Go Back   Mitsubishi Eclipse Forums > Performance and Technical > Electronics, Audio & Lighting
Electronics, Audio & Lighting Discussion regarding anything that hooks up to DC voltage goes here.
Login to remove these ads.
Old September 14th, 2008, 12:37 PM   #1 (permalink)
Ricoswave
Lathe Master
Ricoswave's Avatar
Vehicle: 07 Eclipse GT
Rep Power: 4 Ricoswave has a brilliant futureRicoswave has a brilliant futureRicoswave has a brilliant futureRicoswave has a brilliant futureRicoswave has a brilliant futureRicoswave has a brilliant futureRicoswave has a brilliant futureRicoswave has a brilliant futureRicoswave has a brilliant futureRicoswave has a brilliant futureRicoswave has a brilliant future
Finding a Tach Signal/Window Switch
So nitrous has begun to sound more and more appealing to me, and I'm doing my homework to make the install go smooth. I'm hung up on one thing, finding the right wire to tap into for a tach signal for an RPM Window switch.
I guess on distributorless ignition you can just tap into the negative side of a coil? How would I go about that? Any suggestions? I'm off to the Factory Service Manual for more digging.................
Mods:
Progress Springs, Fujita CAI, Full 2.5" Stainless Exhaust, Ripp Long Tubes, Ripp Poly Mounts, Glowshift Gauge Pod and Gauges, SSK Weighted Knob, GTech SS
Old September 14th, 2008, 12:57 PM   #2 (permalink)
Ricoswave
Lathe Master
Ricoswave's Avatar
May have found the answer, barring some tests. It would appear that the ground for each coil is a black/blue wire. If anyone can confirm or deny this for me that would be great. I will test it soon enough, just not in the mood to strip perfectly good wires to look for a tach signal..............
Mods:
vB code is On
SEO by vBSEO 3.0.0
Club4G.org Copyright 2007
