Old April 11th, 2011, 10:46 AM   #1 (permalink)
blue lightning
rgv4's Avatar
Vehicle: 2006 mazdaspeed6,2005 rx8
rgv4 has a spectacular aura about
burned out o2
Just wondering if a burned out o2 sensor (bank 1 sensor 1) would hurt me at the track
Pushing 19psi Mods: greddy type s bov, greddy turbo timer, boost gauge, sure race pipe, sure sri, magnaflow exhaust, aem wide band, cobb ap, su rear engine mount, h&r springs, whiteline adj. rear sway bar, cxracing fmic, dreadnaught front differential brace, dreadnaught rear differential brace, kmd fuel pump internals
rgv4 is offline   Reply With Quote
Old April 11th, 2011, 10:49 AM   #2 (permalink)
Vehicle: 07 eclipse gs-n
it may rob you of some power as the car tries to correct what its reading
Old April 11th, 2011, 12:33 PM   #3 (permalink)
deprydation's Avatar
It shouldn't hurt your performance a whole lot. The only thing I know of that it WILL affect is your emissions and fuel mileage.
this guy is a cunt rag
Old April 11th, 2011, 12:38 PM   #4 (permalink)
blue lightning
rgv4's Avatar
Cuz it sputters and misfires on me
Old April 11th, 2011, 01:10 PM   #5 (permalink)
If it's sputtering and misfiring you need to check more than just an O2 sensor. You may have other problems.
Check your spark plugs...
You may have fouled them out with the hefty shots of nitrous + fuel and no tune...
Old April 11th, 2011, 03:08 PM   #6 (permalink)
seems like it wouldn't be good....the ECU is expecting to see a certain reading, and if it doesn't who knows what it will "think" is wrong and try to do.....I would certainly fix it before I spent $ at the track - but that is me. my 200 yen.
Old April 11th, 2011, 03:52 PM   #7 (permalink)
Yap yap...
For sure get it fixed....but also figure out why it fouled out like that too...
Old April 11th, 2011, 04:31 PM   #8 (permalink)
blue lightning
rgv4's Avatar
Well the misfiring could b cuz of the sensor. Every code i get has to do with bank 1 sensor 1
Old April 11th, 2011, 05:43 PM   #9 (permalink)
If you have a misfire, yes, get it fixed ASAP!! This will be your rear header, first sensor. A Bosch replacement will run about $75, and an OEM replacement will run about $135.
You can have an underlying problem/s other then just your O2 Sensor, like an exhaust leak. But any who, your O2 Sensors reads your exhaust gases, in-turn sends that information to your ECU. The ECU determines if the exhaust gases are to lean or rich, and there-by adjust the fuel to that bank. If the the ECU adjust the fuel to be rich, then you can foul-out your plugs, but if the ECU leans-out the fuel mixture, then it can burn your valve seats.
Old April 11th, 2011, 09:40 PM   #10 (permalink)
Thank god, Clovisman to the rescue to save the day!
o2 sensor
