Old October 25th, 2011, 04:48 PM   #1 (permalink)
the town body man
Vehicle: 2006 eclipse GT
ice raptor is on a distinguished road
synthetic oil question
so i heard that you can switch from synthetic back to normal oil from some people and that you cant from others. which is true? i dont see a reason why you would want to in the first place but just wondering what is true
ice raptor is offline   Reply With Quote
Old October 25th, 2011, 04:50 PM   #2 (permalink)
Perfection over power
Elemenohpee's Avatar
Vehicle: 06 GS-Turbo
Its not that you cant but that you shouldnt, once you go synthetic dont go back. Someone else can chime in with more info but you just shouldnt do it.
Old October 25th, 2011, 07:44 PM   #3 (permalink)
pat_08GT_Spyder's Avatar
Vehicle: 08 GT Spyder 6MT
i read a lot about that last year...
while this was true in the old days (early days of synthetic), the consensus now is that you can switch back and forth without any issues...
again, just my reading..
pat_08GT_Spyder is online now   Reply With Quote
Old October 25th, 2011, 07:54 PM   #4 (permalink)
yeah, and another tid-bit, I asked a guy at autozone if it mattered if you coudln't or couldn't put in a 'heavier' oil then what is recommended w/out issues, i.e. - 5W-20 (OEM recommended for GT) to say 10W-30. He said you can do that w/ an older engine - but it should NOT be done w/ an engine w/ less then 30K miles on it. Just FYI fellas.
Old October 25th, 2011, 11:00 PM   #5 (permalink)
the town body man
cool thanks for the info guys! im debating on either mobile 1 synthetic or royal purple...leaning a bit twards mobil 1 since from what ive read most people prefer over royal. any thoughts on that?
Old October 25th, 2011, 11:01 PM   #6 (permalink)
I use Mobil 1 Synthetic and love every minute of it
Old October 26th, 2011, 08:43 AM   #7 (permalink)
i use Mobil 1, and i'm not sure how anyone can tell the difference between oils while driving...
maybe my connection with my car isnt strong enough ?
Old October 26th, 2011, 02:58 PM   #8 (permalink)
the town body man
alright i think ill go the mobil 1 way then. getting her a oil change on friday then a tune up later on maybe next week with new plugs
Old October 26th, 2011, 03:05 PM   #9 (permalink)
I think the pressure and temperature levels are affected more than anything, plus in the morning with synthetic a dry start isnt as hard on the engine since synthetic leaves like a layer of.. idk stuff on the cylinder wall. That is what I have been told
Old October 26th, 2011, 03:15 PM   #10 (permalink)
dsm2mivec's Avatar
Vehicle: 06 Mitsu Eclipse GS
Residue ha i think that's the word you were lookin for!
Also synthetic properties are to pick up grime and dirt and carry it to the filter where as conventional is more like spraying something off with a water hose it's kinda just let's it settle at the bottom of that part i.e. The oil pan that is why they say don't switch if I'm not mistaken bc it would clog your oil filter too quickly causing oil pressure variances! If I'm wrong correct me but I'm pretty sure that's what they said at school
Old October 26th, 2011, 05:22 PM   #11 (permalink)
sorry guys, i didnt mean synthetic vs. conventional in terms of "is it better for our engines?", i meant more like some guys saying "oh i run RP because i get so much better throttle response / chicks looks / mileage", comparing one synthetic oil to the other (Mobil 1 to RP)
Old October 26th, 2011, 05:58 PM   #12 (permalink)
choppertwo's Avatar
This is good to know, been thinking about changing to synthetic, but haven't acted on it yet-- CHOP
Old October 26th, 2011, 06:56 PM   #13 (permalink)
Vehicle: 2009 4G69
guys . . . just go synthetic and enjoy it
Old October 26th, 2011, 10:37 PM   #14 (permalink)
the town body man
*salutes* will do captain!
Old October 29th, 2011, 03:33 AM   #15 (permalink)
deprydation's Avatar
Use what the FSM and Owners Manual recommend. Hell, Trevin, you shouldn't even be running a thicker oil. With as tight as the tolerances and clearances are on these engines I wouldn't deviate from the stock oil besides going pure synthetic as these things usually roll off the lot brand new with synthetic blend in them.
Remember, weight of the oil isn't always the problem. If your worried your oil is gonna get too hot or start to boil because of a hot turbo or nitrous setup, you can always add an oil cooler to your car. They're pretty cheap to buy and definitely a good investment. I know I've gone a little off topic here but I've used synthetic since I bought this car and will use it til the day this engine stops running.
this guy is a cunt rag
back, oil, question, switch, synthetic, synthetic oil
