I just installed my 10k h13 hids everything is working good. The only problem is that the lights stay on the whole time. When I first start the car and the ebrake is up I can turn the lights on and off. As soon as I drop the ebrake the lights stay on no mater what. I can't turn them off. I installed the kit as I was supposed to. Can someone tell me what's up with this??
Black Irish
Ross
2006/eclipse/gs
our eclipses come with drls. Meaning daytime running lights. There is a how to thread on disabling them on the forum takes about a few mins to do.
I got it. It was the high beam fuse. But now I'm having a problem with my driver window. You know how when u close the door and the window is up already and the motor closes the window by it's self. Mine isent doing that. What could this be?
#12 (permalink) | ||
2009 4G69
Got Stance??? i dont :(
Dann
2009 Eclipse GT
turn u key the 2 clicks without startin ur car... roll down ur driver side window and hold the button in intill u hear a click... then roll it up to reset it..
#27 (permalink) |
2009 4G69
all this due to HIDs lol . . and yes about the fuses, always get 5-10amps higher than u kno u need
#31 (permalink) |
I look stock...
Jason
2008 GS 5spd
i cant wait for thread where he starts performance modding..
#33 (permalink) |
John
2007 Eclipse GT
Like Dustin said recheck your wiring hanesses for a short.
Then it's time to pull-out the multi-meter and check voltages. More then likely you might have another bad ballast. What kind oF HID kit did you buy??
#35 (permalink) |
Queen Goon
Tournaments Won: 3 Name:
Lisa
06/Eclipse GT
Is this a joke or for real?
Chaos - lisa i like your car a lot. Here's why, the black says ill fuck you up if you try to mess with me but the pink accents tells me that you'll cuddle afterwards -Mods: SRI, Exhaust, Headers, Stiffy, Rear Sway bar, Motor Mount, Reflashed Ecu, Black -Pink Rims , Spoiler,Painted tail lights, 2% Tint Tein Springs,- |
#36 (permalink) |
Got Camber? 10.5+15 of IT
Fuzzy Wuzzy Umpkin
2006 Eclipse GT
MY AUTOMOTIVE PHOTOGRAPHY SITE - STREET | MANOR Check Out The Official Kazman Thread!!! |
#39 (permalink) |
Wize Old Azn
Absinthe
'08 GT
I know we've all had our problems from time to time, but this? It must've been one of us effing around, posing as a n00b.
But if this was a real person, I wonder if the car is still in one piece...
#40 (permalink) |
Don Glisson
2008 Eclipse GT
This was entertaining!
![]() If you didn't specifically buy a high/low beam set or a bi-xenon set then the high beams are not gonna work. If you used the car with the DRL still connected after the HID install the lower voltage used for the DRLs could have damaged something. Please do some research in here before starting other projects and know that the instructions that come with some kits are not specific to our car and believe me this car has some quirks Good luck resolving your issue(s)....we sure will try and help though.
| art, car, drop, ebrake, good, h13, hids, kit, lights, problem |
