| Electronics, Audio & Lighting Discussion regarding anything that hooks up to DC voltage goes here. |
Shit Happens
06 Eclipse GS
Projectors.
I have a set of the projector headlights with a set of 8k HID's.
I put them in and they are very bright but for some reason when I took my car into the shop I just asked if they would re-aim them up a little. After the guy was done he told me that the Low-Beam lights could not be a adjusted up or down. I would love for them to be adjusted up a little bit because they are aimed down a lil to low. Is there anyway or special trick that will allow me to aim them up a notch. Any help would be great! Thanks. |
| Sponsored Links |
Luis.GT.06
06/eclipse/GT-Premium
well it;s a little hard but it can be done, i had the same problem what you can do is try to remove the bumper from the sides and their you will find some screws and when you turn them the projectors are going to go up and down, i recommend that you do it slowly because if you screw them on too high then it's harder, i hope that could be of any help to you
Luis.GT.06The mods: TEIN S tech springs, led halo projectors, led altezza taillights, HID 6000K, tints, ralliart emblems, mudflaps and more.
Moderator
![]() Join Date: Aug 2007
07 Eclipse GST
Projectors FTL - nothing but problems... they look good until the lense starts peeling and the halos burn out... but I had the same problem with the beam to low and I never tried fixing it... good luck!
Luis.GT.06
i think that the problem with the beams is that the bulb is inside of the lence and the light is not coming out at all, if you can see in the proyector you can see the intensity of the HID comes out through the side of the of the front light and the bulb is left separated from the lence so the light will kinda look not so strong
