View Poll Results: Stay turbo or Spray?
Replace the turbo 17 80.95%
Nitrous with headers and tuned 4 19.05%
Voters: 21. You may not vote on this poll
Old January 14th, 2012, 04:54 AM   #1 (permalink)
leet's Avatar
Vehicle: 2006 Eclipse GS-Turbo
leet will become famous soon enough
Exclamation Help me what to do!
Turbo got replaced in April 2011 and now it starting to smoke again. I will go back to RRE but MikeW says another turbo might last long because MIVEC's high oil pressure that causes the seals to leak. So I am thinking of taking out the turbo kit and going nitrous with headers, tuned but I am affraid it will not produce the same numbers.
What you guys think? Keep it or go nitrous.
leet is offline   Reply With Quote
Old January 14th, 2012, 07:17 AM   #2 (permalink)
Got Stance??? i dont :(
MFTK's Avatar
Vehicle: 2009 Eclipse GT
how high are u boosting at?? maybe just tune it down a bit?
Old January 14th, 2012, 08:36 AM   #3 (permalink)
I love To Drift
Animefreak1983's Avatar
Vehicle: 07 Eclipse GT
Animefreak1983 is a jewel in the roughAnimefreak1983 is a jewel in the rough
I'm not a fan of nos. Plus it's not something one would be able to or want to use all the time. A turbo could be.
Also there's no way they can just putt different seals on your turbo?
Animefreak1983 is online now   Reply With Quote
Old January 14th, 2012, 08:38 AM   #4 (permalink)
Vehicle: 2009 4G69
seems like it should b ab easy issue to fix with upgraded seals or something ?? but a different seal may cause drag
Old January 14th, 2012, 08:57 AM   #5 (permalink)
I don't see how it could produce the same numbers. certainly not on a consistent basis. maybe you should look into coated/badass gaskets like the ones TWilson is going with/using for his build. Look at ways to seal the set-up as you go with a new turbo?
To me, nothing sounds like a BOV. End of story.
Old January 14th, 2012, 09:42 AM   #6 (permalink)
Vehicle: 07 eclipse gs-n
i would stay turbo cause it makes you different.
Old January 14th, 2012, 10:48 AM   #7 (permalink)
Black Irish
muscles's Avatar
Vehicle: 2006/eclipse/gs
Turbo. Nitrous won't be the same
Old January 14th, 2012, 10:55 AM   #8 (permalink)
what horsepower are you making with the turbo
Old January 14th, 2012, 01:05 PM   #9 (permalink)
pat_08GT_Spyder's Avatar
Vehicle: 08 GT Spyder 6MT
better seals? i'm sure MikeW and the RRE crew can help you figure that out...
275whp topless
My ride: http://club4g.org/board/members-ride...gt-spyder.html
pat_08GT_Spyder is online now   Reply With Quote
Old January 14th, 2012, 02:36 PM   #10 (permalink)
leet's Avatar
I am suppose to go to RRE whenever I can so MikeW can see it and give me options. Maybe the line is too restricted and needs to be bigger but im no professional. He will give me options. Currently the car is boosting 3.5-4 PSI making around 240whp. Before I was in the high 200's whp at 10.5 PSI. I just know I will miss and regret getting rid of the turbo if I do. I will keep you all posted. I haven't heard of seal kits for turbo's but I will bring that up. Some people told me to use thicker oil 20w and use sealants for those seals but im not sure about that yet.
Old January 14th, 2012, 09:45 PM   #11 (permalink)
Vehicle: 2009 4G69
how well is ur crankcase venting ?? if not vented well enough that could add just enough extra pressure to cause this issue. . . idk just tossing ideas out there
Old January 14th, 2012, 10:18 PM   #12 (permalink)
deprydation's Avatar
Well, I'm not fully sure of the oil pressure that MIVEC runs at, but on the 300ZX twin turbo, I have an oil pressure gauge and it peaks at over 100 psi and I have no problems with blowing oil seals.
Are you using stainless oil lines with a free flowing return line to the pan or is your return line restricted in any way? I know many cars just tap the pan to return oil so it flows as freely as possible, just lubricating the bearings and seals enough to run and not create a huge pressure area inside the turbo itself.
this guy is a cunt rag
Old January 15th, 2012, 06:56 PM   #13 (permalink)
yeah ur making more power then me on a untuned 65 shot. i hit 215whp
Old January 16th, 2012, 08:45 PM   #14 (permalink)
Vehicle: 1991/Mitsubishi/3kgt VR4
Wingo171 will become famous soon enough
I would suggest you check your oil pressure and bounce it off of the factory specs as your Mi-VEC operates on strict oil pressure requirements. Your oil lines to the turbo may also be too small or the return line. Have you considered porting and polishing for taking better advantage of your forced induction? After you find out what's causing the increase in oil pressure you can check out having a port job done to increase the power without having to keep bumping up the boost.
Wingo171 is offline   Reply With Quote
Old January 18th, 2012, 02:39 AM   #15 (permalink)
Or you could try one of the Evo X 16g turbos. They came off of a MIVEC engine therefore already have to deal with the high oil pressure.
Worth a try...
Old January 18th, 2012, 08:05 AM   #16 (permalink)
fabguy's Avatar
Vehicle: 2007 eclipse GT
fabguy has a spectacular aura about
Stay with the turbo. Can't you put a pressure regulator or restrictor to reduce the oil pressure to the turbo.
Mods so far
AEM FIC, TWM short shifter + base bushings, CAI, Tower braces upper and lower, Proflow TB + spacers, Blue interrior lights, Oil catch can, BC racing coilovers, TB bypass, Cooler NGK plugs, OBX long tubes, magnaflow exhaust, engine mounts, eibach swaybars.
fabguy is offline   Reply With Quote
2011, back, headers, king, kit, leak, long, mivec, nitrous, oil, rre, starting, turbo, turbo kit, what to do
