Old November 27th, 2011, 09:57 AM   #1 (permalink)
nokiauser's Avatar
Vehicle: Eclipse GS 5 Speed
Centric Slotted, R-1, or Disc Italia rotors?
I'm prepping myself for a new set of rotors and pads for the 4G 4-Cyl. I need one that has a good balance in price, performance, and looks. But most important, it has to battle through the harsh conditions of winter in the rust belt.
Centric - Slotted: $180 (front) / $125 (rear)
RRE carries them and a lot of you guys might have these. How long have you had them before noticing rust?
R-1 Concepts - Cross Drilled & Slotted: $130 (front) / $92 (rear)
http://www.r1concepts.com/mitsubishi...se-2007-gs.htm
Supposedly, these are good.
Disc Italia - Drilled & Slotted: $245 (front) / $215 (rear)
X Drilled & Slotted - Drilled & Slotted: $155 (front) / $125 (rear)
Performance Brakes - Brake Pads, Brake Rotors and Brake Kits
Does anyone have inputs? Personally, I would support RRE's products just because they've stuck around with us for so long and Lydia is awesome in making all the arrangements go through as smoothly as possible.
Old November 27th, 2011, 12:58 PM   #2 (permalink)
The O.G.
horse-eater's Avatar
11 Highscores
Vehicle: 2006 eclipse GT-TT
horse-eater has a reputation beyond reputehorse-eater has a reputation beyond reputehorse-eater has a reputation beyond reputehorse-eater has a reputation beyond reputehorse-eater has a reputation beyond reputehorse-eater has a reputation beyond reputehorse-eater has a reputation beyond reputehorse-eater has a reputation beyond reputehorse-eater has a reputation beyond reputehorse-eater has a reputation beyond reputehorse-eater has a reputation beyond repute
All of them will be similar, rust happens on any performance rotor but usually just on the contact surface.
I don't have any experience with the bottom 2 on your list, centric is good stuff though.
Under construction! Converting to single turbo, more to come!
Twin Turbo- 338whp/311tq@4psi - Mustang dyno, courtesy PIA in Spanaway, WA.
Panty dropping ability courtesy Forward Motion, Road///RaceEngineering, BrianJ, Delta Cams, Custom Import Heads
horse-eater is offline   Reply With Quote
Old November 27th, 2011, 01:35 PM   #3 (permalink)
Vehicle: 07 eclipse gs-n
i got mine from autocityimports and ive had no issues with mine so far
Old November 27th, 2011, 09:48 PM   #4 (permalink)
deprydation's Avatar
I went through RRE and got the Centric slotted rotors. I have them matched with the stock calipers and the Centric Ceramic pads and my stopping power is amazing. Actually better than my 300ZX with the stock 4 piston fronts and 2 piston rears...
this guy is a cunt rag
$130, $180, 2007, 4g eclipse, belt, brakes, eclipse, good, kits, list, long, mitsubishi, mod, parts, performance, rear, rust, winter
