Old June 24th, 2011, 08:46 PM   #1 (permalink)
Has A Big Member
stangcobra's Avatar
Vehicle: 01 svt cobra
150 DIY Tuner Tips(Direct Copy Paste from ImportsNC)
Not all of these tips are applicable to our cars, in fact maybe 50% are, that being said some of them are a self explanatory, some are really helpful, some are just freaking stupid
Heres a few DIY tuning tips.......... for every car......
1.Port Matching
If you are lucky, the engine in your vehicle has exhaust and intake manifold ports that line up perfectly to the cylinder head. But chances are this isn't the case. You can pick up a few horsepower by carefully removing material in the manifold ports to match the gasket or the gaskets to match the port. This can also be done on the cylinder head.
2.Transmission Line Pressure Increase
This simple modification pertains to automatic transmissons only. By using a factory service manual and looking at the wiring diagrams, you can increase line pressure within the transmisson. This results in stronger shifts by simply adding a drop resistor that can activated with a relay and dash-mounted switch. Great little weapon for bracket racers, too
3.Get the lead out
If you are a bracket racer or racing fanatic, you should know that weight is the enemy. Removing your spare tire and jack can save up to 30 pounds. If you need more weight reduction, drain your windshield washer reservoir. To the average joe this sounds nuts, but you diehards understand.
4. Spark It Up
This is a simple yet overlooked tip that can restore a few ponies: pay attention to the condition of your spark plugs. Worn plugs wont make optimum spark. Also, switching from a conventional plug to an iridium unit may help. For a few more bucks its worth it.
5.Clean terminals= Happy Charging System
Over time, you will experience a negative battery terminal corrosion, which affects conductivity and looks unsightly. To avoid this, use an aftermarket terminal that has better conductivity and is less likely to corrode, or use a protective spray. You can clean up this mess with a mixture of water an baking soda applied with an old tooothbrush.
6.Replace Worn Ignition Wires
This is a no-brainer, but those NGK wires that use to be bright blue are now black should be replaced. If your ride bogs and just plains runs like it has twice its mileage, try swapping the ignition wires.
7.Redline Water Wetter
This product works wonders by raising the enegine's boiling point and increasing the cooling capacity of your coolant. This tip is used by many forced-induction fanatics.
8.Lower Tempature Thermostat
Head to your favorite auto parts store and see if it has a thermostat that opens sooner ) lower temperature) than your factory unit. If it works in your application, this will allow your car to run cooler sooner and can minimize power lost to heat.
9.Stay Lubed
One of the things top racers do is change their oil before and after each event. Having fresh, clean oil in your engine serves many purposes. For your street machine change oil every 1,500 miles.. For those that can afford it.
10.More Ground
A thicker ground on the Nissan mass airflor sensor (MAF) is a mod many enthusiasts perform. The factory ground wire on the MAF tends to corrode, casuing inadequate signal. Your car will run better due to the stronger constant signal sent to the ECU.
11.Gutted Air Box
For those tuners who desire maximum airflow but cannon use a cone-style filter, this mod is for you. Cut the sides of your air box abd replace the paper filter witha high flow foam or cotton unit.
12.Test Pipe
Removing your catalytic converter is the fast way to free up power. It's also the fast way to pollute the environment and get into trouble with the law. By using a test pipe in place of your cat, on race day you can have the best of both worlds.
13.Who Needs A/C?
Some tuners believe that air conditioning on a small displacement engine is a joke since it steals a considerable amount of horsepower an sends the fuel enconomy into the toilet. By simply switching off the A/C or removing the belt, you can free up more power.
14.Power Steering Deletion
C'mon you big burly man! You really dont need power steering in a civic hatch back. Regain horsepower-go manual. OE power steering has no place on racecars or high-performance applications in such little cars. When rebuilding, do it right and use the correct parts.
15.Big Wire, More Voltage
If in doubt, rewire your fuel pump for adequate voltage. you must use larger gauge wire than OE to wire large-capacity fuel pumps and relays. Be certain to follow install specs-even if it means running new wire from the battery source to the pump, rather than splicing into an existing loom. You will be glad you did.
16.Questionable Speed Washers
I dont know enough to fully recommen this practice, it worked for this talon owner: he devised his own "ghetto" boost controller, consisting of washers installed on his internal wastegate linkage. This opens the wastegate farther than the factory setting...
