Old November 21st, 2011, 05:51 PM   #1 (permalink)
Dexy's Driver
Vehicle: 2006/Eclipse/GS
jasondhimself is on a distinguished road
Throttle Body Bypass Problems
So I searched and didn't really find anything...I did the TB bypass yesterday drove the car hard no leaks...drove it to work this morning and it starts leaking. Took it to a shop, and they fixed it and some how it started leaking again. Took it back and that spliced it, and retightened the hoses. I noticed that those hoses swell pretty bad is this normal. The guy that worked on it the second time said that the hoses on the car are pretty weak and that I may want to have them run one straight hose instead of the splice. Does anyone have on straight hose? Does anyone else's hose swell that bad?....I will see what happens when I drive home.
jasondhimself is offline   Reply With Quote
Old November 21st, 2011, 06:06 PM   #2 (permalink)
Amarillo 4g
DustinH's Avatar
I didn't have to splice mine. I just used the longest of the two and ran it back to where the other hose went. Do away with the splice if its giving you problems. Cheap quick fix to buy another hose.
Old November 21st, 2011, 06:06 PM   #3 (permalink)
hmmm...never heard of this issue before - I guess I'd do whatever the pros are recommending.
Old November 21st, 2011, 06:10 PM   #4 (permalink)
Amarillo 4g
DustinH's Avatar
Old November 21st, 2011, 06:55 PM   #5 (permalink)
Vehicle: 2009 4G69
ya just get one hose long enough to reach both ports instead of joining the 2
Old November 21st, 2011, 08:02 PM   #6 (permalink)
Dexy's Driver
^ I can see where one hose starts but what about the other one how easy is it to get too? btw no leaks on the way home and thats 20 miles
Old November 21st, 2011, 08:34 PM   #7 (permalink)
Vehicle: 2009 4G69
u need to take ur cai off or wutever u have off to have enough room to reach but its down below the drivers side of the manifold
Old November 21st, 2011, 09:03 PM   #8 (permalink)
Dexy's Driver
If it leaks tomorrow I will have them replace it, but if its not broken I'm not gonna fix it. I will look into it tho if its not too much I will probably have it done very soon.
Old December 26th, 2011, 11:49 AM   #9 (permalink)
groundpounder's Avatar
Vehicle: 2008 spider gs
groundpounder will become famous soon enough
Mine worked fine as well
groundpounder is offline   Reply With Quote
back, bad, body, car, drive, problem, problems, shop, straight, throttle body, throttle body bypass, work
