Old July 30th, 2011, 09:05 PM   #1 (permalink)
G-TuneD...
PearlGreenNMean's Avatar
Vehicle: 2009/Eclipse/GS
Custom Stock intake??+headlights
Note: I did search, and found nothing for a few pages. Even googled -_-
So I've been throwing this idea around to drill like 1 1/2 inch holes after the filter in my stock intake. My dads racing friend said that people actually do that. So did the guy at Napa.
Also, should I remove the spout that comes out too, or just leave that there?
Also, My headlight mounts are broken on both sides. How would I be able to raise them/ keep them/ measure them back to where they were? I can take pics on what it looks like. The bracket thingy on top is broke. Thats the only bracket broke on both.
Thanks - George.
SOON: Turbo Kit... GT25
Old July 30th, 2011, 09:06 PM   #2 (permalink)
Vehicle: 07 eclipse gs-n
what would be the point of the hole
Old July 30th, 2011, 09:07 PM   #3 (permalink)
G-TuneD...
To receive more air...?
Lol.
Old July 30th, 2011, 09:09 PM   #4 (permalink)
your by passing the filter so you better hope its not dusty or dirty where you drive. and you will expose the intake to more hot air
Old July 30th, 2011, 09:10 PM   #5 (permalink)
G-TuneD...
Nooo man. After the filter... Like the side closest to the bumper.
Old July 30th, 2011, 09:13 PM   #6 (permalink)
Celer, Silens, Mortalis
jarhead0321usmc's Avatar
Vehicle: 2006 GT
jarhead0321usmc is a jewel in the roughjarhead0321usmc is a jewel in the rough
Umm why dont you just get a cai or sri for more air? That way you still have the oem one, so if something breaks you can do a quick swap and still bring the car in for warranty work, without having to worry about them refusing to do the work cause your intake is drilled out.
jarhead0321usmc is offline   Reply With Quote
Old July 30th, 2011, 09:15 PM   #7 (permalink)
G-TuneD...
Because, sadly enough, I can't afford it. Being 17 is horrible when looking for jobs. Why you have to be 18 to be a pizza deliverer? Idfk.
Old July 30th, 2011, 09:43 PM   #8 (permalink)
Vehicle: 2009 4G69
so u drill holes after the filter meaning that unfiltered air is going into ur engine . . . plus this seems like it would cause air to leak instead of intake .
Old July 30th, 2011, 10:04 PM   #9 (permalink)
snakeeyes's Avatar
Name: Loves haters !
Vehicle: 09 5 speed manual
drilling holes wont make any difference dude.the stock air filter is a big ass pillow restricting air flow.
Modified
Old July 31st, 2011, 01:03 AM   #10 (permalink)
meDave's Avatar
Vehicle: 06-GS-Titanium Pearl
meDave is just really nicemeDave is just really nicemeDave is just really nicemeDave is just really nice
You should of bought the CAI before you bought a header. Basically what you have done is put the plow before the horse.
I do not know the emission laws of your state, but it is not wise to cut up/throw away your stock parts, as you may need them later on in a few years and have to scramble around try to search and buy them again.
How did you break your tabs? do you still have them? you can try some plastic weld and glue them back together. If not... zipties are your friend.
Performance: AEM F/IC w/ BilletProof PNP Harness, AEM UEGO Wideband, 2.5" Catback Exhaust w/Dual Outlets, Fujita CAI, Ported Intake Manifold with GT TB Swap, Ralco RZ Short Shifter, RPW Thermal Spacer Kit, RRE SS Race Header
Suspension: Evo Brembo Swap, Front: Cusco Strut Tower Bar, Custom Tein Coilovers with D2 Camber Plates Rear: Eibach Sportlines Springs, KYB GR-2 Shocks
meDave is offline   Reply With Quote
Old July 31st, 2011, 03:18 AM   #11 (permalink)
redlenses's Avatar
Vehicle: 08 GT Spyder
redlenses has a spectacular aura about
Might want to try this before you start cutting holes in things:
Quick easy (FREE) performance tip 3.8L
I'm assuming the GS & GT intakes are similar, but I could be wrong.
redlenses is offline   Reply With Quote
Old July 31st, 2011, 03:06 PM   #12 (permalink)
snakeeyes's Avatar
go with a real intake !
Modified
Old July 31st, 2011, 05:06 PM   #13 (permalink)
snakeeyes's Avatar
sure the air filter will get warmer with the ac on.how many of you race with the ac on .
Modified
Old July 31st, 2011, 05:07 PM   #14 (permalink)
yeah any further down on the auto or over will result in lots of heat
Old July 31st, 2011, 05:09 PM   #15 (permalink)
snakeeyes's Avatar
fact !
Modified
Old July 31st, 2011, 08:12 PM   #16 (permalink)
Has A Big Member
stangcobra's Avatar
Vehicle: 01 svt cobra
Pearlgreen, you need to just save up for a real intake, doing anything ghetto on these cars is just asking for massive failure, they arent ae86 corollas or 240sx where you can basically do whatever you want and make power(lol I know I'm wrong here). Buy real performance parts that everyone uses and knows about
Old July 31st, 2011, 08:25 PM   #17 (permalink)
snakeeyes's Avatar
lol,i did what i wanted for 19k hard miles with different custom intake setups.car runs like the day i bought it.only reason i started doing that dumb shit was because of the stickie thread pertaining to heat with a sri.regardless,my injen sri is on its way....lol.so in point,there is no reason to make a custom intake on the gs.either get an injen sri or dc,fujita cai.
Modified
Old August 1st, 2011, 11:50 PM   #18 (permalink)
G-TuneD...
Haha I should of bought both at the same time, but we all dont have money like that brother.
Accidents, and we did plastic weld, still not the same... I was thinking paint stick paddle things between the headlight and bumper... idgaf about appearance. lol. Zipties... I wanted to do that, but i didnt know where to place them?
And thank you to all who posted.
Old August 1st, 2011, 11:52 PM   #19 (permalink)
G-TuneD...
I've read on here that sri is actually better for the gs than a cai... with gains of 15 hp~ vs 9 hp...
So an Injen sri huh? Still about 250$ though right?
Old August 1st, 2011, 11:54 PM   #20 (permalink)
G-TuneD...
drilling holes wont make any difference dude.the stock air filter is a big ass pillow restricting air flow.how much money do you have to spend ? do you have any cutting power tools ?
you can make one that will work pretty good for about $80.you will however need to use the oem maf holder pipe.last couple of days i have been doing more experimenting eliminating the box alltogether(was using it as a heat shield and works great when moving) and pretty much positioned it like the injen sri.turns out,thats some pretty good positioning on the gs.i still and will allways have the snorkel hooked up.i dont have a pic of this in my album atm,but you can get the idea of how you can make one.i have an injen sri coming in the mail to test that bitch out to lol
And where did you get you injen sri, and how much? I'll get serious about it if i land this job...
Old August 2nd, 2011, 08:23 AM   #21 (permalink)
snakeeyes's Avatar
i paid 149 shipped for a used one.
edit; got it in today,installed it on my lunch break and even in 97 degree heat,the car pulls a little faster over any custom sri i made lmao.
Modified
back, bracket, broken, custom, filter, headlight, headlights, intake, mounts, pics, racing, remove, stock, top
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
