![]() Name:
Jorge
2011/Eclipse/OZ Rally
ehh turbo kits from ebay "/ i wouldnt go for it
Some say if you tune your radio to 88.4, you can actually hear his thoughts... all we know is, he's called the Stig. |
08/eclipse/se
DONT DO IT! seriously dont get it, you'll be sorry. search the forum. we got guys on here who are selling or parting out turbos. just look around.
no mods, RUNNING ON DRIVING SPIRIT |
2008 gs
The issue is our turbo is mostly a custom kit and buying individual parts makes it more expensive, a decent kit for our cars are 3k and another 3 to install, i really hate our aftermarket support
Jeff
2008 Eclipse GS-N
you gotta take what you can get sometimes though.. sucks but if you want it that bad you gotta bite the bullet...
#7 (permalink) | |
08/eclipse/se
Jeff
2008 Eclipse GS-N
couldnt have said it better^
The O.G.
![]() Join Date: May 2007
2006 eclipse GT-TT
bro. the GS can practically borrow any 4gXX turbo kit available.
look at the NA lancer kit. its pretty much the same damn thing with some slight modification. you have to pay to play. cheap, fast, reliable. you only get to pick 2.
Under construction! Converting to single turbo, more to come! Twin Turbo- 338whp/311tq@4psi - Mustang dyno, courtesy PIA in Spanaway, WA. Panty dropping ability courtesy Forward Motion, Road///RaceEngineering, BrianJ, Delta Cams, Custom Import Heads |
The O.G.
2006 eclipse GT-TT
and if you think you are going to get all those parts for that price and have them last more than a couple days, you're stupid.
08 Eclipse GT - SC
I was going to say, it just isn't this easy. You always get what you pay for, like the guys say above. You need to KNOW your car and KNOW the kit and parts you are getting. it is just not easy to turn a n/a car into a FI one. You really need to understand what the kit is doing and how the engine works, etc. Even doing the build shrewdly and smartly will cost a few thousand dollars for anything of quality.
To me, someone wanting to go FI should buy a quality blower or trubo from a respectable company like Vortech or Greddy, HKS, etc. then build your set-up around that. Get the AEM F/IC 6 or something similar to control the fuel. You'll need to upgrade fuel delivery at least. (pump, regulator, injectors) If you push upwards of 10 lbs or more, you need to think about cooling - another thing that seems tricky and tough to get dialed in - either using a meth injection system or a FMI. If you push upwards of 10 lbs in the 6G75 w/out cooling you are looking at a very high chance of blowing your motor, it seems. So building your motor is at least another couple thousand. Hey man, you could buy that, throw it on your car, and hell it may even work for all I know. I just feel like going FI is something you don't want to skimp on. Be smart, patient and shrewd, yes - but don't go cheap. just my 2 cents.
Love that car
Dane Bush
2008 eclipse GT
Like everyone has already said dont do it it really isnt in your best interest and Horse eater when are we gonna see some numbers on your beast
Banned
2007/eclipse/GroceryShopp
Its not a bad kit I never had problems with the intercooler and piping from ebay but as far as the turbo, wastegate, bov, go with a respectable brand I learned the hard way it will work for a while but than it will die on you and its a headache . Turbo was good for a while but than began to leak oil so if you do buy it rebuild the turbo.Its a good base kit but I would build around it and get better parts.
#17 (permalink) | |
Moderator
2007/eclipse/SE
白人看不懂 azn/cracka goon #1 holla! ![]() |
Virgin Islands Refugee
2006 eclipse gt
well one person already bought this kit and it worked for a while and put out decent results i believe.....but i would def upgrade the main stuff....but his kit will start u off in the right direction.....just dont stick with it
Andy
04/lancer/ oz rally
I have a kit from eBay with 700cc injectors, 500lph pump, and a fully tuneable piggy back that controls a/f and timing retard every thing total came out to little over $1800.00, the only suggestion I have is to make sure all the bolts on the turbo housing are tight, " mass production " may have faults in that area you'd be surprised at what a t3/t04e is capable of! And never forget to upgrade clutch and flywheel! I can also tell you where to get the piggyback for probably around $550.00 plus shipping.
