Old January 31st, 2012, 09:53 AM   #1 (permalink)
Dirty D
douellette's Avatar
Vehicle: 06 GT sportronic
douellette will become famous soon enough
Difference between AT and MT cai's?
what is the difference? just a diff mounting bracket? or is the pipe routed differently? cuz i found an ebay cai i want but it says MT only
Mods: DC Sports CAI, Aero Turbine muffler, painted rear spoiler, painted front emblem
facebook.com/DDcomputers <-- Me and my brothers computer repair business, check us out!
douellette is online now   Reply With Quote
Old January 31st, 2012, 09:59 AM   #2 (permalink)
Huge Member
Steveo's Avatar
Vehicle: 2006 Eclipse GT-N
Steveo will become famous soon enough
Believe it's routed different because of how the transmission is mounted..but not a 100% on that.
Full Bolt On + Zex 75 wet shot ~ 353WHP~~327lbs TQ
http://club4g.org/board/members-ride...ates-ride.html
RIP Matt (bullet06) A great man you were.
Steveo is offline   Reply With Quote
Old January 31st, 2012, 10:20 AM   #3 (permalink)
Dirty D
douellette's Avatar
alright cool
anyone else have some info?
Old January 31st, 2012, 10:43 AM   #4 (permalink)
dsm2mivec's Avatar
Vehicle: 06 Mitsu Eclipse GS
Its bc the at is larger and takes up more space but the cai's fit it just rubs a little! Fujita cai and injen Sri both fit prrfectly
Old January 31st, 2012, 10:50 AM   #5 (permalink)
Dirty D
douellette's Avatar
the tranny itself is larger or the intake tubing is larger? cuz i will buy the MT one if it will fit right in on my AT
Old January 31st, 2012, 11:20 AM   #6 (permalink)
dsm2mivec's Avatar
The at tranny is larger. You can run a good quality intake no problem but the cheaper brands you may have to grind a smidge off
Old January 31st, 2012, 11:22 AM   #7 (permalink)
dsm2mivec's Avatar
I assume your talking about the 4 cylinder
Old January 31st, 2012, 12:03 PM   #8 (permalink)
Dirty D
douellette's Avatar
nope the v6, haha. these are the ones im looking at on ebay (and no i am not planning on using the crappy filters that come with)
eBay - New & used electronics, cars, apparel, collectibles, sporting goods & more at low prices
2006 2007 MITSUBISHI ECLIPSE V6 3.8L COLD AIR INTAKE RD | eBay
Old January 31st, 2012, 01:54 PM   #9 (permalink)
SEXUAL TYRANNOSAURUS!!!
executive's Avatar
Vehicle: 07 GT-N Spyder 4.0
Do those off brand intakes works? I swore some said they had problems with theres.
in theory the a/t one should fit m/t but not the other way around. It may rub and get beat up. That motor and Trans does alot of jumping without a stiff and mounts
executive is offline   Reply With Quote
Old January 31st, 2012, 02:21 PM   #10 (permalink)
dsm2mivec's Avatar
Your probably talkin about the weapon r it caused misfires and other problems but a guy found that it was frying the maf bc it was over heating with modification he got it workin fine!
Sorry doulette if only you had a i4
Old January 31st, 2012, 02:29 PM   #11 (permalink)
Huge Member
Steveo's Avatar
Don't buy those!! My first one was like that and the bracket broke within 2-3 months and the filters are junk...although my fujita did the same it was much longer of a time and it worked out cuz I had to tap it for nitrous anyways..I like the injen cuz there is an added support.
Old January 31st, 2012, 02:58 PM   #12 (permalink)
Dirty D
douellette's Avatar
haha...well its either ebay ones or a dc sport one...although its almost $100 more (And i hate spending alot of money on one thing) haha
Old January 31st, 2012, 03:53 PM   #13 (permalink)
executive's Avatar
Spend it now or spend even more later. Though, obx headers and that Ebay seem to work ok
Old January 31st, 2012, 06:52 PM   #14 (permalink)
Huge Member
Steveo's Avatar
I did the same thing bought a cheap one for $70 got screwed..company wouldn't replace. Fujita cost around $150 and when it broke they were quick to replace but I did t need to because I welded it myself..if I had went the good route first I woulda saved myself $70 and down time.
Old January 31st, 2012, 07:58 PM   #15 (permalink)
deprydation's Avatar
Ok check it out. The REAL difference.
Yes, they are mounted different, but that is only a minor bend and change of mounting bracket.
Now the difference with the AEM with the A/T and M/T CAI's is the addition of screens inside the coupler piece between the upper pipe and lower pipe. I talked to MikeW at RRE about this and he explained it very well since RRE got to do alot of R&D for AEM with the CAI design.
When the M/T sits at idle, for some reason it sucks less air than the A/T. When you have slow speed, low pressure air headed around a bend in piping, alot of times it will become turbulent. Hell any bends in piping can cause air to become turbulent period, but less so on the A/T model for some reason. He went on for almost a good half hour with me about how the bends in the pipe had to be perfected and how they would change the MAF readings and air flow each way the pipe is bent or twisted. Finally it became a pain in the ass with the M/T because of the slow speed air at idle. The screens were put into the coupler to "straighten" the airflow that passes by the MAF sensor and give a more solid reading. This stopped it from also popping CEL lights and other nice stuff.
So, any more questions?
Besides the "What CAI should I get?" or retarded shit like that.
this guy is a cunt rag
Old January 31st, 2012, 08:08 PM   #16 (permalink)
Dirty D
douellette's Avatar
thats pretty much what i was looking for! lol thanks. ill go with the DC CAI then unless i can find a cheaper used CAI before than
Old January 31st, 2012, 08:11 PM   #17 (permalink)
pat_08GT_Spyder's Avatar
Vehicle: 08 GT Spyder 6MT
So why doesnt the Fujita have a screen? Obviously not doubting Mike's word, or yours, but i've aleays read that the screen on the AEM is more like a by-pass valve to avoid sucking water in (when the filter is submerged, the engine gets air through the screen)?????
275whp topless
My ride: http://club4g.org/board/members-ride...gt-spyder.html
pat_08GT_Spyder is online now   Reply With Quote
Old January 31st, 2012, 08:23 PM   #18 (permalink)
Dirty D
douellette's Avatar
yeah ive seen that too
Old February 1st, 2012, 11:23 PM   #19 (permalink)
Negative, the screenS are there to straighten the airflow.
Fujita probably didn't do as much R&D with the unit as AEM did. Remember Fujita is not approved by the California Air Resource Board. The screen will not stop any water from getting past it, trust me, more than once have I had an "oh shit" moment where my MAF has become wet in the rain.
Stupid me
Old February 2nd, 2012, 09:00 AM   #20 (permalink)
you sure, bro??
i swear i saw a video one day of a Supra, or some other Jap car, on a dyno, with a rigged up intake + screen (longer intake tube so that they can hand-manoeuver it), where the guys would pull it in and out of a water bucket to show how the screen works... mhm...
as far as Fujita's R&D, well, they make it sound sexy, that's the most important
275whp topless
Old February 2nd, 2012, 08:18 PM   #21 (permalink)
you sure, bro??
You're thinking the bypass valve. The screens are just literally 2 pices of metal mesh in the pipe coupler. The bypass valve has foam and crap in it.
Old February 2nd, 2012, 08:36 PM   #22 (permalink)
ahhhhh, why didnt you say earlier??? i thought that's what you were talking about... i've never seen a AEM intake either, so it doesnt help
dammit
275whp topless
bracket, cai, mounting, pipe
