GT - SC
Ahhhhh..............i seee.
Brianj is right of course. sorry guys I am a dumbass. looks like the y-pipe flows better then I realized. but still - that backward bend isn't good but probably doesn't even matter.
| 09 eclipse gs, 4g eclipse, accessories, car, eclipse, eclipse gs, eclipse gt, exhaust, exhaust manifold, header, headers, long, long tube, manifold, obx, parts, performance, rre, tube, worth it |
