Old August 9th, 2011, 01:31 PM   #1 (permalink)
Vehicle: 2009 Eclipse GS
usarmy2011 is infamous around these parts
Oil filter replacement
Okay so im doing this oil change myself this time.
90 bucks for full synthetic oil change at local shops is not worth it.
Got Mobil 1 full synthetic 5 qts
K & N oil filter Ive tried searching if there is any gains from using it but all i see is people Claming 3-6 horsepower and 3 mpg increase.
W.e
I found the filter location, Ive searched for the tool i need. Anyone have an opinion what works better to remove the old one? Oem Tool or a Steel band wrench? like this one OEM/3 7/16 to 3 3/4 in. swivel TPR handle oil filter wrench (25371) | Oil Filter Wrench | AutoZone.com
Anything else that Im Missing that would be important?
I see people saying that there are misc o rings or w.e but really do i need to go to the dealership and buy parts for an oil change?
trying to not be completely nooby about this post because i know how much everybody hates anti searching fools.
usarmy2011 is offline   Reply With Quote
Old August 9th, 2011, 01:40 PM   #2 (permalink)
Club4g Bouncer
ussoldier0227's Avatar
1 Highscore
Vehicle: 2007 Eclipse GT, 93 VR-4
ussoldier0227 is a glorious beacon of lightussoldier0227 is a glorious beacon of lightussoldier0227 is a glorious beacon of lightussoldier0227 is a glorious beacon of light
Steel band wrench should be fine. Pretty easy to remove. You can go to autozone and ask for the tools, they'll point you in the right direction.
The Sleeper 4g.
RRE Headers, Magnaflow Cat-back, TB Bypass, Intake and TB spacers, Ingalls Stiffy, Energy motor mounts and bushings, CM Stage 3, Injen CIA, ZEX 65 shot, Eibach springs. Purdy Purge kit.
ussoldier0227 is offline   Reply With Quote
Old August 9th, 2011, 01:46 PM   #3 (permalink)
yeah not a problem getting the tools just making sure im not messing around with more parts. Its the first aftermarket part im putting on. Next is a CAI and some Headlights
Old August 9th, 2011, 01:49 PM   #4 (permalink)
Fizzix's Avatar
Vehicle: 09 Solar(Y19) Eclipse GS
Fizzix will become famous soon enough
Well I haven't owned my Eclipse for that long...but I found that my left hand works just fine and no tools were needed for this job at all.
If your oil filter was put on by the Hulk, then you can always try the old "screwdriver through the filter trick".
Good luck.
Fizzix is offline   Reply With Quote
Old August 9th, 2011, 01:50 PM   #5 (permalink)
Club4g Bouncer
1 Highscore
well i also use the k&n filter when I can't get the royal purple one. Also use the royal purple oil.
You'll get addicted modding your car lol. Good luck!
The Sleeper 4g.
Old August 9th, 2011, 02:04 PM   #6 (permalink)
Vehicle: 2006/GT-Manual/Black
glbg is on a distinguished road
I changed the oil on my son's 06 GT, I used the ff:
- cap wrench size F
- Mobil 1 5w-20
- Mobil M1-110
- 17mm socket
-crush ring (got it from the dealer)
-torque wrench (26ft-lbs to torque it)
I normally buy in bulk when Advance Auto Part has it on sale for ~$32 (5 quarts and the filter).
glbg is offline   Reply With Quote
Old August 9th, 2011, 02:41 PM   #7 (permalink)
see i saw people talking about 5w-30 and thats what i got.
I dont know how much a difference that makes but I got that.
Old August 9th, 2011, 05:20 PM   #8 (permalink)
And if this is the first oil change for this engine, the filter will be a bitch to take off. Mitsu stores their engine and/or transports their engines, so they use a sealant on all seals, so if you have the use of, or know someone who owns a gorilla, by all mean use it!!
The torque on the drain plug is 30 ft/lb
Oil filter, lightly coat the new rubber seal with clean oil, hand tight until it seats, then 1/4 turn with the wrench.
Old August 9th, 2011, 06:36 PM   #9 (permalink)
Call me Sparky!
Vehicle: 07 GT
snoeclipse is just really nicesnoeclipse is just really nicesnoeclipse is just really nicesnoeclipse is just really nice
NAPA/Wix filters here. Buy them by the case from a friend who works there, my cost is about $3- each in a case.
Also use a fumoto quick-change oil drain valve (#F-106).
Filter and oil top off every 3500 miles, complete oil change at 10500 miles.
M1 5-30 full synth.
07 GT Sportronic, Deep Red Pearl. I like the 6G75 just like it is, the sportronic really does need a real mechanical LSD though. Back from a nice unexpected tour extension; home for good I hope!
snoeclipse is offline   Reply With Quote
Old August 9th, 2011, 08:20 PM   #10 (permalink)
th3 salvy_516's Avatar
3 Highscores
Vehicle: 2011/Eclipse/OZ Rally
th3 salvy_516 has a spectacular aura about
i get 5 quarts of RP 5W-20, RP filter, and might as well change the drain plug too
clovisman is right if it's the 1st oil change that filter is a pain to get off
Some say if you tune your radio to 88.4, you can actually hear his thoughts... all we know is, he's called the Stig.
th3 salvy_516 is offline   Reply With Quote
Old August 9th, 2011, 10:39 PM   #11 (permalink)
I did the oil change its not the first, its actually the 3rd. Full synth mobil 1 5w-30 with a K & N Oil filter. took it out for a test run and it is smooth running. Whole process took awhile cause i was just chilling but it worked out.
accessories, buy, filter, handle, horsepower, mpg, oem, oil, oil change, opinion, parts, remove, shops, synthetic, synthetic oil, works, worth it