17.Remote Exhaust Valve Control
This product can be bought over the counter-or if you are creative , make your own. For quicker turbo spool-up (more usable power) use it to "dump" the exhaust after the downpipe from your turbo. And when you're done racing, your car is once again street legal.
18.Big Mouth
Do some reserach and see if another vehicle within your automaker's fleet has a larger throttle body that can be retrofitted onto your intake manifold. For example, the Type-R throttle body is larger than the b16A throttle body.
19.Throttle Cable
Examine your throttle cable; if considerable slack exists, adjust it or the throttle will not fully open when you floor the accelerator. Also, check that you are actually getting "full-throttle".
20.OverLooked Manitenance
Interestingly, some of the simplest power tricks full under routine maintenance. Havinga clean air filter, for example, will ensure that you are getting maximum airflow into the enegine. New fuel filters are also smart- and thats for starters. Good wiring connections ad preventive maintenance on life-cycle parts is also wise.
21.Get A Grip
If lucky, you could benefit from bigger brakes off a different vheicle. Do some research to see if there is some cross-pollination action in your near future. For example 300ZX brakes and calipers will fit on a 240SX. Enough said, go for it.
22.Rear Diffuser
This product is available commercially and has been used on many drag Hondas for years. This low-buck version is a series of 3-inch holes cut into the back bumper of your car, which allows air passing under the car to escape instead of pooling behind the back bumper ands causing excessive drag.
23.Nail A Wicked Hole-Shot
This is simple yet very effective weapon for front wheel drivers. For drag racing at the track, get bump stops and install them in your rear suspension. This will limit the rear suspension travel, giving you better hook-up. You will nail better 60-feet times
24.Tire Pressure
Having the correct tire pressure not only ensures that you get maximum fuel economy, but also the best performance out of your high-performance tires. Check tire pressure every two weeks and adjust accordingly. New rims will leak
25.Timing Is everything
If you have a good consistent grade of fuel where you live-or better yet 92 octane- then you can benefit from advancing the timing a few degrees to pick up some extra throttle respsonse and more driveability. Be sure to use a timing light!
26.Lexan Windows
Replacing your heavy factory glass with light weight Lexan will help your car in weight department (and hence, accelerate quicker) A lighter car is quicker than a heavy one. so call FAL (866-203-5958) If you own a 92-00 Civic. If not, make your own.
27.Brake Fluid
This is too often overlooked. brake fluid needs to be changed at least every two years and for a high performance vehical, every year. Use or upgrade to a high performance DOT4 brake fluid. Its easy as draining the old fluid (completely), replacing with DOT4 and then bleeding the system. NOTE: this may make your pedal feel softer and is completely normal.
28.Crank Protection
When installing rods into a freash engine, it's an old tip to install a couple pieces of rubber hose over the rod botls to prevent scratching the crank journals. You can buy them inexpensively, too.
29.Ram Air Scoop
This information is nothing new; nonetheless, it can be quite an effective addition. To pick up cooler outside air, make a funnel-like device that goes in place of the headlight or any other greille-area location that best fits your vehicle.
30. Custom Cold-Air Intake
If you have a car that doesnt have a cold-air application available from the aftermarket, design your own.
31.Keeping Your Cool
For high output application take " keeping your cool" one important step further and replace your factory radiator with a high-flow aluminum unit. Not only does it look trick, it tends to make your cooling system much more efficient
32.Header Wrap
If you have a turbocharged engine, the engine compartment terperature may have a tendency to get hotter than usual. One helpful tip to combat this heat is to use a thermal wrap on the downpipe, turbine housing and the headers.
33.Hood Washers
By placing washer between the hood and hood mounting brackets and using longer bolts you can lower the temperature of the engine compartment. Air will enter the engine compartment in much the same way as a cowl induction works.
34.No-Pop Oil Dipstick
The problem of the oil dipstick popping out doesnt happen to everyone, but if it does there is a small fix. Either put a small pinch in the top of the tube or use a wire ( or spring) to hold it in place.
35.Custom Heat Shield
There are companies that sell intakes with these heat shields, but you can make your own out of stainless steel or any other material for that matter- and for cheap. It can be as simple as a flat piece of material that isolates the air fitler from the engine heat.
