380Gt
6G75 forged engine
Hey guys I am in Australia.
Been lurking around the forum here for a while. I don't own any of the vehicles hosted here but we have a model 380/9g that uses a 6g75 as some of yours here have. So in case anyone is interested I have finished a build of a forged 6G75. It's all forged, balanced,ported and is ready to go in the car in two days. I waited and watched another similar thread on here but it has been quiet for a few months there so here is my build. It's my first build so go easy on me. It's a supercharged vehicle already and I want to increase from 7 psi with stock internals to 12 psi with fully forged internals. The engine reconditioner tells me it is bullet proof/indestructible. It may be of interest to some. I elected to have custom forged pistons made up, instead of reboring the block to fit the pistons, each piston is mated to the block. The rods are huge and the crank already forged has been Nitride treated to a depth that is obscenely hard. Heads are all polished,ported etc etc Here are pics of the engine at the rebuilders workshop. Interestingly the best con rods came from a US company and are same rods as they supply for a 6G74 engine...worth noting. enjoy! Here are a few happy snaps in random order for your enjoyment. The entire engine will be fully balanced, the crank is away being Nitride treated at the moment. ![]() the man ![]() the other man ![]() 6g75 sump showing baffles ![]() more of the same ![]() the block, no lip which is great ![]() another view of the block ![]() heads ![]() another heads pic ![]() old pistons etc, still perfectly serviceable. ![]() oil pump mechanism ![]() old and new piston comparison ![]() another old and new comparison ![]() The bolts are stamped ARP ![]() kit of bits ![]() another kit view, rings etc...rings are cast by the way, as per the stock rings ![]() note the new rod's busihing, the pin is tapered inside to reduce weight. ![]() Pauter logo ![]() note the massive improvement in material mass Last edited by z80; February 25th, 2011 at 06:16 AM. |
Don Glisson
2008 Eclipse GT
Sweet! Thanks for sharing that with us. I'd be interested in seeing more of that SC application. Please update as you progress.
Mods: Nitro's Little Girl With Attitude Last edited by NitroGlisson; February 25th, 2011 at 09:04 AM. |
Did u see GT on the back?
2006 Eclipse GS W26
Don you can check it on RPWs website as well. Thats the 380 with a Non Mivec 75 that comes stock Super Charged
"No, no, no, light speed is too slow. We're gonna have to go right to MIVEC speed." |
The Fallen
![]() Tournaments Won: 3 Name:
Isamu
300zx(TT) nismo 370z(T)
would that S/C fit in the eclipse?
Like our Facebook page:UAM 2009 Z34 SC STAGE 2 2010 Z34 NISMO Single Turbo 2013 FRS |
Diamond Dog
Ryan
2007/GT/MT
Sweet work. I'd be interesting in seeing the list of parts you swapped out for the motor build.
2007 Eclipse GT/MT ~ RRE Headers, Progress Springs, Injen CAI, Isotta Pedals, Poly Front Motor Mount, Tanabe Axle, back, TB Bypass, Rear Windshield Washer Delete, Rear Seat Delete, DRL Delete, Glowshift Gauge Pod, 6000K HID's, Centric Slotted Rotors Lowest timed run 13.984 @ 102.17mph My Garage Indycarz.com Admin |
08 Eclipse GT - SC
awesome man just awesome. thanks so much for the great pictures z. +rep
The Fallen
Isamu
same engine, just a spare one being dropped in from what it sounds like
2006 Eclipse GS W26
Im sure it would RPW offered it at cost if anyone wanted to test it, but no one has taken them up on it yet
And that why there are still only 2 turbod GT's and one option for a Super Charger for some reason everyone is afraid to be the first to do something
2006 Eclipse GT
I thought RRE tested that sc and it did not fit due to the firewall in the eclipse
Current mods: F5 CAI, tint, Ruffracing R281 19x8.5 RRE [update coming] |
#12 (permalink) | |
380Gt
-pistons custom made by SPS forgeing company in Australia. -rods from the US..."Pauter" brand -arp rod bolts -nitride treatment on crankshaft -CNC heavy duty bearing shell -balancing by removing crank material,replacing with heavier mass dowel -head port and polish -cams untouched -stock head gasket -8.5 static compression ratio -sump gaskets,etc...stock -cast rings supplied by pauter -no rebore, measurement of each bore and custom piston each cylinder. -light hone, engine had only done 25k miles out of a wreck. Hope that's clear enough. |
#13 (permalink) | |
380Gt
If I owned an Ecllipse i would modify the firewall to make it fit. I have that much satisfaction in the performance of the unit. It comes with a piggy back ECU..a perfect power SMT6 which drives a 7th injector to dump fuel in the manifold on large power demand. The supplied ECU mapping out of the box just works on our cars. The piggy back kit does have a version that you can tune your own maps yourself. Here is my stock one, power is so smooth and no violence. It's tuned for street use, not the drag strip. It has a LSD so takeoffs are superb....something that is a must for FWD cars...note no torque steer, camera is on steering wheel. Remember its a 9G, your car is much lighter and would fly like a rocket in comparison. YouTube - Redblower's Channel anyway...just wanted to talk about the engine forgeing cause doesn't seem to be anyone on the net that has posted about finishing it yet. Last edited by z80; February 25th, 2011 at 06:11 PM. |
#14 (permalink) | |
380Gt
My car has had the supercharger added after it left the factory. The factory fitted ones only came in 20 cars, they are collectors items, most went into museums and private collections and never get driven. The car pictured in the start of this thread is not a TMR380....it is a stock 9G GT with accessories added to bring it near the same spec. TMR - Team Mitsubishi Ralliart sold me the supercharger kit. I would not perservere with RPW, they are..err...in a different league. Having said that...I do own a TMR380 as well...just rarely drive it. The GT is my daily driver and dont really want to put a lot of miles up on this TMR380...it's too rare to fiddle with. I fiddle with the dark red GT...more boost...forged...LSD...AWD... Here's some pics , don't drive it much. ![]() ![]() ![]() ![]() ![]()
380Gt
Anyway...a forged 6G75 can be done, has been done.
