Old September 6th, 2011, 03:58 PM   #1 (permalink)
SEXUAL TYRANNOSAURUS!!!
executive's Avatar
Vehicle: 07 GT-N Spyder 4.0
Need some bolts
The bolts that hold the bracket for the rear mount to the trans. What size, type, and length are they?
executive is offline   Reply With Quote
Old September 9th, 2011, 12:09 AM   #2 (permalink)
deprydation's Avatar
Ohhhhhhhhhhhhhh
Sounds like you've experienced my problemo there sir!!!
They're a 12mm bolt, not sure how long or anything, but make sure you check the casting and everything on your transmission. For some reason mine snapped the hell off.
I think I used a .5 pitch with a 14 or 15mm head too...but I had to take mine out because of the casting breaking. Still gotta get around to fixing it when I get back from Japan.
this guy is a cunt rag
bolts, bracket, mount, rear, rear mount, trans