36.Power Terminals
The factory terminal is Japansese vehicles its made as cheaply as possible, but by upgrading to a block style terminal accessories such as alternator, starter and other current demanding equicpment will get the proper amount of current. Yes, this does affect horsepower.
37.DSM Blow Off Valve
This modification is popular among the DSM crowd. Thee first generation DSM vehicles could withstand boost pressures to about 17psi. With careful mod, it can actually hold upwards of 20psi.
38.Reveres Bov On A 2Dsm
By reveresing the blow-off valve on a second generation Talon/Eclipse , you can run more boost than stock without buying an aftermarket unit
39.Hacked MAF
Another mod brought to you buy dsm guys: by removing the lower chamber of the MAF, air-flow can be increased substantially with minimal effort and a soldering iron.
40.Subframe Spacers
This can be bought or made and are used primarily on Nissans. The spacers pre-load the rubber bushings between the subframe and the body, thus helping to reduce wheel hop and body lean.
41.Bushings
For very little cost, replacing worn and tired rubber bushings with urethane bushings will put life back into your suspensio. In cetain applications, this will be a major performance boost in handling.
42.Engine Mounts
Sometimes it's the little things that make all the difference. When doing an enegine swap, using mounts designed for a swap makes things alot easier. Check this out prior to your engine install.
43.Toluene
Toluene is a solvent that can be found in more serious hardware stores across the nation. Adding 10 percent (by volume) of this solvent to a tank of, say, 91 octane gasoline should increase the rating toapproimately 116 (See http://www.superhonda.com/forum/showthread.php?t=252611 to see if this is okay for your application ) which is great for forced-induction or nitrous-powered engines. For about $3 a gallon, you cant go wrong- but it may not pass fuel check.
44.Propane Injection
This approach has been around for some time and is used with wet nitrous systems. Instead of using fuel, propane has an octane rating of 105 and allows you to get a fuel boost with out disturbing the air/fuel ratio.
45.No Fog
This is an old ice hockey tip. Tired of your visor in your helmet or windows on your street car fogging up? Take a cloth with a dab of shampoo and wipe the inside surface. Take a clean cloth and completely wipe off the shampoo. No more fog!
46.Redline Shock-Proof Gearl Oil
This product works great in transmissons that see heavy street racing or racing action. This oil features a solid dispersion that helps custhin gear teeth from shock loading. It also makes disassembly of the gear set easier.
47.One-Drill Drill Set
You may have seen one before. The Unibit is a stepped drill bit that allows you to make a different size holes (larger) with out the guesswork and with out changing bits
48.VHT Track Bite
This compound is applied to the drive wheels of a drag vehicle to improve traction on less than-ideal track surfaces. If you have a problems hooking up, this product can help. This is the same company that makes traction compound for dragstrip surfaces.
49.Wheelie Bar Sho Polish
You may have seen crewmemebers of pro drag teams applying a white substance to the wheels of wheelie bars. By using white shoe polish, you can determine for how long the front end is lifting; thus, it helps you fine tune your suspension.
50.No Drag
If you don't wish to cut up your bumper to minimize drag, you can close up these areas with a piece of sheetmetal. It keeps the air out and is virtually invisable to onlooks. Paint it black or body color.
51.Ground Wires
Think car audio. By upgrading the ground wires you alleviate the load on the charging system. Using a heavier-grade ( larger diameter) wire, you reduce the amount of electrical resistance. Since 12 volt electrical systems pull from ground, using this product makes sense and it does make dyno-proveb power..
52.Indexing Spark Plugs
This can be costly, plug wise, but worth it in the end. Using a marker pen, mark the procelain inline with the electrode. Screw the plug in the head and tighten. Make sure the mark aligns the way you want the opening of the electrode to face, favoring the intake valve. Indexing can be adjusted with various thickness washers or try more plugs. The are not all the same thread-wise.
53.Windage Tray
This decive is both simple and effective and, with some thought, you can fabricate your own. Basically, a windage tray keeps oil from spalshing up and hitting the crank, which effectively tries to slow the crankshaft, reducing power. Keep the oil in the pan!
54.Oil Pans
There are several companies making alloy oil pans for Honda, Mazda, Dodge, Toyota and Mitsubishi. These pans have a kick-out sump that keeps oil from splashing on the crankshaft. (Some will have a windage tray so if you have such a pan, eliminate tip 53.)
