Old November 3rd, 2011, 03:28 PM   #1 (permalink)
hektik skidz, y0
ensiferum0's Avatar
Vehicle: 2006 Eclipse GT 6spd
ensiferum0 is on a distinguished road
weird rpm thing!
Last night, I was driving home and my car started to act...weird. I noticed when I would floor it, the rpms would go from say, 4k to 5k then suddenly drop back down to 4k and rise normally after that. Also, I was in first and steadily accerlerating with like 50% or so on the throttle and the car died? at like 5k rpm. It felt like if you get on the red line and an engine cuts off. It dropped to like 1.5-2k rpm with no throttle response and then came back to life. I do have the cat converter ses and have for like a week. Also, I shifted normally and completely fine on one occasion and it felt funky and I smelled what I assume to be burning clutch. I have never burned the clutch before since owning this car and it is my 3rd manual car. It seems weird that the clutch would just poop out in one night. I gave this clutch the gauntlet when test driving the car and I've REALLY made this baby sweat in the past 3 or so weeks with absolutely zero problems except for last night. I wasn't even driving that spirited last night. Could it be the clutch? I dunno why the clutch would cause the car to die out in first like that, though. Could it be due to the bad cat code it s throwing? Need a tune? Crappy a/f ratio? Those are some general causes I've found online. Anyways, thanks for the help!
Spec stage II clutch, halo projectors, Injen CAI, GReddy EVO 2 axle back, Tanabe front strut tower bar, Eibach springs, rattlecan special stock 18's, Yokohama tires...headers, full exhaust, oem fangs, CF hood, and GSX spoiler coming soon!!!
ensiferum0 is offline   Reply With Quote
Old November 3rd, 2011, 03:43 PM   #2 (permalink)
pat_08GT_Spyder's Avatar
Vehicle: 08 GT Spyder 6MT
how many miles on the clutch? i have never burnt one either, but it sounds like clutch symptoms, from what i've been reading here...
pat_08GT_Spyder is online now   Reply With Quote
Old November 3rd, 2011, 03:44 PM   #3 (permalink)
Vehicle: 2011/GT/6MT
synthetic is on a distinguished road
wow pat you're all over this stuff today
synthetic is offline   Reply With Quote
Old November 3rd, 2011, 03:55 PM   #4 (permalink)
just dont tell my boss...
sorry for the OT man...
Old November 3rd, 2011, 04:29 PM   #5 (permalink)
NitroGlisson's Avatar
Contact Randman.....he burned one out at the track and it was all sudden like that. He might can give you some insight.
Old November 3rd, 2011, 04:29 PM   #6 (permalink)
the town body man
Vehicle: 2006 eclipse GT
ice raptor is on a distinguished road
from what ive read, and heard from everyone, the cats are going to eventually bog your engine down and cause problems so thats half your issue, and if your smelling burnt clutch id check it and check your shift linkage to, just in case. my 3000gt burned out a clutch because of the shift linkage coming undone and that was not fun
ice raptor is offline   Reply With Quote
Old November 3rd, 2011, 08:07 PM   #7 (permalink)
hektik skidz, y0
ensiferum0's Avatar
Well, I drove it today and no problems
I only smelled the weird burnt smell once. I just assumed it was clutch because it was strong and funky. There was no grinding and I haven't felt any grinding. Shifting is still smooth as butter. I haven't noticed any sluggish behavior from my engine other than the weird dying out thar one time. I launched at 5k a couple times today and no slippage. I down shifted a lot and no slippage. I figure that the clutch would slip when launching the car if it's slipping in higher gears. When I notice the weird rise and drop in rpms it isn't when I shift. I can be in gear for a while. It doesn't make a difference. It's when I floor it and only at like 3k+ rpms.
Pat, the car has 78k miles(74k when purchased) I have no idea when/if the clutch was replaced so I'll assume it's the factory one.
Old November 3rd, 2011, 08:13 PM   #8 (permalink)
CF ----> Carbon Freak :)
BPHILLY22's Avatar
Vehicle: 06 Eclipse GT
BPHILLY22 is a jewel in the roughBPHILLY22 is a jewel in the rough
It sounds like the clutch is slipping.. my jus went out like 2 weeks ago Same thing but a little worse, i would jus tap the gas and the rpms would shoot up and back down and the car would go nowhere! it sucks, i took the car to work and the clutch had went out and didnt move (had to tow home) hope this helps man
Carbon King ---->http://club4g.org/board/members-ride...ncreation.html
Originally Posted by STL Eclipse 2011 View Post
and above u is carbon fiber man lol
BPHILLY22 is offline   Reply With Quote
Old November 3rd, 2011, 08:15 PM   #9 (permalink)
BPHILLY22's Avatar
oh and i would park it and have the same smell
Old November 3rd, 2011, 09:17 PM   #10 (permalink)
Willow Spring Racer
wgpengineering's Avatar
Vehicle: 2006 Eclipse GT 6SPD
wgpengineering will become famous soon enough
Could there have been air in the line somehow not letting it fully engage/disengage? These symptoms happened when I raced mine at Willow Springs but my pressure plate actually set up from too much heat. It wouldn't let me engage or disengage at all! When I changed the clutch, all the little fingers on the pressure plate were only halfway up but that's a little different than ur issue lol...
Hope you figure it out bro, good luck...
Mods: Fujita5 CAI, MR coilovers, custom 2.5" cat back w/ electric cutout, rear seat delete, 4-point harness, RRE headers/EGR delete
Awaiting Installation: HX55, twin Turbonetics 35mm wastegates, Turbosmart BOV, FMIC
Buying Soon: F/IC, custom y-pipe/exhaust, boost controller, Stg3 clutch, LSD
wgpengineering is offline   Reply With Quote
Old November 3rd, 2011, 09:21 PM   #11 (permalink)
hektik skidz, y0
ensiferum0's Avatar
It helps but it's terrible news lol. Damn it! I guess new clutch just replaced headers as #1I on my list. I want a staged clutch and I might get an lsd at the same time. Timev to do some clutch research. Any suggestions?
Old November 3rd, 2011, 09:32 PM   #12 (permalink)
BPHILLY22's Avatar
On were to get them? Auto City Imports : Sport Compact Auto & Import Performance Superstore <---- info on them u can search here .. lots of topics on different clutches
Old November 3rd, 2011, 09:32 PM   #13 (permalink)
Willow Spring Racer
Clutchmasters.com or autocityimports.com
I think Autocityimports.com is in michigan so shipping probably wouldnt take very long...
Old November 3rd, 2011, 10:17 PM   #14 (permalink)
hektik skidz, y0
ensiferum0's Avatar
Thanks! You guys rock. I appreciate all of the help!
back, bad, car, cat, clutch, code, converter, cuts off, drop, engine, general, life, manual, problems, red, tune
