Go Back   Mitsubishi Eclipse Forums > Performance and Technical > Electronics, Audio & Lighting
Electronics, Audio & Lighting Discussion regarding anything that hooks up to DC voltage goes here.
Login to remove these ads.
Old July 25th, 2008, 12:24 AM   #1 (permalink)
Permastudent
Overeducated Slacker
Permastudent's Avatar
Vehicle: '08 Spyder GT Rave Red
Rep Power: 1 Permastudent is just really nicePermastudent is just really nicePermastudent is just really nice
Amp power wire install?
I used search a few times, but I'm still confused...
How do you get the power wire for an amp from the engine bay into the cabin? I got the fenderwall thingy off, and followed the wire bundle to a grommet...that can't be removed and appears to be extremely tightly packed. What am I missing? The only 2 options I can see are:
1. cutting into the grommet and thereby making it useless
2. pulling the tape off and squeezing/forcing the power wire through there and hoping I don't screw anything up
Am I missing something obvious? Which option are people taking here? This was so much easier in my xB. :/
Thanks!
Permastudent is offline   Reply With Quote
Old July 25th, 2008, 09:41 AM   #2 (permalink)
dentedz71guy
The redneck
Rep Power: 2 dentedz71guy is a splendid one to beholddentedz71guy is a splendid one to beholddentedz71guy is a splendid one to beholddentedz71guy is a splendid one to beholddentedz71guy is a splendid one to beholddentedz71guy is a splendid one to beholddentedz71guy is a splendid one to beholddentedz71guy is a splendid one to behold
hahaha...we did firewall + 1" drill bit
dentedz71guy is offline   Reply With Quote
Old July 25th, 2008, 04:54 PM   #3 (permalink)
psy-q
Time for a sexy party
psy-q's Avatar
Vehicle: 2007 Eclipse GT-P
Rep Power: 6 psy-q has a reputation beyond reputepsy-q has a reputation beyond reputepsy-q has a reputation beyond reputepsy-q has a reputation beyond reputepsy-q has a reputation beyond reputepsy-q has a reputation beyond reputepsy-q has a reputation beyond reputepsy-q has a reputation beyond reputepsy-q has a reputation beyond reputepsy-q has a reputation beyond reputepsy-q has a reputation beyond repute
Whatever you end up doing make sure you get some black silicone goo to waterproof whatever you've opened up.
"Banned from .com" club member
Wise Words
psy-q is offline   Reply With Quote
Old July 25th, 2008, 06:11 PM   #4 (permalink)
Permastudent
But where do you drill? I can go buy a grommet but I don't want to randomly drill and do bad things.
As for anyone saying (including the guy who posted the sticky) that you can install an amp wire in 30 mins through the driver-fender-grommet: Until you show pics and give a step by step, you're lying through your teeth or you have no bones in your body. The thing doesn't even line up properly from the inside to the outside.
Old July 25th, 2008, 06:50 PM   #5 (permalink)
dentedz71guy
The redneck
I pulled back the mat and covering up behind the brake pedal. Then had someone tap one the inside of the engine bay on the firewall (yeah not foolproof but it was pretty reliable) and located where to drill. I then used a smaller drillbit to make a starter hole then finished it with the larger one. It's been in over a year now and there hasn't been any water leakage.
Old July 25th, 2008, 09:36 PM   #6 (permalink)
Permastudent
Did you use a grommet?
Old July 26th, 2008, 01:47 AM   #7 (permalink)
Permastudent
Yep, got it - thanks a ton!
Almost hit my break assembly in the process, but almost doesn't count except in horseshoes, handgrenades, and pregnancy scares.
Tomorrow we'll work on actually getting everything working - given how much effort it took (had to remove the battery) just to get a friggin' wire run, that's a big enough victory for today.
Old July 26th, 2008, 12:40 PM   #8 (permalink)
dentedz71guy
The redneck
cool, glad it worked out! No, I didn't use a grommet or silicone (best idea to to use one) but like I said, we haven't had any water leakage in over a year and she's driven through some pretty sloshed areas...
Old July 27th, 2008, 01:24 PM   #9 (permalink)
Permastudent
Well, as a friend of mine pointed out: given how high-up it is there, if you've got water reaching that spot, you've got some serious issues regardless of whether or not there's a hole.
Old September 8th, 2008, 10:00 PM   #10 (permalink)
infuriated
infuriated's Avatar
Rep Power: 1 infuriated is on a distinguished road
can someone upload a picture please as I already drilled one hole too far down, thanks.
infuriated is online now   Reply With Quote
Old September 19th, 2008, 09:02 AM   #11 (permalink)
joshmbu
Vehicle: 2006/Eclipse/GT
Rep Power: 1 joshmbu is on a distinguished road
I need to try some of these idea's, I ran mine from battery with zipties down, and up through where the steering comes through the floor.
joshmbu is offline   Reply With Quote
Old September 21st, 2008, 02:56 AM   #12 (permalink)
MG4G
Rep Power: 1 MG4G is on a distinguished road
can you post a picture of this spot so i can see exactly where to drill
MG4G is offline   Reply With Quote
vB code is On
SEO by vBSEO 3.0.0
Club4G.org Copyright 2007