55.Short Shifters
Short shifters like B&M shifter enable quixker firmer shifts by reducing the amount of time required to select a gear. Positive shift stops are also helpful, but be sure to set them properly.
56.Acura Type R Shifter
This shifter is the weapon of choice. Pros such as gary Gardella call it " the best short shifter for a honda, especially for drag racing".
57.Cutting Off The Fuel Cut-Off
There are electrionic devices available that bypass the factory fuel cut-off limit on turbocharged vehicles. By using such a device on your modified engine, you can more boost with out having the fuel cut out on you. A very popular mod in the Supra and Dsm crowd.
58.Honda Shifter Bushings
More ofthen than not, these inexpensive little bushings can cause all kinds of shifting gremlins if worn out. Inspect and replace often.
59. Aligning Wheels
This is a must, especially on older cars or cars that are slammed. It is hard to go fast or for the car to handle properly when the wheels are pointed in the wrong direction or not in alignment with one another. Find an alignment shop willing to play with settings , as opposed to one that will use only the stock alignment specs.
60.Tire Pressure
Having the correct tire pressure on a street/strip car takes work to fight the right combination. Air pressure will be different in street trim compared to dragstrip needs. To nail a great hole shot, pressure will be lower than what is needed for road handling. Work on this one- there's alot of free performance here.
61.Lsd Swap
A great way to put power to the ground is to swap in a limited slip differential from an aftermarket company or if you are lucky, another model of your car for example, an LSD from a 95 Infiniti J30 will fit in a 240Sx.
62.Lose Weight Fast
Weight is the go fast enemy, so try replacing your conventional lead battery with a smaller, lighter gel cell or specialty-sized battery. Stay on top of maintenance, but every pound counts!
63.Octane Boosters
A subject of debate for some enthusiasts, but they do help if you don't have access to high-octane fuel. Forced-induction and nitrous powered vehicles can benefit from these cocktails.
64.Piston Install Tool
A simple tool that keeps piston rings compressed while inserting the piston in the cylinder. This tool prevents rings from being broken
65.Adjust Your Valves
Another routine maintenance procedure that can bring performance gains when done properly. Some vehicles are more difficult to adjust than others. All of them need to be stone-cold engines before any adjustments can be made.
66.Fuel Flow
Upgrading to a less restrictive fuel filter keeps your fuel clean and flowing. Also, be sure your fuel filter is not a restriction. Check this on a chassis dyno, using an adjustable fuel pressure regulator to help fine-tune your modified engine.
67.Reputable Tuner
This is a no brainer: your ride will only perform as well as it's put together and tuned. Spend the time and reserach tuners in your area. Talent comes with a price, so be prepared to pay if you want the best!
68.Ice
Very simple and free! Free our other favorite word other than sex. At the dragstrip a bag of ice placed on your intake manifold or intercooler can net you a few ponies, some days more.
69.Thermal Coatings
These products work the same wasy as header wrap, except it looks nicer and it lasts longer. In addition, the applications aren't only limited to exhausts. pistons and intake manifolds can benefit, too.
70.o2 Sensor
This sensor moniters the emissions of your engine and determines weather the engine should run richm leak or stoic. When the sensor wears out the car may go into "limp home" mode, where performance is noticeably decreased, but the car is able to be driven. Inspect every year and replace as necessary.
71.Rocker Arm Stoppers
This is something that is mainly used on Nissan Sr20Det engine. This product helps control valve-train floating at high rpms.
72.Reset Your Ecu
Some vehicles can benefit by resetting the ECU after performance modifications have been performed. This can be done by removing the ECU fuse for a period of time, then replacing it. If your vehicle has a knock sensor an the vehicle has ever detonated in its life you should reset this from time to time, it can place you into a "low power" mode. This is applicable to OBD-I.
73.Indexing Camshafts
Considerd crucial to making power when installing aftermarket camshafts, in actuality any cam must be properly inxdexed ( to the bottom end). As aftermarket cam profiles can be different from stock, advancing and retarding the cam(s) can also be effective.
74.Phenolic Spacer
This device can be made easily out of an non-metallic material. The idea behind this is to that it keeps the cylinder head from heating up the intake manifold.
