Old January 28th, 2011, 09:21 AM   #1 (permalink)
deprydation's Avatar
Oil Catch Can
What do you guys think of Oil Catch Cans? I'm curious about putting one in, but I've never done anything like it before and also wondering about what it does.
I've been told that even totally stock cars can gain from having one installed.
Anyone familiar?
this guy is a cunt rag
Old January 28th, 2011, 09:26 AM   #2 (permalink)
hey man I have one. they are used to stop oil from getting into your intake manifold. helps extend the life of the engine, etc. you would want to use one on any high performance engine or car with higher then average oil pressure - i.e. OURS.
It doesn't add any power of course but is good for your engine. A hose coming out of the front valve-cover goes to one side of the can and a hose coming out of the other side of the can goes to the intake manifold.
don't know if I would say "gain" from having one installed but all stock cars could "benefit" from it - at least in a minor way. If you drive aggressively at all I'd say go ahead and put one in.
they are cheap and good for your motor, but I don't know what the real benefit to an NA motor would be - BUT it certainly couldn't hurt. like I said, we do have higher then average oil pressure. Here I'll get a pic of mine installed
Old January 28th, 2011, 09:28 AM   #3 (permalink)
Old January 28th, 2011, 09:32 AM   #4 (permalink)
dsm2mivec's Avatar
Vehicle: 06 Mitsu Eclipse GS
I have one for sale if you want to check it out
Old January 28th, 2011, 10:57 AM   #5 (permalink)
Joey, on yours I only see 2 tubes. There is always a 3rd line on all of them that I see. What is that?
Old January 28th, 2011, 11:04 AM   #6 (permalink)
Sleeper
pdiddy1995's Avatar
Vehicle: 2006/Eclipse/GT Plus
pdiddy1995 has a reputation beyond reputepdiddy1995 has a reputation beyond reputepdiddy1995 has a reputation beyond reputepdiddy1995 has a reputation beyond reputepdiddy1995 has a reputation beyond reputepdiddy1995 has a reputation beyond reputepdiddy1995 has a reputation beyond reputepdiddy1995 has a reputation beyond reputepdiddy1995 has a reputation beyond reputepdiddy1995 has a reputation beyond reputepdiddy1995 has a reputation beyond repute
JoeyB said it all. They help keep oil out of your intake. Usually only FI motors use them due to their higher oil pressures however I have one on my NA setup and i was surprised at just how much oil it keeps out of my intake.
Injen CAI|Headers|EGR bypass|Proflow TB|TB bypass|Phenolic spacers|De-burred upper & lower intake plenums|APXEi hyper-ground system|Hi-flow Cat|WORKS Exhale 3" cat back|Ingalls ETD|Poly motor mounts|Quaife LSD|Short shifter|Aluminum Flywheel|CM FX400 Clutch|Poly suspension bushings|Eibach springs|Cusco strut tower bar|Tanabe under body brace|19 x 7.5 ADR Spades|245/35 Goodyear GT2's|Aero kit|Eyelids|Debadged|5% tint|
pdiddy1995 is offline   Reply With Quote
Old January 28th, 2011, 11:06 AM   #7 (permalink)
Originally Posted by deprydation View Post
Joey, on yours I only see 3 tubes. There is always a 3rd line on all of them that I see. What is that?
ah - some of them have a 'drain tube' that you can have go back down to your oil pan. on mine I just 'dead-ended' the tube and will have to drain my catch can from time to time. my oil pan is so pressurized it was blowing oil right THROUGH the catch can and into my manifold anyway! so I just took the drain and ended it off.
not all of them have it but most do. and going to your oil pan shouldn't be a problem for most. I just have that extra oil pressure b/c of that blower
Old January 28th, 2011, 11:22 AM   #8 (permalink)
eBay is a good place to buy or no?
Like this one?
Old January 28th, 2011, 12:17 PM   #9 (permalink)
yeah cool man. way better then mine - but mine was just $70, so that was a factor
Old January 28th, 2011, 01:12 PM   #10 (permalink)
Well the one pictured is like 125 bucks. I'm not spending that, just used as an example.
I'm looking at one from eBay for like 30 bucks or something. Is there any real difference or something I should look for when buying one?
Old January 28th, 2011, 01:26 PM   #11 (permalink)
x-street
bullet06's Avatar
Vehicle: 06/GT/AT
You could get one with a breather aka filter so the are going in to the intake manifold is a little cooler.
Old January 28th, 2011, 01:28 PM   #12 (permalink)
oh hell no - it's just about functionality, and after that just how "pretty" it looks under there. You could make your own for very cheap, I'm sure. I wanted mine to be kind of shiny, and not totally homemade looking - but it could certainly be done for very cheap.
cars, oil, oil catch can, stock
