Old July 20th, 2011, 10:20 AM   #1 (permalink)
-cruzer-
JoeyC's Avatar
Vehicle: 2006 ECLIPSE GT
my cars bleeding!!
im so scared i noticed a few drops of oil on the floor yesterday and when i left 4 work today! I hope its not bad. I added half a court to get to work but i cant get a dam jack under my car now to see whats goin on?how do other cars get lowerd cars lifted with a jack?my idea is to drive onto 2 pieces of wood and that may get me up enough? i recently had timing belt water pump cam seal tensioners drive belt replaced could one of these be causing a leak possibly?
JoeyC is online now   Reply With Quote
Old July 20th, 2011, 10:28 AM   #2 (permalink)
Lathe Master
Ricoswave's Avatar
Vehicle: 05 Lancer Evolution
Of all of those the cam seal is the most likely...
Mods:
Old July 20th, 2011, 10:40 AM   #3 (permalink)
mrgibs121's Avatar
Vehicle: 2007 eclipse GS
im not sure about the GT but when they did the timing belt on the GS the tensioner is oil pressure controlled and its a metal to metal seal... the dude got dirt in there causing it to leak oil alll over when we started it... this could be your problem if it is similar on the GT
Old July 20th, 2011, 10:44 AM   #4 (permalink)
229boss's Avatar
Name: James Alphadawg Jones
u gotta get 2 jacks and lift one side up enough
Old July 20th, 2011, 11:01 AM   #5 (permalink)
Lathe Master
Ricoswave's Avatar
GT has a sealed hydraulic piston for the tensioner, if that blew he would have all kinds of rattling and whatnot not to mention the possibility of jumped timing.
Has anyone ever had you're valve covers off?
Mods:
Old July 20th, 2011, 11:02 AM   #6 (permalink)
-cruzer-
JoeyC's Avatar
ok ill check cam seal -and tensioners thanks rico and mr gibs
@229 boss-2 jacks- i cant get 1 jack under the car -my cars to low jack wont go under it!
Old July 20th, 2011, 11:19 AM   #7 (permalink)
TrainerZak's Avatar
Vehicle: 2006 Eclipse Gt
TrainerZak has a spectacular aura about
Just drive up on some pieces of wood, just enough to get the jack under there. That's what we have to do with the corvette. It's most likely coming for the cam seal though.
TrainerZak is offline   Reply With Quote
Old July 20th, 2011, 11:22 AM   #8 (permalink)
-cruzer-
JoeyC's Avatar
Originally Posted by trainerzak View Post
just drive up on some pieces of wood, just enough to get the jack under there. That's what we have to do with the corvette. It's most likely coming for the cam seal though.
sweet i cant wait to get home and try this!
Old July 20th, 2011, 11:32 AM   #9 (permalink)
Pureredgt's Avatar
Vehicle: 2006/eclipse/gt
Pureredgt is on a distinguished road
have you tried a low profile jack?
Pureredgt is offline   Reply With Quote
Old July 20th, 2011, 11:44 AM   #10 (permalink)
-cruzer-
JoeyC's Avatar
well i looked for one on intrnet yeterday lol 1st one was a racing low pro jac for 1400 i was like ahhh!but iit looks like it starts getting to tall half way -middle if jack if it was low all the way to back it may work thgey just look to tall?
Old July 20th, 2011, 11:55 AM   #11 (permalink)
Pureredgt's Avatar
whats the ride height of your car? i can check the height of our jacks
Old July 20th, 2011, 12:19 PM   #12 (permalink)
-cruzer-
JoeyC's Avatar
a little under 3 inches!
Old July 20th, 2011, 01:06 PM   #13 (permalink)
♥♣J-Hu$tle♣♠
Justin's Avatar
Vehicle: 95 Eclipse GSX
Justin has a reputation beyond reputeJustin has a reputation beyond reputeJustin has a reputation beyond reputeJustin has a reputation beyond reputeJustin has a reputation beyond reputeJustin has a reputation beyond reputeJustin has a reputation beyond reputeJustin has a reputation beyond reputeJustin has a reputation beyond reputeJustin has a reputation beyond reputeJustin has a reputation beyond repute
My low pro jack sits like 3 inchs high got for 100 bucks at walmart can lift 3 tons there awesome. I used to drive on boxs of cardboard to get the car up enough.
My Hustle never stop like a car with bad brakes.
'95 GSX/6 Bolt Swapped/HX35/Custom SMIM/FP Intake/2.5" Short Route IC Piping/Greddy Type S BOV/Big FMIC/750cc FIC's/Chipped EPROM ECU/DsmLink V3/AEM UEGO/AEM TruBoost/B&M STS/Punishment Racing radiator w/2x slimfans/BBS RX 17" Powdercoated GunMetal
Justin is offline   Reply With Quote
Old July 20th, 2011, 01:47 PM   #14 (permalink)
-cruzer-
JoeyC's Avatar
ill chek walmart out!
Old July 20th, 2011, 01:55 PM   #15 (permalink)
♥♣J-Hu$tle♣♠
Justin's Avatar
Walmart.com: Torin Jacks 3 Ton Low Pro Jack: Automotive
Old July 20th, 2011, 03:22 PM   #16 (permalink)
Pureredgt's Avatar
the jacks we have are like 3 1/4 inches tall
Old July 20th, 2011, 04:31 PM   #17 (permalink)
-cruzer-
JoeyC's Avatar
this may work ill try it -or add boards and try it!
Old July 20th, 2011, 08:49 PM   #18 (permalink)
Check AutoZone and other part store, they always have sales and such, I got one for $35, and another 4 ton low-profile for $75.
Old July 20th, 2011, 11:22 PM   #19 (permalink)
-cruzer-
JoeyC's Avatar
well i decided 112 degrees out side is to hot to lay on ground and it wasnt broke before i got it tuned up so i droped it back off at shop he said its gotta be cam seal cuz there cheap from checker?
Old July 20th, 2011, 11:28 PM   #20 (permalink)
deprydation's Avatar
Harbor freight is your friend when it comes to jacks too.
Sucks that the cam seal is leaking. At least you have a shop to fix it for you.
this guy is a cunt rag
Old July 21st, 2011, 11:16 AM   #21 (permalink)
-cruzer-
JoeyC's Avatar
whats up will-yah they better fix that shit they did all that work before i came to cali! i miss cali-that mod how was awesome i kinda wish i would of looked at all the 4gs better it all went so fast i felt like i was in lines all day in n out,then rockfords,then drawings, -all them lines and i missed the show-and worst part is so cal chino recorderd us sall leaving parking lot and my dam car couldnt leave the parking lot where yall did so i missedout on video to!!!
Old July 21st, 2011, 06:02 PM   #22 (permalink)
Yeah, dude, you haz some nice stance on that thing but not for California streets...
Just too low. Oh well though man, glad you had fun and everything. I wish I could have parked next to ya at Extreme Auto Fest...
Would have been neat having my ride in there too.
Old July 21st, 2011, 06:16 PM   #23 (permalink)
phast007's Avatar
Vehicle: 2006 gt v6
phast007 is on a distinguished road
i used to pull up on some peices of wood to get a floor jack under it. Ask autozone if they have some jacks that they want to sell. I picked up two that way
phast007 is offline   Reply With Quote
bad, belt, cars, drive, leak, oil, timing, water, work
