Old July 18th, 2011, 08:35 PM   #1 (permalink)
4GALTOONA
4GALTOONA's Avatar
Vehicle: 2008 ECLIPSE GS
4GALTOONA is on a distinguished road
Throttle Body Whistle
I installed the gt throttle body and it whistles on and off when i get to around 2 gear. Does this effect the performance at all?
4GALTOONA is offline   Reply With Quote
Old July 18th, 2011, 08:39 PM   #2 (permalink)
deprydation's Avatar
Depends on what kind of whistle. If you aren't getting a proper seat between the manfold and the throttle body then you're leaking air which could cause some whistle.
Make sure your gaskets are good and everything is good-n-tite.
this guy is a cunt rag
Old July 18th, 2011, 08:43 PM   #3 (permalink)
4GALTOONA
4GALTOONA's Avatar
Its not constant. I just might get a new gasket and see if it still does it.
Old July 18th, 2011, 08:46 PM   #4 (permalink)
Do you have a throttle body spacer on it?
Old July 18th, 2011, 08:47 PM   #5 (permalink)
Black Irish
muscles's Avatar
Vehicle: 2006/eclipse/gs
its supposed to make that turboish sound. If it only opens up around those rpms you are fine. But go ahead and check to make sure everything is nice and tight that can never hurt.
Old July 18th, 2011, 08:54 PM   #6 (permalink)
OWNER OF C4G
Vehicle: 2008 GT-SC
Smoke test maybe???
TEAM BIG SUPERCHARGEERS
Old July 18th, 2011, 09:30 PM   #7 (permalink)
meDave's Avatar
Vehicle: 06-GS-Titanium Pearl
meDave is just really nicemeDave is just really nicemeDave is just really nicemeDave is just really nice
You might just need to put a lil sealer on the gasket. I used carb cleaner to find the leak I had when I installed my Intake manifold spacer. Sprayed around the area with the car running, and it sputtered when I hit the area that was leaking.
Performance: AEM F/IC w/ BilletProof PNP Harness, AEM UEGO Wideband, 2.5" Catback Exhaust w/Dual Outlets, Fujita CAI, Ported Intake Manifold with GT TB Swap, Ralco RZ Short Shifter, RPW Thermal Spacer Kit, RRE SS Race Header
Suspension: Evo Brembo Swap, Front: Cusco Strut Tower Bar, Custom Tein Coilovers with D2 Camber Plates Rear: Eibach Sportlines Springs, KYB GR-2 Shocks
meDave is offline   Reply With Quote
Old July 19th, 2011, 06:13 PM   #8 (permalink)
snakeeyes's Avatar
Name: Loves haters !
Vehicle: 09 5 speed manual
its normal, you dont need gasket sealer on the tb gasket.
Modified
body, gear, gt throttle body, performance, throttle body
