Old July 8th, 2011, 12:55 PM   #1 (permalink)
Vehicle: 2010 eclipse
glenncalabro is on a distinguished road
brake pads
how to check brake pads for possible ware and replacement> im getting brake light on while accelerating only>
glenncalabro is offline   Reply With Quote
Old July 8th, 2011, 01:30 PM   #2 (permalink)
Vehicle: 2009 4G69
well if ur brake pads r seriously worn down then the metal wear sensor clip on the pad will b exposed to the rotor and when u brake it will make a screeching noise. . .brake light means hydraulic pressure has been lost check ur brake fluid level and make sure it is not too low
Old July 8th, 2011, 04:21 PM   #3 (permalink)
NitroGlisson's Avatar
Ditto.....If the light comes on when you accelerate it is because your fluid is low. The fluid surges to the back of the vessel/reservoir exposing the sensor. Fill it up and check again before too long to be sure you don't have a leak somewhere.
NitroGlisson is online now   Reply With Quote
Old July 8th, 2011, 04:34 PM   #4 (permalink)
ptr149's Avatar
Vehicle: 2007/Eclipse/GT
^I was just about to type that Don. I have had the same thing happen and it was the fluid. Luckily it's an easy fix.
**5AT**
AEM SRI // HKS 3" Headerback Exhaust // Ingalls Stiffy // KYB Shocks // Eibach Prokit // Eibach Rear Sway Bar // Centric Rotors & Ceramic Pads // D-Speed Rear Bumper // Projector Headlights With CCFL Halos // 3k Fogs // 15mm Ichiba Spacers // SE Lip
ptr149 is offline   Reply With Quote
Old July 8th, 2011, 05:45 PM   #5 (permalink)
deprydation's Avatar
Fill your reservoir and actuate your brakes.
Get a friend and look in all your brakes while you actuate them to check for any leaks in the system.
Also if you have a manual transmission, the clutch uses your brake fluid to actuate the hydraulic clutch. You also need to look at possible leaks in this area, but only if you have the manual.
this guy is a cunt rag
brake, brake light, how to, light