75.Upgrading Your MAF
While this may not be applicableto all vehicles, it does work on some. By upgrading your MAF to one that is less restrictive, more power can be realized.
76.Truck Style Cooling Fan
Crank driven cooling fans were intended for big V-8s and trucks. If your car comes with one replace it with an electric fan. Not only will you get rid of that "whurrrrr" sound, you will also pick up additional power because the engine has one less accessory to turn.
77.Cam Swap
This is Something that isn't new, but if you are one of the lucky ones, you can benefit from cam swapping with an engine of a different year engine or engine model. One example is swapping out a set of B16a Cams for Type-R cams.
78.Swap The Hot Cam
like the previous tip, it is possible that the exhaust cam has a more desireable profile. This swap can be done by re-pinning the cam sprocket on some engines; on others it's even easier. See your engine technician and talk exhaust cam specs. You'll see what I mean.
79.Wheel Balancing
Drag racers have found this out the hard way; road racers have been doing it for years. Rather than statically balance (bubble balance) wheels, dynamically balance them. Drag racers have picked up as much as a .10 on the quarter of mile.
80.Knock Sensors
This is not for EVERYONE. Some owners in the 350z community have disconnected their knock sensors and picked up close to 10 hp. Apparently, the knock sensors are very sensitive to vibrations and pull timing back considerably. thus reducing power output.
81.Blizzak Racing
This is the power man's drag rdial. The soft compound of these tires gives you great grip at the cost of people laughing at you..
82.Two Step Rev Limiter
This feature comes with aftermarket ignitions, but it can be pruchased separately as well. This device helps build boost on the line by spooling the turbo and acts as a launch control by enabaling you to launch at optimum rpm
83.Copper Seal
This high temperature gasket maker is handy when building a custom turbo kit, as it can be used as added insureance against power robbing exhaust leaks.
84.Dust Off
This is a compressed gas that is found in art supply stores, used for dusting off art work with out touching it. In our case spraying it on the parts that need to be cooled, i.e. the intake manifold.
85.Transmission Fluid
If you change the type of fluid in your automatic transmission, this could result in better shifts. The accumulators react faster, allowing the various clutch controls to react quicker. This is due to the viscosity and friction modifiers in the fluid. Try it next time.
86.Titanium Wheel Nuts
These are more expensive than regular lug nuts, but when you weigh all the lugs together, they do help reduce un-sprung weight. Enough attention in these areas and presto- you got yourself a serious diet.
87.Titanium Exhaust
The same goes for lightweight titannium mufflers and exhaust systems. While it isnt as exotic as it sounds and is more expensive than stainless, it's also lighter. Less weight is better and if you can't afford it all at once start with mufflers, add the pipes.
88.Dont Drop the Plugs
When installing spark plugs in OHC enegines, its easy to drop the plug down the hole, potentially bending the electrode and altering your preset gap. To avoid this, try using a length of rubber or silicone tubing to pass the plug and get a few turns before using a socket.
89.Rear Camber Adjustment
If you have access to a die grinder, you can grind out a portion of your rear upper control arm so that you have a little more adjustment. You will notice the interference to be removed.
90.Intercooler Spray
Using a set of injectors or washer nozzle spray and a remote reservoir filled with a mixture of water and alcohol, you can make your own IC spray for verry little outlay.
91.Yank The I.C.E.
If your going racing, pull out the audio system in the back. This can save you 50 to 100 pounds by removing it. IF its a dual purpose ride, install the equipment with quick disconnects, so it is easily removed.
92.Water Injection
A fine mist of water spray is injected into an en engine to help reduce the chances of deonation. A great addition to any forced-induction enegine, but again check fuel/air curve and overall boost on a dyno.
93.Stop Blowing Hose
Conventional worm gear clams dont do a good enough job of holding intercooler piping together. By replacing them with T-bolt style clamps you will be liess likely to toass a hose under boost.
94.Obd-II Data Logging
There are programs available for your Palm Pilot that actually allow you to read date acquired from the OBD-II ECU. This is useful when you have upgraded your car and want to see exactly what the ECu is doing. Programs such as Pocket Logger are available for both OBD-II and OBD-I.
95.Claim Your Tools
IF you work in a busy shop, it's easy to confuse your tools with someone else's. To avoid this, do something unique, like painting your tools a different color or add stripes, etc, to avoid arguments.
