feisal
2006 eclipse
Light engine service soon
Hi, i have eclipse 2006, change spark plugs, air filter, oil, etc. and light engine service soon is on. Help please. Sorrry my english.
Has A Big Member
Jake
01 svt cobra
We can't help you until we know what the code is
♥♣J-Hu$tle♣♠
Justin
95 Eclipse GSX
Go to autozone and have the code printed out they do it free then go from there. You can try pulling the battery cable for 5-10 min then putting it back on that'll reset the ecu then see if the code cones back.
My Hustle never stop like a car with bad brakes. '95 GSX/6 Bolt Swapped/HX35/Custom SMIM/FP Intake/2.5" Short Route IC Piping/Greddy Type S BOV/Big FMIC/750cc FIC's/Chipped EPROM ECU/DsmLink V3/AEM UEGO/AEM TruBoost/B&M STS/Punishment Racing radiator w/2x slimfans/BBS RX 17" Powdercoated GunMetal |
Don Glisson
2008 Eclipse GT
.....or if you are going to be working on your car a lot...go ahead and by a code reader. You can pick one up for about $60 and it is worth having one around.
John
2007 Eclipse GT
Because of the maintenance you did, long story short, disconnect both battery leads, then reinstall them. This will put the ECU into factor re-learn mode, this will allow the ECU to learn its new parameters from the factor setting which is much easier for the ECU to do rather then trying to learn form its current mode.
Also like the other have mentioned, by an OBDII code reader and post the codes, this way we can tell you how to fix your problem.
| 2006, air, air filter, eclipse, engine, filter, light, oil, plugs, service, spark |
