Pat
2007/Eclipse/GS
that trans from other cars will fit a gs
i have a GS auto and the trans needs to go i need stick. i would get a junk yard trans and rebuild it. but wat cars will have Manuel trans that will bolt up to. would any lancers trans line up right.
got a quote
RJ
2009 Eclipse GS
i feel you man.. i absolutely hate having this automatic..... if it weren't four speed and sluggish as hell, i wouldn't mind it so much.
Will
2007 Eclipse Spyder GT-PN
Find a car that uses the 4g69 block, hence the lancer. Those bellhousings should bolt right up and match the input shaft since they're basically the same. You'll have to get a new computer too since your Ecu is programmed for automatic and you're going to manual.
Pat
2007/Eclipse/GS
so any car with the 4g69 motor the trans will bolt right up. and i know i gonna need a new ecu. but will a programable ecu work. cause i want to change the head to the 4g63 head, than get a tubro and injectors. so i know to get the car to run right with those mods ill need a programble ecu
#12 (permalink) | |
Will
That or stand alone... |
| auto, cars, fit, trans |