96.Shoe Polish On Tires
This works for both autocross and drag racing. If you want to see how much side wall rollover you are getting or how much contact the tire is marking during a run, make a band with whith shoe polish along the outside of the tire. After the run you will see how much is less, which will tell you what the tire is doing.
97.Relocated Battery
Not only does this clear up clutter under the hood but it makes it easier to plmb intercooler piping , etc, IN some cars like AWD and RWD vehicle, it also can help traction.
98.Increase Cooling Capacity
Do some research- you may be surprised to find that there is a larger radiator from a different vehicle that will fit your application. The improved cooling capacity will increase with the lonevity of your enegine by keeping it cool. This is especially ture if modified.
99.Atmospheric Waste Gate
Not environmentally sound, but it yields decent power gains. The street-legal way to do this would be to have a flapper valve that is controlled from the inside, which switches from atmospheric to non atmospheric. Usually good for 0.3 Second in the quarter.
100.Stainless-Steel Brake Lines
Everyone knowns about this mod, but it is worth remembering that by replacing your flexible rubber lines with braided lines, your brake pedal will feel firmer and more responsive. Remember too, high performance racecars do not use rubber brake hose!
101.86-87.5 Mazda Rx7 Injectors
These babies are 550cc low impedance injectors that can be found at resonable prices in wrecking yards. They should be cleaned and flow balanced before use!
102.Silicone Coolant Hose
Yes, they look pretty but they also outlast conventional rubber hoses and are resistant to both oil and ga.. Sounds like an easy decision to me.
103.Lose The Side Mount IC
Some cars such as the Talon/Eclipse,Croarado G60, and SR20Det equipped vehicles come with side mount intercoolers. Take a trip to the wreckers and look for an intercooler from a Saab 900, Isuzu cargo truck, Audi 5000 turbo or Mitsubishi Starion. All of these intercoolers are cheap and can be used as front mounts for better cooling of the air charge.
104.Intercooler Pipes
If your car comes with plastic or rubber intercoolers pipes, upgrade them to alloy or stainless steel piping. The factory piping expands consderably under boost and that air presssure would be better served in the combustion chamber.
105.Ported o2 Housing
This will work on just about any turbo machine that has this sort of setup. By porting the O2 housing the exhaust flow will improve, thus allowing the turbo to spool quicker..
106.Stainless Steel Clutch Lines
If bradied stainless steel lines work for the brakes and you have a heavy duty clutch and pressure plate setup, then you should consider upgrading the pressure line that runs to your slave cylinder with braided stainless line.
107.Carbon Fiber Panels
Replacing heavy steel panels, including trunk lids and hoods, with real carbon fiber units is an easy way to upgrade the look of your ride while saving weight. You will seem more CF use over time.
108.Chill Out
Using an intercooler spray bar can net you a horsepower gain by simply spraying nitrous oxcide or carbon dioxide over your intercooler to lower the surface temperature of the fines. This has the effect of :icing) down the intake charge.
109.Cooler Oil
This is a definite must have if your car is force-fed by a turbocharger. We all know that oil is the life to your enegine and the better condition you keep that oil, the longer your engine will last. Keeping your oil cool and installing aftermarket oil cooler directly in the air stream is one of the best ways to protect your investment.
110.Honda Fuel Pressure Regulator Mod
The stock FPR is restrictive when the times comes to extract more performance from the engine. The restriction is in the return orifice. This problem can be solved if you drill a 0.35 inch hole slightly angled toward the return port of the regulator. This mod helps alleviate some of the pressure caused by the restrictions at low rpm levels.
111.Wheel Key Upgrade
If you have tuner style lug nuts on your wheels, they could have some cheap key to remove them. These keys can eventually strip and /or destroy your lug nuts. Do yourself a favor and head to the hardware store and buy an Allen bolt socket set that fits and removes your lug nuts. A stocket wont strip like a key will.
112.Supra TT Or 3000Gt Vr4 Fuel Pumps.
If you can find a wrecked example of thse cars, first mourn the loss and then grab the fulel pump. These things flow extremely well and make a great intake upgrade for those that are budge-minded
113.Speed Clip The Throttle Linkage
This works well in old school VW's that have a secondary butterfly in the throttle body. By installing either screw or speed clip in the linkage you can open the secondary butterfly sooner, thus reaching full throttle sooner. Great for drag racing.
