Rep Power: 3 ![]() |
Rear catalytic
I just took out the rear catalytic bc my front one broke and I guess it clogged up the rear one my car was riding shitty and I was getting so pissed so I bought the front catalytic and cut out the rear one and my car is running a lot stronger. I did not know that rear catalytic holds back so much power. Now am ready for the next step in power increase
Loves haters !
09 5 speed manual
with the rre header.the dyno showed 159 hp.after the removal of the 3rd cat.the dyno showed 172 hp.take it for what its worth
Modified Last edited by snakeeyes; July 30th, 2011 at 11:17 AM. |
Huge Member
Steve
2006 Eclipse GT-N
When I took all 3 out I noticed such a big gain in power and it felt smoother
travis
07 eclipse gs-n
same here. plus you get to smell all of that uncleaned exhaust coming out
travis
07 eclipse gs-n
there are 2 precats in the header and a third in the piping.
Ohh ok yeah now under stand I was counting the 1st 2 as one since there together. I would change the first one an add the headers but i was told the check engine light would come on bc of the sensor and check engine light is annoying! Is that true?
travis
07 eclipse gs-n
spacers on the post cat o2 sensors will eliminate that from happening.
2009 4G69
wut about a high flow cat . . does that make a big difference as well compared to stock. . and u dont get engine light with high flow cat do u
travis
07 eclipse gs-n
the third cat isnt monitored so no light.
2009 4G69
oh seriously . . but u would still fail inspection right . . if not imma rip that b!tch out
Cesar
2008 Generic Veyron
i always get confused at this, so, in order, its 2 precats in the manifold, the "3rd cat" immidiately after the manifold, the resonator, then the muffler, correct?
Cesar
2008 Generic Veyron
is the third cat bolted onto the manifold, or is it, manifold>pipe>third cat? i ask cuz if its manifold then pipe, then my shop will tear it out, if its bolted on, well then its a bit of a pickle
2009 4G69
ur headers bolt on to the beginning of the y-pipe of course . . then the end of the y-pipe has a bolt on clamp/gasket thing that connects to the 3rd cat . . no more bolted pipes after that . . depending on wut ur setup is now its either just clamped or welded
08 Eclipse GT - SC
^in some states yes, in some no. but what do I know? OKlahoma has no such bullshit to deal with.
#20 (permalink) |
travis
07 eclipse gs-n
yeah you can pass with no cats in pa
#21 (permalink) |
Cesar
2008 Generic Veyron
what will this do to the sound of the exhaust, i dont wanna sound like a fuckin honda
#23 (permalink) |
2009 4G69
and yes if headers / 3rd cat delete / magnaflow catback does not sount like rice being shaken in a can then i will def remove the cat
#24 (permalink) |
Cesar
2008 Generic Veyron
i has no header, just straight pipe and muffler no resonator
anybody wanna chime in on the 3rd cat sound result?
#25 (permalink) |
Loves haters !
09 5 speed manual
no header,3rd cat delete,stock rear resonator and a universal mag.deep,no drone,no rice sound here.sounds great,especailly under a bridge during aclleration.worse case scenerio,try it,dont like it,put it back on
Modified |
#26 (permalink) |
Cesar
2008 Generic Veyron
sound clip bro??
#27 (permalink) |
Loves haters !
09 5 speed manual
dont have one right now.what i can tell you is if you dont have a universal mag,it will be loud ! hence the reason i had to go back to the muffler shop 3 times before i was happy.do you still have your oem res ? if so put it back on and it will sound good depending on the muffler you have.the mag muffler is where its at toning down this engine
Modified Last edited by snakeeyes; July 31st, 2011 at 08:09 PM. |
#29 (permalink) |
2009 4G69
i have the magnaflow resonator on the cat-back exhaust so that should help keep the sound from being rediculous . . im bout to do this . . so will i just need to weld a pipe on where the cat was or can it b clamped . .and should i replace the entire pipe ( from y-pipe to resonator) ??
AEM FIC / UEGO Wideband + POD / Custom Bolted Last edited by FeaRlezZ; July 31st, 2011 at 08:36 PM. |
#30 (permalink) |
Loves haters !
09 5 speed manual
so you have dual exhaust and 2.5" piping ? if so,you better leave it alone or dont make it permanent until you have tested the performance of the car
Modified |
#32 (permalink) |
Loves haters !
09 5 speed manual
then yea,just weld a straight pipe the same size as the rest of the piping in its place.leave your self some welding room on the pipe in case you want to put it back on
Modified |
#33 (permalink) |
2009 4G69
^ do u have the same setup as me snake . . headers / 3rd cat delete ( im about to do ) / and magnaflow cat-back
#35 (permalink) |
2009 4G69
well i feel comfortable removing it so thats wut i will do . . stock piping is 2.5 or 2.25 ?? how tha fuk did i forget
| back, car, catalytic, power, rear |
