Old June 3rd, 2011, 10:43 PM   #1 (permalink)
UV Blue Crew!
XYZ123's Avatar
Vehicle: '06 GT 6spd
XYZ123 is on a distinguished road
Curious: has anyone modded their CAI (shorter)?
I keep going back and forth on Injen CAI vs K&N SRI. At one point I decided no-way on the CAI due to the risks with water.
I'm thinking of getting the CAI and shortening it by a few inches to keep it a few inches higher off the ground. I don't know if this is possible?
Has anyone ever considered doing this, or even done it before?
And please, any comments telling me not to worry, it'll be OK as-is, etc, is a waste of breath - I've read all those comments in the other threads. Just wondering if it's possible and/or if anyone's done it or looked into it. Thx!
XYZ123 is offline   Reply With Quote
Old June 3rd, 2011, 10:45 PM   #2 (permalink)
Amarillo 4g
DustinH's Avatar
Bypass valves do wonders for cai's
Old June 3rd, 2011, 10:46 PM   #3 (permalink)
UV Blue Crew!
XYZ123's Avatar
Yeh but I read they get torn in half if you don't have ugraded engine mounts!
Old June 3rd, 2011, 10:47 PM   #4 (permalink)
Amarillo 4g
DustinH's Avatar
I havent had any problems on any of the cars i've used them on.
Old June 3rd, 2011, 11:15 PM   #5 (permalink)
UV Blue Crew!
XYZ123's Avatar
Maybe the problem's unique to the GT's?
Old June 3rd, 2011, 11:23 PM   #6 (permalink)
Amarillo 4g
DustinH's Avatar
Maybe...But in the end the cai for our cars are placing the filter down under the bumper. If you run through water deep enough its going to hydro lock. Even if you can cut it and move it up a few inches. You still have to watch for water. Get some motor mounts if it will make you feel better about the bypass valve. Or stay out of the rain. If not stick with sri.
Old June 4th, 2011, 12:10 AM   #7 (permalink)
Got Stance??? i dont :(
MFTK's Avatar
Vehicle: 2009 Eclipse GT
Get an injen cai and just use it as a short ram. Dont connect the rest of the tubing is what i did. And u can use a hacksaw and cut the tubing if u want it shorter. Just cut on the filter side and make.sure u sand out the loose pieces .
Old June 4th, 2011, 12:12 AM   #8 (permalink)
MFTK's Avatar
Acutally stay away from injen. Noticed u have the 6 spd. Just read an article about it. Ill try and post it when i gethome
Old June 4th, 2011, 12:27 AM   #9 (permalink)
UV Blue Crew!
XYZ123's Avatar
Huh? Yeh, please let me know what's up w/that.
Old June 4th, 2011, 12:40 AM   #10 (permalink)
MFTK's Avatar
Ill snap a pic of it. Im at work till 9 am. Do it first thing when i get home. I think its just the 6th gear its not optimized for. Loss in power and richer air fuel levels
Old June 4th, 2011, 08:04 AM   #11 (permalink)
MFTK's Avatar
Old June 4th, 2011, 08:05 AM   #12 (permalink)
MFTK's Avatar
other then the 6th gear its a good intake, ive had no problems with it but i have the sportstronic gt
Old June 4th, 2011, 08:41 AM   #13 (permalink)
UV Blue Crew!
XYZ123's Avatar
OK thanks. I see that article and those numbers apply to the Nissan Cube.
Old June 4th, 2011, 04:19 PM   #14 (permalink)
UV Blue Crew!
XYZ123's Avatar
Well I just ordered the K&N Typhoon. No worries about water and I'm not building a friggin racecar anyway.
Old June 4th, 2011, 04:26 PM   #15 (permalink)
ptr149's Avatar
Vehicle: 2007/Eclipse/GT
Ya I was going to say just get the K&N. I have the AEM intake and I used to use it as a CAI, but I had a lot of problems with it when washing my car. It seemed like no matter how careful I was, the filter still got wet and caused the engine to go into limp mode until it dried. I have mine as an SRI now and it performs almost identical except it gives you more throttle response compared to the CAI which is a lot of fun for daily driving.
**5AT**
AEM SRI // HKS 3" Headerback Exhaust // Ingalls Stiffy // KYB Shocks // Eibach Prokit // Eibach Rear Sway Bar // Centric Rotors & Ceramic Pads // D-Speed Rear Bumper // Projector Headlights With CCFL Halos // 3k Fogs // 15mm Ichiba Spacers // SE Lip
ptr149 is offline   Reply With Quote
Old June 4th, 2011, 04:36 PM   #16 (permalink)
Mr. 4th gen eclipse's Avatar
Vehicle: 06 eclipse GT
Mr. 4th gen eclipse is a jewel in the roughMr. 4th gen eclipse is a jewel in the rough
i have the fujta 2 piece and switch between the two depending on the weather.
Mr. 4th gen eclipse is offline   Reply With Quote
Old June 4th, 2011, 05:48 PM   #17 (permalink)
snakeeyes's Avatar
Name: Loves haters !
Vehicle: 09 5 speed manual
as per request; this mod will help a great deal with your k&n sri.
Modified
Old June 4th, 2011, 06:52 PM   #18 (permalink)
UV Blue Crew!
XYZ123's Avatar
Thanks Kenny! That'll all make more sense to me when I get the intake in my hands. Hopefully it'll show up next week and I'll install it.
Old June 4th, 2011, 06:54 PM   #19 (permalink)
snakeeyes's Avatar
glad to help ! good luck with it
Modified
Old June 4th, 2011, 09:48 PM   #20 (permalink)
ThE JaIMsTa's Avatar
Vehicle: 2009 GS 5speed
ThE JaIMsTa is a jewel in the roughThE JaIMsTa is a jewel in the rough
ive though about that but just not sure if removing that rubber was worth it. also thought about closing the opening into the hood vent that way only the intake recieves the air
We are the GS, Vroom Vroom Bitches
ThE JaIMsTa is offline   Reply With Quote
Old June 5th, 2011, 11:40 AM   #21 (permalink)
snakeeyes's Avatar
removing the rubber definately helps to pull the air through the enlarged slit.when i removed it,i tried to slide a piece of notebook paper in there to test and it went no problem.that told me that air will get in there.removing the rubber alone will not help.that slit has to be enlarged allso so they both work together if your running a k&N setup or something similar that uses the snorkel.
Modified
back, cai, injen, king, sri, water