114.Fuel Line Hose Clamps
Get rid of those conventional, worm gear hose clams and replace them with proper fuile line hose clamps. The worm gear clamps actually cut into the hose and can lead to leaks and even worse, a fire. Don't fool or shortcut the fuel system.
115.Skinny Track Tires
A cheap solution for front runners or rear runners on drag machines or weekened warriors is to head to the wreckers and look for a spare tire from a Ford Thunderbird Turbo coupe. These are alloy wheels that are light and can be fit with legal front runner tire from your favorite tire company. You can also use the spare from a third generation Rx-7s and fit either skinny or motorcycle tire on it, if you have a five bolt pattern.
116.Delete The Front Sway Bar
This sounds crazy, but for some drivers, they feel their cars actually handle better with out the front sway bar.....
117.Apexi Super AFC
This product is so popular amont enthusiast that I just had to include it. Thse can be pruchased for new or off the net at low prices and allow you to extract considerable amounts of power from your setup with careful tuning
118.Lightend Flywheel
By replacing your stock flywheel with a lighter design, your engine will be noticeably more responsive and more willing to rev. Note: on some engines there may be some extra vibrations, but that's nothing that the benefit doesn't outweigh.
119.Goop Adhesive
If you are in a jam and need to temporrarily repair something on your car, this product has worked wonders. Plus it's cheap.
120.Zip Ties And Vacuum Lines
Loose vacuum lines can cause more problems than you can imagine plus they are a pain to find, too. MOre often than not, a line has siply slipped off. Using a small zip tie on the end of each hose will fit this problem.
121.12 Volt Treble Light
If you tend to take long trips or like to race at night, a treble that be connected directly to your battery is a life saver especially when wroking under pooor light conditions.
122.Remove 2g Bov Tube
This will make your blow-off valve more responsive by simply removing the secondary tube.
123.Lisele Panel Remover
This is another handy tool and one that is available at auto parts stores. This tool allows you to removed panels while minimizing the chances of breaking them or fasterners that secure them.
124.T-Taps And Scotch Locks
It may not be a good idea to use these types of easy fix items in high performance applications, since they can cause more headaches than you can imagine later on. Spend the time necessary to solder your connections then they are permanent fixes.
125.Baffled Oil Catch Can
Having oil enter the tintake tract can skew emmissions and even lead to deonation. By using an oil catch can that has baffles or breather, you can avoid this problem. This will also allow you to runa few more pounds of boost over a stock PCV-equipped car.
126.Restrictions On Boost Controller
On the Dsms you can remove the restrictor on the stock boost controller, which will enable more boost to be creaded on the stock setup.
127.Aftermarket Honda Cam Seal
These seals on the B-series Hondas are notorious for leaking and making a mess under the hood. Replace these stock seals with an aftermarket design (available from numerous companies) and you can easily solve this problem.
128.Cam Angle Sensor
If you swap out a first generation Dsm cam angle sensor and install it on a second-gen Dsm, you will be able to run more timing, which in turn will give you more power. A word of warning: this may turn on the 'check engine: light on occasion.
129.Check Ingnition Wires
If you are unsure as to the condition of your ignition wires, perform this simple test: take a spray bottle full of water an while its running, spray the ignition wires. It shoul dbe somewhat drak when you do this test. If you see arcing, you know that its time to replace the wires.
130.Torque Wrench
Every do-it-yourself mechanic should have one of these and learn to use it religiously. It can even be used on spart plugs. Everything on your car has a specific torque rating. Learn and use them!
131.Molyslip, Copaslip
This product is great for lubricating caliper sliders, as it will not clump up or corrode like some lubricants. As in any product, be sure of its application purpose, heat tolerance and its ability to lubricate throughout expected exposure.
132.Brake Proportioning Control
Want to have absolute control over your braking bias? Instale a bias controller that is adjustable from insted the car. Theres's also the wilwood proportioning valve, which is adjustable front to rear
133.Tire Pressure Gauge
Keep one of these inexpensive tools in your glovebox and check it religiously. For optimum performance and tire life, its essential that proper air pressure be used for the tire, rim width and the type of performance to which the tires will be subjected.
