Old July 3rd, 2011, 01:20 AM   #1 (permalink)
blaise2212 is on a distinguished road
Will I need an alignment after half in drop?
So my car was recently lowered about 2 inches. I'm going to lower the front about another half inch and only on the front. Will I need a wheel alignment AGAIN just for a half inch drop?
blaise2212 is offline   Reply With Quote
Old July 3rd, 2011, 07:28 AM   #2 (permalink)
groundpounder's Avatar
Vehicle: 2008 spider gs
groundpounder will become famous soon enough
I think that will be ur limit without needing an alienment 2.5"
groundpounder is offline   Reply With Quote
Old July 3rd, 2011, 08:11 AM   #3 (permalink)
Vehicle: 2009 4G69
u should need an alignment after 2" bro if ur on stock struts
Old July 3rd, 2011, 08:11 PM   #4 (permalink)
I have Megan coilovers I already dropped my car once and got a wheel alignment done. I was just wondering if I want to drop the front another half inch would it be necessary to get another alignment done.
Old July 3rd, 2011, 08:13 PM   #5 (permalink)
My bad my first drop was about 3 inches not 2. That's why I got an alignment.
Old July 3rd, 2011, 09:18 PM   #6 (permalink)
Black Irish
muscles's Avatar
Vehicle: 2006/eclipse/gs
I would just incase. Otherwise you'll tear up your tires sooner then normal.
Old July 3rd, 2011, 09:31 PM   #7 (permalink)
^yeah not a bad idea - should be free if the alignment was done recently and it's garenteed work. if it's not going to be free, and you don't notice any 'pulling' or anything and it seems ok at the steering wheel, you'd probably be ok waiting until your next regular alignment. but yes, as ross says, wouldn't hurt to be safe.
Old July 3rd, 2011, 09:44 PM   #8 (permalink)
The O.G.
horse-eater's Avatar
11 Highscores
Vehicle: 2006 eclipse GT-TT
horse-eater has a reputation beyond reputehorse-eater has a reputation beyond reputehorse-eater has a reputation beyond reputehorse-eater has a reputation beyond reputehorse-eater has a reputation beyond reputehorse-eater has a reputation beyond reputehorse-eater has a reputation beyond reputehorse-eater has a reputation beyond reputehorse-eater has a reputation beyond reputehorse-eater has a reputation beyond reputehorse-eater has a reputation beyond repute
any time you touch your suspension, brakes or even change tires, you should get an alignment.
Under construction! Converting to single turbo, more to come!
Twin Turbo- 338whp/311tq@4psi - Mustang dyno, courtesy PIA in Spanaway, WA.
Panty dropping ability courtesy Forward Motion, Road///RaceEngineering, BrianJ, Delta Cams, Custom Import Heads
horse-eater is offline   Reply With Quote
Old July 4th, 2011, 01:01 AM   #9 (permalink)
Ok thanks guys. Also is there anyway of adjusting the height of the coilovers (megans) without having to unbolt the big bolts and everything else?
Old July 4th, 2011, 01:09 AM   #10 (permalink)
Daxenth's Avatar
Vehicle: 2008 Eclipse GS-N
if your on progress you dont need an allignment
Mods=Daxenth's Satin Girl
Buy My Stock Shit!
Old July 4th, 2011, 05:35 AM   #11 (permalink)
what do you mean by progress?
Old July 4th, 2011, 07:07 AM   #12 (permalink)
Black Irish
muscles's Avatar
Its a type of spring.
Old July 5th, 2011, 03:12 PM   #13 (permalink)
If you have Megan Coilovers (any coilovers), you unlock the large ring lock-nut, then just above that, use the same wrench to adjust the higth of the coilovers. Don't forget to take measurements so you know how far you are dropping. After you are done adjusting, don't forget to tighten the lock-ring, and make sure you check the lock-ring about a month later to make sure it didn't come loose.
Old July 6th, 2011, 05:33 AM   #14 (permalink)
im a lil bit confused Clovisman. on the megan coilovers theres 3 lock nuts all together. theres the main one on the bottom and then theres the 2 that lock into each other. Your saying unlock the main one on the bottom and them the big one on top?
alignment, car, drop, lowered, wheel
