Old April 10th, 2011, 01:26 AM   #1 (permalink)
UV Blue Crew
kasey8697's Avatar
Vehicle: 06 UV Blue GT 6spd
kasey8697 is on a distinguished road
Aem ugeo
I have an AEM Ugeo and i have it installed rite after the flex pipe only problem is i have cats in my headers still. the reading im getting sound to be about normal but here is a vid of first and second gear pull (shift at ~6250). How much are the cats in the headers going to effect my Ugeo sensor? is it useless??
~kyle
kasey8697 is offline   Reply With Quote
Old April 10th, 2011, 01:32 AM   #2 (permalink)
UV Blue Crew
kasey8697's Avatar
wow ok fml anyone know how to get a .mov clip on here?
Old April 10th, 2011, 07:32 AM   #3 (permalink)
Black Irish
muscles's Avatar
Vehicle: 2006/eclipse/gs
photobucket. prob gonna have to link it though
Old April 10th, 2011, 09:43 AM   #4 (permalink)
mrgibs121's Avatar
Vehicle: 2007 eclipse GS
your readings will probably be pretty whack with those in there... anyone know what effect cats have? probably move the AFR closer to 14.7 if its running rich i would assume...
Old April 10th, 2011, 10:51 AM   #5 (permalink)
I thought the instructions say the sensor must be 30 inches from your exhaust hole...after the cat.....sounds like you are a little close to the engine to me....you need to be further 'downstream'
Old April 10th, 2011, 11:00 AM   #6 (permalink)
I look stock...
3CL1PS3's Avatar
Vehicle: 2008 GS 5spd
3CL1PS3 has a spectacular aura about
my sensor is right after the downpipe before the black connecting arm that goes under the pipe
Magnaflow catback, Injen CAI, RRE Underdrive Pulley,Ripps Brat Box,GT Throttle Body, Throttlebody bypass, Ralco Short Shifter, AEM UEGO wideband,AEM F/IC w/ brianj harness, ralliart strut bar, Optima Yellow top, JL W3 12", JL speakers front/rear, diesel audio 1600 watt apm, pioneer navi, tint.
3CL1PS3 is offline   Reply With Quote
Old April 10th, 2011, 11:30 AM   #7 (permalink)
UV Blue Crew
kasey8697's Avatar
http://i1096.photobucket.com/albums/...7/1da157b5.mp4
Old April 10th, 2011, 11:32 AM   #8 (permalink)
UV Blue Crew
kasey8697's Avatar
There's what it says in a 2nd gear pull
Old April 10th, 2011, 11:32 AM   #9 (permalink)
I look stock...
3CL1PS3's Avatar
same thing mine does
Old April 10th, 2011, 11:33 AM   #10 (permalink)
UV Blue Crew
kasey8697's Avatar
Do u have headers?
Old April 10th, 2011, 11:35 AM   #11 (permalink)
UV Blue Crew
kasey8697's Avatar
U have a gs also has to be different
Old April 10th, 2011, 11:38 AM   #12 (permalink)
UV Blue Crew
kasey8697's Avatar
No it's 36" after the headers and b4 the resonator and cat. I'm Jw about the effect with the cats in the headers
aem, gear, headers, pipe, problem, sound
