Quebec Light Source
Olivier
Lancer ES/AWC 2012
yea....the right side of my trunk is not closing if i don't close it pushing on that side...at least we only have 3 doors to look at when the light shows in the dash
John
2007 Eclipse GT
OK, with your truck open, same for your front hood also, on each corner you will see a rubber stop, one on each side. By hand, you can screw this up or down as needed. Some times these will go out of adjustment, if to far in the trunk can rattle, or if to far out can make it difficult to close the trunk. If this does not help, then you'll have to adjust the trunk lock-gate.
call centers suck
Elliott
06/eclipse/gs 5spd
i have the opposite problem. all i need is a slight force, like just taping with my finger and it will close all the way. i think the gas struts are about dead
mods: rre header, rre axleback, rre underdrive pulley, tb bypass, fujita cai/aem bypass valve, eibach prokit, twm shifter/type r knob, tanabe stb, oe fogs, webasto sunroof, eclipse cd4000 hu |
John
2007 Eclipse GT
Well if it drops quickly without having to give it some force then your struts are bad, i.e. like your front hood, it just slams if you let go of the hood.
