Old September 30th, 2011, 08:18 PM   #1 (permalink)
mayday295's Avatar
Vehicle: 2008/Eclipse/GT
mayday295 is on a distinguished road
Strut removal tool
So I ran into yet another problem with my strut/spring install. The front struts are not able to be removed/replaced very easily. I know what tool it is I need but the only thing is no one nearby sells them and I really want to finish this job today or tomorrow.
So my question is, how important is the torque settings on the front strut nut? - the manual says it was 14, or 17 ft-lb(off the top of my head) with +/-1-lb of tolerance. So If i just used a socket and grabbed it with some pliers, and stuck a Allen head in there, would it be safe to just tighten it down by hand as hard as I can?
mayday295 is offline   Reply With Quote
Old September 30th, 2011, 08:20 PM   #2 (permalink)
hmmm.....that is a good question to which I do not know the answer. I want to say you'll be ok, but I am just not sure. someone on here needs to confirm or deny.
Old September 30th, 2011, 08:49 PM   #3 (permalink)
Elitist Prick
Xero's Avatar
Vehicle: 2011/Eclipse GS
Xero is just really niceXero is just really niceXero is just really niceXero is just really nice
I used an allen wrench and a socket with a really good pair of vice grips and it worked fine.
RRE UPD, Custom Exhaust, CAI, Megan Racing Springs, Ralco Short Shifter, Eibach Rear Sway, HID Projectors, LED Tails, AIC CF Hood, Vortex Generators, Rear Seat Delete, Grillecraft Grille, Big Cock
Xero is offline   Reply With Quote
Old October 1st, 2011, 02:14 AM   #4 (permalink)
mayday295's Avatar
ok great haha, turns out my KYB replacement strut does not have that allen key slot. (found this out after I removed mine) Instead it is solid with a | | shape on top, so I have no idea what tool will work for that... hopefully i can torque it down when car is resting its weight on it, otherwise maybe the guys at shop will be able to tighten it when I get this thing aligned.
Edit: used an airgun.
Old December 31st, 2011, 01:41 PM   #5 (permalink)
Vehicle: 07 mitsubishi eclipse gs
sham_rock1994 is on a distinguished road
which way does that allen head and nut turn on the drag link? i am having problems gettin the drag link off so i can take my strut off... need help asap send me a text at 8284608357. be much appreciated
sham_rock1994 is offline   Reply With Quote
head, install, manual, problem, question, removal, strut, struts, top
