Warren Gary
2007/GS/Black
So, last weeking i went to install my underdrive pulley and figured while i was down there i would buy a Gates belt to put on also, to avoid any problems. As i was in Andvanced Auto Parts Store I saw the Duplicolor Undercoating w/ Sound Eliminator. I thought, I'll put some of this in my wheel wells while i'm under there. Then i got a better idea. So, after i finished my pulley and spark plug install I proceeded to remove the Plasic hatch covers and spray the back of them with 2 coats of the Undercoating. I then sprayed the inside of the hatch panel with 1 coat. I let it dry for about two or three hours then checked on it. I knocked on the plastic panels and they were solid as a rock. The aluminum on the hatch was as well. i took it for a drive, and low and behold, hatch noise decreased dramatically. I almost could barley hear the exhaust from the back anymore. I did previously dynomat the area where the spare tire is, though. The sub does not rattle any of the panels at all. I am very impressed. The only problem is that it will take a week to get the smell out of the car. I will move on to the door panels and wheel wells later. Took me 2.5 cans of spray. About 7 bucks a piece at AdvancedAutoParts.
Has anyone else tried this before? Dupli-Color :: Undercoating Buy Duplicolor Professional Undercoat with Sound Eliminator, Black, 17 oz. Aerosol UC102 at Advance Auto Parts
2007 Black GS Debadged rear/ blue LED dome light/ blue LED map lights/ Removed front upper grill/ black painted feul door/ JDM Black OEM headlights/ 10K HID in Heads and Fogs/ RRE underdrive pulley/ Injen S-RAM Intake/ Tanabe Front Strut Tow Bar/ Ralliart style eyelids/ TB Bypass Mod/ Dynamat and Duplicolor undercoat/sound eliminat hatch / vortex generators Last edited by GchildT; June 29th, 2011 at 12:53 PM. |
Preston
2007/Eclipse/GT
This is the first time i've heard of this product. I have an annoying rattle coming from the metal heat shield above where the stock cat was in the mid pipe. Now I have a resonator there and that's whats causing it to vibrate. I am going to pick up a can of this stuff this weekend and give it a shot.
**5AT** AEM SRI // HKS 3" Headerback Exhaust // Ingalls Stiffy // KYB Shocks // Eibach Prokit // Eibach Rear Sway Bar // Centric Rotors & Ceramic Pads // D-Speed Rear Bumper // Projector Headlights With CCFL Halos // 3k Fogs // 15mm Ichiba Spacers // SE Lip |
Jeff
2008 Eclipse GS-N
this reminds me one of my heat shields and body panels are loose.
| auto, back, belt, black, buy, car, door, exhaust, install, noise, panel, parts, problems, rattle, remove, shop, sound, spark, spark plug, tire, wheel |
