2006 Eclipse Gt
Mobil 1 5w-20. Cost about 27ish bucks at walmart. Get the extended guard filter by fram. It's the most expensive one. Should cost about 9 bucks. It's for synthetic. Change every 3750 miles is what is recommended by mitsubishi. Just make it every 4k, depending on your driving habbits.
2009 4G69
mobil 1 extended performance 5w-20 . . on advanced auto parts and auto zone computer programs they say to use 5w-30
AEM FIC / UEGO Wideband + POD / Custom Bolted Last edited by FeaRlezZ; August 1st, 2011 at 04:39 PM. |
Quebec Light Source
Olivier
Lancer ES/AWC 2012
if you don't do a lot of milage you don't need a lot of oil changes(i do less than 10k in a year) except for winter. Always respect the 3 months limit or 4k during winter because your engine is getting more humidity during winter.
#10 (permalink) | |
Perfection over power
Trevin
06 GS-Turbo
I will be productive and answer though, Mobile-1 Extended performance 10w-30... dont use the oil I do, I have special circumstances |
Speed Fanatic
Thomas
2003 350z Touring
Mobil one extended performance with a K&N HP-1010 Oil filter.
BEST OIL IMO. I was using Castrol Syntec, Mobil One EP is sooooo much better. The car runs like a sewing machine now |
#12 (permalink) | |
2006 Eclipse Gt
@ bk3939 Where do you buy your oil? I could get royal purple for cheaper, but mobil 1 has never let me down. Yes, you can go longer between changes, but if you change every 4k your engine is like new inside and you wont build up any performance robbing composites in your engine. |
2009 4G69
^ thats wut im saying dont go by wut a parts store tells u . . even though if u accidentally took 5w-30 it will not do anything wrong
Trevin
06 GS-Turbo
Advanced auto parts > Auto zone.. in this area at least. they have better products and a smarter staff, but again that is just where I am from it could flip in a heart beat
Loves haters !
09 5 speed manual
i use the oil that has the less friction between the block and pistons
.seriously,mobile 1 syn is what i use
Modified Last edited by snakeeyes; August 1st, 2011 at 05:44 PM. |
2006 Eclipse GT
I too use mobile 1 full syn and change it every 3k same for the wifeys civic and soon on her optima turbo
Current mods: F5 CAI, tint, Ruffracing R281 19x8.5 RRE [update coming] |
#23 (permalink) |
Brandon
2011/GT/6MT
rockin some castrol full synthetic, usually just get the dealership to do the maintenance, though i'm thinking the next change will be royal purple (not due for another 2500km)
my oil changes with full synthetic are around 75$ (CAD) |
#24 (permalink) |
2007 eclipse se 2.4l
If im runnin conventinal oil and switch to full synthetic will my car start to leek or will it harm it in anyway?? Im at 46,000 milies
Magnaflow catback 2.50 , GT tb (thermal spacer), Injen sri, RRe headers (jet hot coated),RRe underdrive pulley, cf/gunmetal oil cap, pulstar sparkplugs, ss brake lines, pro-kit drop, Halo projectors, projector eyelids, 6000k hid,Led taillights, Disabled DRL, Oem fogs blacked out, 5% Tint, debadged, 18x8 matte black Rohana rims, Falken 912 tires. |
#26 (permalink) |
Ive heard when u switch, your car is more prone to leek
#28 (permalink) |
Sounds good thanks
#30 (permalink) |
John
2007 Eclipse GT
Back in the old-days when syntetic's first came out and many engines still used cork seals, there was a problem sometimes when you switched from fosil to syntetics, no so anymore.
Mitsu recommends 7500 mile oil changes for normal driving, anyone here drive normal !! But if you drive it hard, keep it simple... 5000, 10,000, 15,000, 20,000, etc. you can't go wrong and forget when you need an oil change. But if you're a pusher and drive track ect. well you need to be doing it a lot sooner!! Oil is cheap compared to an $8000.00 engine.5w-20, or 5w-30 and a good oil filter. Torque on the drain plug is 30 ft/lb A light coat of new oil on the filter seal, hand tight until it seats, then 1/4 turn with the wrench. And if this is you first oil change, mitsu uses a sealant on the oil filter seal, and it's goiing to be a bitch to remove the first time!! So borrow your friends gorilla to remove it!!
#32 (permalink) |
Quebec Light Source
Olivier
Lancer ES/AWC 2012
doing an oil change on our cars is so easy...im doing my oil changes in my gravel driveway and it takes me 15 minutes. 5L of mobil1 5W20 cost me 50$ at canadian tire(try to find one in US if you want to have fun XD)
#34 (permalink) |
mike
07/Eclipse/GS
I use mobil full synthetic and the m1-104 filter here at autozone. I pour an extra q or two thru it to get any remaining sludge tho before i cap it off and filk it til next time
#35 (permalink) |
John
2007 Eclipse GT
Pouring extra oil though the engine will not get rid of any sludge!! Regular oil changes with quality oil is the best way to keep your engine clean and sludge-free. Penzoil has a good syntethic oil with cleaning agents that will help clean your engine.
#37 (permalink) |
Quebec Light Source
Olivier
Lancer ES/AWC 2012
once i started playing in cars i bought a little kit for something like 80$ with a small 1 ton jack and 2 stands but i died under the heavy eclipse weight so now i bought a new one for 160$ that is a michelin 3 1/2 ton wich is sooooooooo great
this is what it looks like ![]() some extra pictures of an oil change i did at 7:30 AM XD too lazy to go the the 1$ shop and buy a dish pan to put my oil in ![]() ![]() the oil filter ![]() the oil pan
#38 (permalink) |
Gabe
2007 Eclipse GS M/T
Are you sure about this??? I am fairly certain the air is dryer in the winter.
Mods: F5 CAI, RRE Pulley, Tint, Custom Painted Headlights, Eibach Pro-Kit, 10000K HIDs, Tinted Fogs w/6000K HIDs |
#39 (permalink) |
Elitist Prick
Jason
2011/Eclipse GS
AMsoil. Good stuff.
On a side note, call Advance Auto Parts or Autozone and ask for a head gasket for a 1997 RX7 and see how long they search. Not the sharpest of tools.
RRE UPD, Custom Exhaust, CAI, Megan Racing Springs, Ralco Short Shifter, Eibach Rear Sway, HID Projectors, LED Tails, AIC CF Hood, Vortex Generators, Rear Seat Delete, Grillecraft Grille, Big Cock |
| oil |