And it's not rocket science either. So get on with it guys, turbo charge it if that's easier. If your engine builder has any questions call this man, very helpful and did the job.. Rob Rennie Engineworx Pty Ltd phone 61-3-52672150 Australia. cya |
2006 Eclipse GS W26
Not the RPW SC just a roots SC
2006 Eclipse GS W26
Thanks for the info I did not know they only made 20 of the ralliart version. There are a couple guys who working on building forged 75's right now. There is also a guy with a Vortec SC that bored it out to 4.0
Question since you are from AUS the statement you made about RPW? Is there something you can shed some light on, or something we should know?
08 Eclipse GT - SC
so that roots blower is stock right? how has it treated you?
Thomas
2008/Eclipse/GT
Didn't RRE test the alpIne supercharger, not this one. And we know forged is possible. There's one already out there and another 8 coming this summer. You can push way more then 12 psi.
#21 (permalink) |
08 Eclipse GT - SC
holy crap man good call, tom - no long tubes, z?
also - how does that roots-type sound? one of the reasons I love the Vortech centrifugal type is b/c it sounds like mad max and the knight rider.
#23 (permalink) | ||
2006 Eclipse GS W26
Oh and joey if you have heard a Mustang, Vette, Dodge, or GTP that is what it sounds like That his car http://www.youtube.com/watch?v=zwlutWC59sQ
"No, no, no, light speed is too slow. We're gonna have to go right to MIVEC speed." Last edited by DarkSidEclipse; February 26th, 2011 at 12:32 AM. |
#24 (permalink) | |
380Gt
Kit i am using has twin mandrel bent pipes with Euro4 emissions compliant fitted rear cat back with relocated lower O2 sensors behind it. Fully emissions compliant...just louder,breathes better and more power. about 20hp more just by doing that. |
#25 (permalink) | |
380Gt
With the bullet proof engine i will put it to the test. But...am having "Laminova " cores fabricated into the plenum chamber as an IC solution just in case. read about laminova cores here from the Aus distributor, am sure you have one in the US as well. Laminova Intercooler Tech Last edited by z80; February 26th, 2011 at 03:11 AM. |
#26 (permalink) |
380Gt
Did I mention i have a custom LSD in my auto?
It's a must with that much power. The Quaife QDH7B is the best for our drivetrains. But it needs machining of the crown wheel, the splines on the driveshafts need resetting and case hardening. No wheel spin or torque steer though... Just noticed it's 4 am in the US and 8pm saturday night here in Aus....LOL |
#28 (permalink) |
Travis
07 Eclipse GT
^ Ya i second Alboe's post. I need one to. Question for ya Z, how much did you pay for the LSD? U.S. Dollar please lol. Get a good deal from anyone in particular for the LSD?
#29 (permalink) |
OWNER OF C4G
Rick
2008 GT-SC
Just wondering y you did not do a overbore? Also what kind of rings did u use like stainless steel chrome plated or what??? Nice build if your going to do over 10 psi I have heard you need stronger valve springs idk if ur doin head work or not...
Please get your car up and runnin and do 15 psi man I want to see it alive
#33 (permalink) | |
380Gt
#36 (permalink) |
380Gt
The key was turned at 5:30 this evening and the engine roared into life...first time.
Just sounds like a new engine, no rattles or whistles...just a smooth whine. Unfortunately the smaller supercharger pulley was machined all wrong and doesn't fit. So will just be running around on 7.5 psi still. Probably won't hurt to run it on a proven relieable boost for a week or so...
#38 (permalink) |
The Fallen
Isamu
oh! does that mean we get a sound clip, or vid soon?
#39 (permalink) |
380Gt
you can always go here and check out the other clips.
the 5 psi clip is there and a few others. YouTube - Redblower's Channel |
| 6g75, block, bolts, bullet, car, custom, engine, fit, lip, pics, random, stock, supercharged, tire, weight |
