Old September 20th, 2011, 01:46 PM   #1 (permalink)
Vehicle: 2006/Eclipse/GS
smokeyred_dot is on a distinguished road
how to take a 2006 Mitsubishi Eclipse gs Serpentine Belt off
The other day I went to start my eclipse and could not get it to turn it over it sounds like it wants to turn over but it wont i tried jump starting it and it was no good and I had the battery tested and it was good so i'm thinking its the alternator so ive searched all over the car for the Serpentine Belt diagram to find the tension bolt but could not find it could someone please tell me how to remove the belt.
smokeyred_dot is offline   Reply With Quote
Old September 20th, 2011, 02:00 PM   #2 (permalink)
dsm2mivec's Avatar
Vehicle: 06 Mitsu Eclipse GS
Ok wow um alright first off if you search the forums you'll normally find what you need. Second we don't have a tension bolt we have an auto tensioner. Take a half inch drive breaker bar and pry back then slide a small Allen wrench in the hole on the bottom of the tensioner til it holds itself back. Third look on rre website for the belt pattern if you have a gs or tearstone! And lastly tearstone is your friend look over the manual there! Good luck but I don't think it's your alternator bc it would start but would run long if it was your alternator keep me posted cause I have a few theories!
dsm2mivec is online now   Reply With Quote
Old September 20th, 2011, 02:15 PM   #3 (permalink)
Vehicle: 2008 Eclipse GS SE
OrangeCrush is just really niceOrangeCrush is just really niceOrangeCrush is just really nice
anything you need to know how to do or know how it's put together, is all solved right here.
Tearstone Performance - 2006 Eclipse Factory Service Manual
Originally Posted by Daxenth View Post
you shall be pro troll second in command! lol but yeah we do dude. fucking awesome. specially when shit really hits the fan
OrangeCrush is offline   Reply With Quote
Old September 20th, 2011, 02:47 PM   #4 (permalink)
alternator was good well i'm thinking its the starter now.
Old September 20th, 2011, 04:44 PM   #5 (permalink)
dsm2mivec's Avatar
If it's trying to turn over it's none of that try your could and your plugs.. Make sure your getting fuel.. And if you have clogged fuel filters or lines
Old September 21st, 2011, 02:56 PM   #6 (permalink)
I actually tested my fuel pump hooking it up directly to the battery and it was powering up but when I hooked it back up to the car it wasn't getting any power would you happen to know what would cause the fuel pump to stop getting power cause that's the problem im having now.
Old September 21st, 2011, 05:40 PM   #7 (permalink)
dsm2mivec's Avatar
Ok check your fuel pump relay and any fuses related to it
Old September 21st, 2011, 08:48 PM   #8 (permalink)
nokiauser's Avatar
Vehicle: Eclipse GS 5 Speed
Next time you're searching for "serpentine belt" info, probably want to look for "pulley" because to get the underdrive pulley on, you have to loosen the tensioner and remove the stock serpentine belt.
nokiauser is online now   Reply With Quote
Old November 4th, 2011, 06:58 PM   #9 (permalink)
Knoxville Tn.
Vehicle: 2006/eclipse/gs
toni is on a distinguished road
thats just what i was looking for, thanks
toni is offline   Reply With Quote
Old November 4th, 2011, 08:50 PM   #10 (permalink)
Chris05's Avatar
Vehicle: 2008/Eclipse/Gs-N
^ thanks for searching first
Chris05 is offline   Reply With Quote
2006, art, battery, belt, car, day, eclipse, eclipse gs, good, how to, king, mitsubishi, remove, starting