Boosting 14psi on stock internals hehe! Haven't dyno'd! Internals yet to come intending to go above and beyond expectations of a 4g94 Last edited by WizardofOZ; February 24th, 2012 at 02:32 AM. |
#20 (permalink) | |
travis
07 eclipse gs-n
#21 (permalink) |
Ryan
07 Eclipse GS-MR
pics or it didn't happen
Her name is Veronica, cause Veronica Vaughn is one hott piece of ace! Mods: rdelaney89's Still Blue Beauty |
#24 (permalink) |
Moderator
Kyle
06 Eclipse GT
Some people get lucky with eBay turbos, most people don't. I have seen several shafts on them just snap in the first hour or so of driving - probably do to extremely bad balancing.
If you want a cheap good turbo, Precision Turbo has some very reasonably priced entry level turbos, check into them.
06 Eclipse GT - My girls car, UV Blue, M6, Turbocharged, Eibach Pro kit, 3" Exhaust, Drifz 18x8 wheels and HID's |
#25 (permalink) |
Got Camber? 10.5+15 of IT
Fuzzy Wuzzy Umpkin
2006 Eclipse GT
Search for an old member we used to have , eclipsetuner44. He used a universal turbo.
He was also the dumbest individual to breathe on this side of the universe. Installed it without any fuel management, thought he was boosting when none of his lines were even connected. And practically blow up his engine and blamed it on how shit stock internals were... Just dont do it...
MY AUTOMOTIVE PHOTOGRAPHY SITE - STREET | MANOR Check Out The Official Kazman Thread!!! |
#26 (permalink) |
2006 Lancer Ralliart
you can turbocharge any motor...as long as it's fuelling properly, a little boost won't hurt anything...it's when you start pushing the power capacity of the motor that things will break down, and if it's tuned properly, it's not going to be detonation that causes the failure...wake up people.
#27 (permalink) |
Andy
04/lancer/ oz rally
Detonation is the main cause of failure, but of course if you have too much boost you can cause other internal damage, bending rods etc.... But air fuel should be the main focus in any build aside from internal upgrades. Most people find that a 255lph pump is sufficient which it it but I always run a 500lph pump and nothing smaller than 600cc injectors... Of course with an adjustable fuel pressure regulator and an aftermarket fuel management system... A fully tuneable piggyback for your FM and timing retard is what I always run, if anyone needs info on where to get one MSG me and I'll help you out, RRM, and other companies that have kits out use the same fuel management that I do but I go straight to the source so it is a little cheaper.
#28 (permalink) | |
Moderator
Kyle
06 Eclipse GT
#29 (permalink) |
travis
07 eclipse gs-n
ford racing makes a 500lph fuel pump
#30 (permalink) | |
Mivec sux
01/honda civic
. Nobody has even come close to 600 hp so why in gods name use 600 cc is this a joke?
#32 (permalink) |
travis
07 eclipse gs-n
edit
#33 (permalink) |
Moderator
Kyle
06 Eclipse GT
When I used to be the tuner at the Tasca Mod shop, obviously primary Fords. I changed many pumps and they don't have a 500lph pump. 05+ Mustangs would usually get the GT500 pump setups and it was a dual pump basket with an extra module and some wiring, expensive and around 375lph. The next most popular thing was to use a Single or dual SVT Focus pump setup as they were 217lph if I remember right. Unless this is something new? I left there in 08.
You can always tune injectors down, obviously you do not want to do way to big but 600cc would be fine just over kill for most people.
#34 (permalink) |
travis
07 eclipse gs-n
this is what i had glimpsed at and when i looked back over it, it seems like false advertising
FORD RACING Aeromotive 1000Hp 500lph high flow TURBO bosch walbro FUEL PUMP NEW | eBay
#35 (permalink) | |
Moderator
Kyle
06 Eclipse GT
#36 (permalink) |
Andy
04/lancer/ oz rally
Lol no joke I said nothing smaller that 600cc, only because when I'm done with the engine I will need the fuel to support, my car runs fine with 700's if you have read the first post I put up... Everything I have is adjustable ane tuneable for the fuel system and ignition system (for timing retard). I'm in Hawaii so humidity plays a big factor when it comes to air fuel ratio...
#39 (permalink) |
Moderator
Kyle
06 Eclipse GT
Never heard of it? Got a link?
| accessories, car, kit, parts, starter, turbo, turbo kit, universal |