134.Piston Swap
Cross breeding occurs in all enthusiast groups. For Nissan 240Sx fans, you can take the Ka24De pistons and put them in a Ka24E for an increase in combustion: Type-R pistons in GS-R enegines and so on. Going with a high compression piston will give you a mild bump in performance, but check piston to valve clearance.
135.Disable Speed Cut
On the 240Sx the speed limiter is set at 115mph. If you race at the track and can exceed that speed, but the ECU wont let you, there is away around it. By unplugging the speed sensor on the transmission, you will loose your speedometer and cruise control, as well as the limiter but you'll go faster
136.Cheap Bolts And Tower Bars
Unless you shell out good coin for strut tower bars, chances are that the ones you have equipped with cheap weak bolts that will no doubt strip or break. Head to your local hardware store or fastener store and buy some hardened bolts. Look for five marks on the head of the bolts, noting that they are grade 8.
137.Purge
If you have a nitrous system, spend the extra coin and buy the purge valve. Not only does it look cool but it also allows the nitrous to hit sooner once the line is purged of any liquid. Best thing is to purge the nitrous a few times before you are about to launch.
138.Pretty Plumbing
If you have a direct port nitrous system and want to have a fancy plumbing, you need a line bender. Two different size radii can be made with this bender and it's fun doing it.
139.Oil On The Oil Filter
Have you ever had to really struggle to remove an oil filter? Solve this problem next time by applying a dab of oil on the rubber gasket that is located on the filter seal. This will help keep the gasket from drying out and will make removal easier next time.
NOTE: NOT ALL OF THESE WORK FOR THE ECLIPSE, SOME OF THESE CAN BE DETRIMENTAL TO YOUR CAR IF USED IMPROPERLY, I TAKE NO RESPONSIBILITY FOR ANYTHING YOU DO.
thats in caps for a reason
Old June 24th, 2011, 10:07 PM   #2 (permalink)
Sin
Bitches Love a Sinner
Sin's Avatar
Vehicle: 2008 SE-X
Sin is a glorious beacon of lightSin is a glorious beacon of lightSin is a glorious beacon of lightSin is a glorious beacon of light
150?
Sin is offline   Reply With Quote
Old June 24th, 2011, 10:56 PM   #3 (permalink)
Has A Big Member
stangcobra's Avatar
the thread was called 150
guess theres 139
Old June 25th, 2011, 12:08 AM   #4 (permalink)
nice! some of these are obvious and no-brainers - but a lot of people are new, to cars and/or modding. some just like to have shit spelled out for them, so this seems like just the thing for them. +erep
Old June 25th, 2011, 03:41 AM   #5 (permalink)
theBIGone
SMeclipseGT's Avatar
Vehicle: 2006 Eclipse GT-P
SMeclipseGT is just really niceSMeclipseGT is just really niceSMeclipseGT is just really nice
#43 is interesting someone care to be the guinnea pig bahahha
The Silver Beast
http://club4g.org/board/members-ride...tml#post523843
SMeclipseGT is offline   Reply With Quote
Old June 25th, 2011, 07:15 AM   #6 (permalink)
Sin
Sin's Avatar
Vehicle: 2008 SE-X
guess theres 139
It was a good read and I was just curious if there was more. Oh well. I guess numbers 140 to 150 are all hp gains from sticker mods anyways.
Old June 25th, 2011, 01:46 PM   #7 (permalink)
NitroGlisson's Avatar
Worth reading.... thanks for posting it....tried to e-rep but you know that story.
Old June 25th, 2011, 01:48 PM   #8 (permalink)
Has A Big Member
stangcobra's Avatar
Yeah I know man, it's chill, not looking for rep, just want people to have these available to them
Old June 25th, 2011, 02:08 PM   #9 (permalink)
Perfection over power
Elemenohpee's Avatar
Vehicle: 06 GS-Turbo
I used to use #45 all the time when I would snorkel or free dive lol
Old June 25th, 2011, 03:27 PM   #10 (permalink)
Vehicle: 07 eclipse gs-n
ive done that one on my pathfinder and celica before with no issues.
accessories, aftermarket, air filter, body, bumper, car audio, carbon, custom, eclipse, event, exhaust, fix, gauge, good, headers, heat, hood, kit, light, nitrous, parts, pick, street, wheels, wrecked
